Question about Samsung HL-R4667W Rear Projection Television
Hl-r4667w shuts off when warmed up, will shut off more often when hot. No blinking lights. the red ready standby light will be on. First started after tv was on for 5 plus hours and when turned back on would be fine for another hour. Now it starts after a couple hours and when the tv is turned back on it can shut down again in a few minutes. It has a 4 screw rear lamp door but have tried taping lamp door switch down no change.
  • lennon_ccma Mar 20, 2011
    Thanks is it something that can be replaced... is it part of a board...
    yes
    Sergeant:
  • 194 Answers
Heat sink has been damaged
Posted on Mar 20, 2011
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
My Sony wega tv won't turn on goes into standby red light blinks 10 times then shuts off?
Look at the owner manual as the 10 blinks is a error code or Google the model number to locate that information--Sony error codes are general and often misleading.
I would if looking at the set inspect the lamp first.
Aug 28, 2012 | Sony Grand WEGA KDF-42WE655 42" Rear...
On HL 1440 Laser Printer, ready and alarm lights (red) on control panel are lit.
Don't fiddle with it you'll just mess with it more take it in and see what they can do if not i suggest you by a new one.
Nov 28, 2011 | Brother HL 1440 Laser Printer
My lamp burned out and I got the replacecent lamp from samsungparts.com, but the housing didnt fit into the tv. So I put the new lamp in the old housing, after verifying the lamp was the correct part...
According to an aftermarket lamp manufacturer, there are 2 different lamps (1st and 2nd generations) available for the Samsung HL-R4667W, but only one of them will actually fit. The lamp that is commonly associated with this model, BP96-00826A, is used in housing that has a silver bump protruding from the opposite side as the front face of the bulb itself. The other type, BP96-01073A, is placed in a housing that has a smooth back face and a overall larger bulb. I can verify that the HL-R4667W that I own seems to have the second type of lamp.
As long as you didn't open the housing of the lamp that you purchased to try to install the lamp in the housing that your TV came with, you might still be able to request an exchange from samsungparts.com, given the circumstances.
Jan 11, 2011 | Samsung HL-R4667W Rear Projection...
After turning on TV, lamp light blinks but no picture
IF IT SHUTS DOWN TO STANDBY, THEN DIGITAL BAORD IS BAD, IF IT JUST KEEPS CYCLING ON/OFF THEN YOU NEED A POWER SUPPLY, BALLAST AND PROBABLY LAMP
Dec 30, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
My samsung dlp tv intermittently just shuts off...don't know if it is because of the lamp or what
When it shuts down, do the LEDS on the front blink? There are 3 of them. Standby, temp and lamp. Do any combination of the 3 blink when shuting down. I could tell you where to start just by those lights blinking.
Dec 23, 2009 | Samsung DLP HL-P5663W 56" TV
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
Immediately Shuts off with blinking light codes
I suggest doing a google search using the tv model # and brand.
I have learned myself that different big screen tvs seem to each have their own common problems. I have read before of power supply issues that cause what your describing.
Mar 11, 2009 | Samsung HL-R5078W 50" HDTV
Samsung HL-R4667W Rear Projection Television Logo
319 people viewed this question
Jerry Greenberg
Jerry Greenberg
