Question about Lexmark X1190 All-In-One InkJet Printer
I need to download manual printing blank presume ink needed cartridge ref needed
TeK Micro
  • 62 Answers
SOURCE: PRINTER
The following link provides the user guide and setup sheet for your printer. They explain how to change the ink cartridges.
http://www.lexmark.com/publications/eng/1200/index.html
Posted on Dec 26, 2007
mediatecar
  • 60 Answers
SOURCE: My printing displays wrong ink levels and prints blank pages
If your cartridge is new (or full) and you know that not just from ink levels display, then you did not used the printer for a while (at least a month) and the nozzles of the cartridge are clogged. If u used the cartridghe 4 or 5 moths ago, then the whole cartridge is dryed out, so get out and get yourself a new cartridge.
If it's just a month, then you should put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the cartridge with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridge in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles. Then clean gentle the nozzle part of the cartridge on some sheets of tissue.
Install the cartridges it in the printer and run a few cleaning processes from the printers maintenance software.
If the cartridge is new and just installed in the printer, and you have the inklevels but it does not print, then get it out of the printer and back to the store, they should replace it for you. I hope you removed the protective plastic stripe that covers the nozzles before installing the cartridge?...
OK, let ne know please how things evolve.
Hope it helped you, rate the solution.
Almoust forgot: ink levels are displayed by Lexmark inkprinters by estimating the ink consumed trough you printing process, it has no sensors in the cartridge. It's just kind of a counter, you can evan set an empty cartridge to be seen as a full one.
Posted on Feb 15, 2008
jonniewalker
  • 1031 Answers
SOURCE: Printer doesn't print even with new ink cartridges.
turn the printer i turned on and Press the cleaning button ,. Cleaning takes about two minutes, the printer makes some noise when it finishes you run a nozzle check for print quality and reset the cleaning cycle.
load paper . go to the printer menu as follows: click Control Panel, and then double-click Printers. Select the Epson printer if have more than one printer is installed. Click File, click Properties, click the Utility tab, then click the Nozzle Check icon.
The printer will print a Nozzle Check pattern in black, and in cyan, magenta, and yellow. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If any dots are missing, clean the head again.
If your software is different, and does not have these options, you can do it this way:
1. Same as above.
2. Same as above.
Turn off printer and computer. Disconnect interface cable from printer. Load paper. Hold down the load/eject button and press the power button to turn on the printer. Release both buttons.
3 Same as above.
4 Turn off printer and reconnect the interface
Posted on May 17, 2008
SOURCE: color ink cartridge
You DO NOT need both cartridges in the printer your problem is you have put 2 color cart. in .It comes with the color and you need to buy the black one.da.
Posted on Jul 05, 2008
abhinav07
  • 22 Answers
SOURCE: Lexmark printer printing blank pages
hello sir,
dont worry this is d simplest case when either cartirage is choked or fileed with duplicate ink.
Try with another and if u still face this prob den reply
abhinav
Posted on Jan 10, 2009
My MX922 printer worked well this morning. All cartridges have ink but ALL lights under the cartridges are on and print comes out blank. There are no error codes or anything abnormal displayed
This problem is mainly happens to all inkjet printers. If your printer print blank pages then please at least once go to official site of Canon and check whether there is any printer/scanner drivers update is available or not. If yes then download it. Also check your ink cartridges. Because if there is no print on paper that means your ink might be dry.Sometimes it clog the print head. If your ink cartridges get dry change it. Or you should clean your printer's print nozzle by using printer's control panel. I hope all these suggestions helps you. If doesn't then watch Canon MX922 Manual English
Jan 12, 2017 | Canon Pixma MX922
What ink is used in an hp q1660a printer?
Here is the Information that you are looking for.
Ref Link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu00691&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=90764#jumptocontent
Inkjet print cartridge part numbers
Inkjet print cartridges Part numberHP 56 Black Inkjet Print Cartridge C6656A HP 57 Tri-color Inkjet Print Cartridge C6657A HP 28 Tri-color Inkjet Print Cartridge C8728A
Feb 18, 2013 | HP Q1660A PSC 1210 All-In-One Printer...
