Question about Kenmore 500 6952 Dryer
Had water in my basement, now the dryer wont turn on. actually it makes a slight buzzing noise. found some corrosion and cleaned it as best i could.
  • 4,323 Answers
Hi
The buzzing noise is due to a shorted wire in motor wire harness or due to a burnt winding on motor. You would need to check and replace the motor if necessary. Please check the below video for replacement/troubleshooting--
You can buy the motor from this link-- Drive motor Kenmore dryer Hope this helps... Please post back if you need more information. Daniel
Posted on Mar 20, 2011
My Dyson D17 Animal vac makes a buzzing noise when the belt turns. I took the belt off and turned the small metal gear that turns the belt. That is what is making the slight noise. My wife vacuumed the...
Try not to **** up any more water. Don't use until you can dry it out well. Hopefully you live in a warm climate so that will happen sooner than later.
Sep 23, 2013 | Vacuums
I have a Kenmore 600 washermachine it won't spin or rinse. It would fill up with water and go all the way through the cycle until it got to the last rinse cycle and just stop and make a buzzing noise...
hi there the first thing ill tell you is that the washer needs to drain water before it can spin there are only a few factors that prohibit this operation a faulty lid switch secound a blown or blocked water pump being a fisher paykel they are famous for jammed water pumps as they decided when they built the sysyem to turn the water pump upside down this causes a lot of stress on the water pump see if you can lay the hose on the ground and get all the water out i belive the machine will then start to spin dry. in this case it is the water pump and have it replaced its a simple operation if you can order the part fromf/p you simply turn the washer on its side depress the white latch next to the pump turn the pump clockwise till ity release from machine disconnect power supply plug and fit new unit as per reverse
best of luck
sonic boom electronics australia
p.s the buzzing noise is the water pump humming because it can not spin the problem is definitly your water pump have it repplaced and it will work fine
please take the time to rank my reply if your happy with it.
Dec 01, 2010 | Kenmore Washing Machines
Bulb has gone out and now makes a loud noise
The noise depending on where it came from may be normal. You wont be sure unless a TV repairman checks the boards to know for sure, or you could replace the bulb and hope for the best.
Jul 19, 2010 | Panasonic PT-56DLX75 56" HDTV
Buzzing noise from dryer and wont start
It sounds like your motor has gone bad....it will buzz really bad when it is trying to start and cannot...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Asker's Testimonial " Thanks so much for your help. Now that you'v mentioned it, the buzzing does sound like it's coming from the motor. I'm,now, more comfortable in call " -
Apr 12, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Whirlpool dryer makes a buzz noise when push
pull motor switch out(the one with wires go in motor) best use compressed air.... lint is stopping lever... this all happens after you turn breakers off...hi hi
Aug 27, 2009 | Whirlpool ET8CHEXSQ Dryer
I have a candy cic60 reverse action condenser dryer about six years old.when it is switched on i makes a buzzing noise and nothing happens apart from the buzzing,any ideas
my candy dryer when on the light keeps come on to clean fliter and the water contain dont seem to being filling up with water
Jul 07, 2009 | Candy CDC266 Dryer
I have an LG TDC70080E condenser tumble dryer. It has worked perfectly for 2.5 years and now is playing up (suprising, considering it is just out of warranty!) There are two issues: 1. The drum is not...
My pump started making a loud noise and stopped pumping, I removed the pump and found that the impeller had moved down the shaft, so I put some locktite on shaft replaced impeller and its fine now
Oct 28, 2008 | Dryers
Dryer problem
You need to listen for the motor working ? Open the dryer door hold the door switch in and start the dryer . A buzzing sound may indicate a bad motor. If you hear a slight spinning noise ,it may just be the belt.
Sep 24, 2008 | Dryers
Whirpool Mod WGD5300SQ0
How much water did you have in the basement? Back in June we had flooding in the area, and the my recommendation to everyone has been to replace any appliance that was under any water.
If the motor was under water, wires or the gas valves, these components will corroded and could cause you future safety concerns.
Jul 26, 2008 | Whirlpool GGQ8831L Gas Dryer
Kenmore 500 6952 Dryer Logo
52 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
