Question about HP Computers & Internet
No Boot After the power went out and came back on my computer will not boot. The only thing it does is flash a little green light in the back of the computer. Nothing else..Nothing..the outlet that the computer is plugged into has the monitor in it and the monitor works so it is not the outlet. Any ideas?
    Master:
  • 518 Answers
Try unplugging the PC from the wall outlet for a minute, then plug it back in and try it.
Geno
Posted on Aug 02, 2008
Precision T7400 power supply sounding an alarm
Did you open the case on your computer? It may have an open case alarm which is a small switch typically located near the edge of the cover you removed. Make sure the case cover is completely installed, then see if the alarm goes off.
Feb 28, 2013 | Dell POWER SUPPLY Power Supply
WE HAVE JUST HAD A LIGHTENING STRIKE AND ALL POWER IN THE HOUSE WENT OFF WHILST MY ASPIRE E 700 WAS POWERED AFTER THE POWER CAME BACK POWER LIGHT WAS LIT BUT COMPUTER WONT START UP WITH START SWICH
Unplug everything from the laptop, remove the battery and let it sit for 5 minutes. Replace the battery only, not the power brick and see if it will boot.
Does the power brick have a solid green light? Flashing? Red?
If it will not boot off the battery or power brick it may be fried.
Jun 28, 2011 | Acer Aspire E700 PC Desktop
Have a HP m7470n. The green power light in the back is constantly on. The power button flashes blue and orange (~3 seconds each). The computer wont turn on. When I unplug the cord and plug it back in, the...
In my case it turned out to be a weak power supply. It would work sometimes and not others. If stone cold, it would not boot. If I unplugged 1 thing, like the hard drive or the CD Roms, it would boot. Tested the old power suppy and it seemed to pass. But once I connected a new power supply, the computer has worked fine ever since.
Jan 08, 2011 | HP Pavilion m7470n (ER883AA) PC Desktop
Power to 1T EHD not going through
yay, I plugged it back into my computer at home and it worked... might have not been enough power or the USB connection wasn't strong enough. anyway, happy happy happy...but have learnt a big lesson...BACK IT UP ON DVD as well.
Mar 26, 2009 | Western Digital My Book Essential 1TB...
Blank monitor
Try unplugging the power cord to your computer tower, click the power button to drain the capacitors in the mother board then plug the power cord back in and try to boot up. Has helped me repair several similar black screen problems. Chuck Housecall101@aol.com
Jul 24, 2008 | Star Logic 17" LCD Monitor
Hp wont turn on flashing green light in back an flashing blue light in front.
open your cpu remove the ram clean it put it back your problem will be sloves
Jul 16, 2008 | HP Pavilion a1250n (EG194AA) PC Desktop
Flashing Green Light on Power BESTEC Power Supply
This is an easy fix so here you go nice and simple:
Problem: Your motherboard circuit has been cut.
Causes: Power disconnected during operation. Power outage or short in the surge protector.
Symptoms: Flashing green light on both motherboard and power supply. System will not power on.
Solution:
Step 1: Ensure that both the power supply and the motherboard lights are flashing green, not solid or off.
Step 2: While the power is on, disconnect the power supply from the motherboard. This connection is the largest of the connections and should be listed as the 'P1' or 'Primary' power connection.
Step 3: Wait until the green light on the motherboard stops flashing and check to ensure that the green light on the power supply is now solid. If it is not solid, disconnect the power to the power supply and wait until the light turns off completely. Then reconnect, it should be solid now.
Step 4: While the power is on, reconnect the P1 connection to the motherboard and you should now see that the light on the motherboard is solid.
Step 5: Power on your PC. The problem should not persist.
Warnings: If the power supply light remains flashing after you have restored power to it while it is disconnected from the motherboard, it may be a system failure in the power supply itself requiring replacement. Always be careful when working with an active or live power machine.
I hope this helped! Good luck!
Jun 23, 2008 | Bestec (ATX-250-12E) 250-Watt Power Supply
Power light flashing
not understanding your question ..need more info .. is the computer not booting ? Is it flashing red, green, orange? need more info
Mar 08, 2008 | Computers & Internet
Power Green Light Flashing HP Desk Top PC m7250n
During a power outage their is a surge when power come back on the grid (surge can be caused by lighting strikes akso). This surge trips the internal procters inside the power supply to protect the Mother Board, hard drive, processor and fans and any device that pulls wattage from the power supply. Since all these power using devices are trying to pull power at the same time to boot the computer back up one ends up with a loop of surge thrugh the power supply with a protective trip, reset, surge again and trip again. This will continue in this loop as the computer is trying to boot all the devices at one time (Mobo, Hd, processor, cooling fans and other devices). Simoly, more power wattage is being demanded than the protectors will allow at one time causing a protective shutdown followed by a restart followe by a protective shutdown in a continious loop.
The normall sequence for a boot is to boot the board, processor and fans followed by a boot of the hard drive, and other boot devices once the board is energised, NOT all devices at the same time, as this results in an overload and trips the protectors. This protective loop is indicated by the blinking light as the power is turned on and then shut down for protection as the wattage pull is over the demand that the protectors will allow.
Blinking light indictes you are in the protective loop.
SOLUTION: 1. Disconnect the Mother Board connector, with the computer unplugged, this will allow the power supply to reset at maximum wattage upon reboot.
2. Disconnect the Hard Drive power connector and ay boot device power supply cables, this will allow the Mother Board, processors and fans to boot without an overload of the protector inside the power supply.
3. Plug in the computer and the indicator light will be solid green indicating that it is reset and out of the loop.
4. With the computer pluged in and the Power Supply fully energised, plug in the Mother Board. The computer will now boot, and the processor fan will come on and the cooling fans.
5. After computer has rebooted, shut the computer back down and connect the Hard Drive power cable and any other power cablis that were unplugged.
6. Reboot with all cables connected and you are up and running again.
POWER SUPPLIES HAVE AN INDICATOR LIGHT FOR A REASON.
REMBER - BLINKING LIGHT IS AN OVERLOAD OF THE PROTECTORS AND ELLIMINATING THE OVERLOAD SOLVES THE PROBLEM AND THAT THE POWER SUPPLY IS WORKING AND CONVERTING POWER.
NO LIGHT MEANS NO POWER OUTPUT AND THAT INDICATES THE POWER SUPPLY IS NOT FUNCTIONING AND NEEDS REPLACED.
Hope this helps everone with power outages and lightining strikes. It is a rather common problem and can also occure when building a computer and one missmatches the power supply with the board wattage needs. If the board wattage needs are greater than the power supply output you will get stuck in a potective loop eventually. WHEN BUILDING A COMPUTER ALWAYS MAKE SURE THE POWER SUPPLY CAN PRODUCE MORE WATTAGE THAN YOU CAN CONSUME AT THE MAXAMUM LOAD.
Have a great computing experiense.
Jan 13, 2008 | HP Media Center m7250n (ED842AA) PC...
Monitor flashes on and off!
Sounds like you have a bad connection from your monitor to your computer. First check and make sure the connection between them is tight. Does your computer boot up and run though? If your computer is not booting up the monitor will default back to the flashing green power light
Nov 29, 2007 | Dell E173FP 17" LCD Monitor
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