My lexmark z611 only prints blank pages with nothing on them, i bought a brand new ink cartridge that is black ink for it and it says it is low on ink for some odd reason but when i print things in color...
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
May 15, 2011 | Lexmark Z611 InkJet Photo Printer
Document is blank when print spooling and prints only blank pages. even test page printed is blank
I can only think its a problem with the ink cartridges.
Is it a new printer?
Have you taken the tabs off the ink cartridges?
Does it need a head clean?
Sep 04, 2010 | HP Computers & Internet
I have a cannon MP160 printer. Color ink button is flashing. The color ink cartridge is empty. I replaced the black ink cartridge and want to print in blank ink only. However, I can't get the color light...
try to go into the software for the printer and find a rest ink cartridge button. This will make it think it has a new one which wil let you print in black by selecting black print only
Jan 08, 2009 | Office Equipment & Supplies
Please help me, my epson inkjet all in one printing just blank blank blank
Epson printers will not accept continuous ink cartridges. That is why you are getting blank pages. I recommend just buying the ink cartridge as you need them.
Good Luck
Jan 05, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Printer prints blank pages. computer screen shows ink in cartridges
screen shows ink but many of the times if the cartridges are dried up it will print blank pages.clean the cartridge head clogging manually and then try.otherwise replace the cartridges.
Dec 07, 2008 | Lexmark Inkjet Z517 Photo Printer
Blank Pages HP Officejet d125xi
Here are a few things to try: 1. Remove and then reinstall the ink cartridges 2. Clean the ink nozzles because they may be clogged which can be done manually or sometimes using the printer control panel like so: Open the print or fax window > right click on ink jet printer icon > select Properties > on the general tab click printing preferences > click services tab > click clean the print cartridge. If you have this option it will automatically clean the print nozzles, if not you will have to do it manually (check your documentation if you still have it for details on how to do this). Take cu-tips and remove the ink cartridges > dip the cu-tips in distilled water (not tap water) and squeeze any excess water out of the cu tip > Hold ink cartridge so that the nozzle plate faces up and use the swab to wipe clean the area around the nozzle plate > Hold cartridge up to light to make sure all dust, dirt, dried ink, or cotton fibers are not left behind > Dry them off and replace into printer and print a test page. 3. Try different settings for the print quality to see if any changes occur. 4. Turn the printer on and leave it on for about 30 minutes to warm up to loosen or melt any dried ink that may have blocked the nozzles. If this does not work there may be more serious problems that will require a qualified technician to deal with. Hope this helps and let me know if you need further assistance.
Jul 05, 2008 | HP OfficeJet D125xi InkJet Printer
I have been given a psc 1310, without an instruction manual and without any ink cartridges.The diagram inside the machine shows 5 different numbered cartridges which the machine uses, 27,28,56,57 and 58. I...
Hello.
HP 27 - Black Ink (approx 220 pages)
HP 28 - Color Ink (approx 190 pages)
HP 56 - Black Ink (approx 450 pages)
HP 57 - Color Ink (approx 400 pages)
HP 58 - Photo Ink Cartridge (approx 140 4x6 photo prints)
Hope that helps!
Jun 07, 2008 | HP Office Equipment & Supplies
Can we print with other three Color ink cartridges when Black Ink cartridge is emptied?
hi,
as u have ran out of ink you cant print anymore... you have to replace a new ink cartridge.... this is because when u print something, the colors will get mixed to print the exact color.... even if u are printing only in black, some other colors wil get mixed to produce the black color on the paper... so u need to change the ink cartridge.... u cannot run with a blank filled ink cartridge.... and the selection of your printer is very good...
thanks and regards
agnel
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Lexmark X1190 All-In-One InkJet Printer Logo
88 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
