Question about Kenmore HE2 Plus Front Load Washer
The bleach & softer stay in the fill tray - Kenmore HE2 Plus Front Load Washer
    Brigadier General:
  • 6,277 Answers
(try this first!)
I suspect that it is the conditioner/softener tray which needs a thorough clean,
paying particular attention to the sentences in BOLD ;-0)
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of these should enable you remove it
(I am having to guess some of the following!)
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
Good luck,
John C
Posted on Mar 20, 2011
The softer tray will not drain
Front Load Washer Troubleshooting: Clogged Dispenser ...
? 1:13
https://www.youtube.com/watch?v=KqQcyprw8j8
Dec 14, 2009 - Uploaded by ManageMyLife
Can you shed some light on why these aren't draining? ... Thosecompartment will stay filled with water after wash cycle. ...Whirlpool & Kenmore Washer Repair - Fabric Softener is NotDispensing - GHW9400PW1 - Duration: ...
Fabric Softener is Not Dispensing - GHW9400PW1 - YouTube
Nov 28, 2015 | LG WM2240CW Washer
Softener tray won't fill with water; although it fills the bleach side tray just fine. No error codes, just an empty bleach tray but full softener tray.
I suggest there may be hard water mineral deposits in the hose or orifice to the tray. Try soaking it with some Coke (yes I mean the soft drink) overnight and see if the flow improves. Either that or you can try some CLR but Coke should be enough to gently remove any deposits there are in the tray, hose or line.
Dec 02, 2014 | Maytag Neptune MAH5500B Front Load Washer
I have a Lady Kenmore Ultra Fabric Care Heavy Duty 90 series model # 1108281120. The drain for the fabric softner and bleach do not fill up and if you put the softer in it just drains out in the wash....
take out the draw where you fill the fluid to you will find that the fluid has built up into paste and is not letting the small valve to close properly happy cleaning eric
Dec 21, 2017 | Kenmore Washing Machines
After each load the "fill bleach cup" is filled with water. I have to take the whole tray out and flip it up-side-down to empty the water. I cannot find where the thing can be clogged. I can't use bleach...
Bleach & fabric conditioners "syphon away" into machine... try adding 1/2 lt water to the bleach compartment, if it then syphons away your syphon is not blocked. If it does not drain you will need to find the syphon cap - genarally just a tube, most manufacturers will make the tube a different colour to the rest of the draw.
If it did drain when water added you may have issues with bleach not being a part of that particular cycle, delicates for example...
Apr 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water in the bleach dispenser
The bleach dispenser is a syphon system. When you put in the bleach , it fills the reservoir to a point just below the syphon point. Your bleach tray has a tube attached to it, with a loose cap around the tube that causes the bleach to be delivered to the washload when the water is added. Remove the cap over the tube in your bleach tray. You'll also note a similar arrangement for your softener dispenser. Clean both caps and tubes. Make sure that the caps fit properly back down over the tubes. The syphoning effect will work only up to the point that the circuit is broken by air. If your cap sits up too high, the syphon effect is broken early, leaving residue (water) in the dispenser.
Best regards, --W/D--
Aug 09, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Bleach & Softner not dispensing correctly
I finally figured mine out! Remove the dispensing tray then take a small brush, or maybe a q-tip and clean out the small hole right above the softener tray. Mine had mold in it and wouldn't let the water fill the tray, which is what causes the softener to dispense!
Jul 21, 2009 | Whirlpool Washing Machines
My front-loading Kenmore washer's bleach and fabric softer dispenser trays are clogged. Does this entire drawer come out so I can clean?
should be able to pull drawer out completely. pull it out as far as it will go. you should see a little lever you can deprese at right rear to pull drawer all the way out.
Jun 24, 2009 | Washing Machines
Bleach and Fabric softer will not dispense
I had the same problem. I took a sewing pin and stuck it up into the holes at the top and really dug around in there. There was a bunch of slimy gunk in there but works fine now.
Mar 09, 2009 | GE Energy Star WCVH6260F Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
32 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
