Question about Cell Phones
Our telephone is the eircom perform 120. it has 4 keys on right hand side in vertical column...MERMORY ,STORE,PRIVACY & REDIAL.......it has 4 buttons along the bottom in a horizintal row.... M1 M2 M3 & RECALL... When a person is talking on the phone & a incoming call comes...how can you put current call on hold & answer the incoming call & then RECALL 1st caller..??? Thanking you for assisat=ance
2 Suggested Answers
  • 5521 Answers
SOURCE: I bought an Emerson cord
Press Store then dial the number (including 1 and the area code) that you want to save. Then press M1 to M3 (if you want to use the one-touch dialing) to store the number. If you want the number to be accessed with two buttons, press Memo and then a digit (0 to 9). These stored numbers will be lost if the batteries are dead or removed for more then 5 minutes.
To dial the number you have stored, press M1 to M3 or press Memo and the appropriate digit.
The manual for the EM2646 is available here: http://southerntelecom.com/emersonsupport/downloads/EM2646.pdf .
I hope this helps.
Posted on Jul 08, 2011
Need to program new phone numbers
The manual is available here: www.uniden.com/pdf/CEZ260om.pdf. If you search google for "uniden cez260 corded phone manual" it is the first result.
You can find the instructions in the fourth column of text under "Storing a Name and Number in Memory"
Here is the text from that section, but I can't promise the copied text is accurate. Check the pdf at that address if anything doesn't work.
1. Press STORE. LOCATION? shows in the display.
2. Press the desired memory location (0 to 9 or quick call buttons A, B, or C.) NOTE: Press LEFT or RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C to select a location.
3. Press STORE again to con? rm the memory location. NOTE: Use Delete to erase existing memories or to correct errors.
4. Use the number keys to enter the telephone number (up to 32 digits) and then press STORE to save. (The unit will not dial a phone number in this mode.) The cursor automatically moves to the text line for name entry.
5. Use the number keys to enter the name of the person associated with the telephone number you just entered. More than one letter is stored in each of the number keys. Press the keys multiple times to scroll through the letters for that key. For example, to enter "B," press "2" twice. Press LEFT two times to create a space. NOTE: The ? ashing cursor automatically moves to the next position or you may press LEFT or RIGHT to move the cursor to the next position.
6. Press STORE to save the name.
7. To enter another name and number in a di erent memory location, return to step 1 and repeat this process.
Storing a Pause in Memory
The REDIAL/PAUSE button has dual functionality and becomes a pause button when pressed in sequence after the STORE button. It is valid only when storing a number into memory locations. Use the REDIAL/PAUSE button to insert a pause when a delay is needed in an automatic dialing sequence (for example, when you must dial a 9 to get an outside line or when you enter codes to access your long distance company).
NOTE: A pause is 3 seconds in length and you can store more than one if a longer pause is needed. Changing a Stored Number Repeat the storage sequence under Storing A Name and Number in Memory, and press DELETE to delete the old number before entering the new number.
Erasing a Stored Name & Number
1. Press STORE.
2. Press the memory location (0 to 9 or quick call buttons A, B, or C) to be erased.
3. Press DELETE.
Copying Caller ID Memories to User Memory
1. Press LEFT or RIGHT to view the caller number and name you want to copy.
2. PressSTORE.
3. Press the memory location (0 to 9 or quick call buttons A, B, or C). The number ? ashes if there is a number already stored in that memory location.
4. Press STORE to enter Edit mode, and then pressSTORE again to edit the name. NOTE: Select a di erent memory location by using LEFT and RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C.
5. Press STORE to con? rm and save. Wait three seconds to exit.
NOTE: If the name you want to enter is longer than 12 characters, only the ? rst 12 characters will be copied into memory.
Storing a Redial Number to Memory
1. Press STORE.
2. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If a number is already stored in the memory location, it will appear on the display. Use LEFT and RIGHT to select a di erent location.
3. PressSTORE again to con? rm.
4. Press REDIAL/PAUSE, and then press STORE again.
5. Enter the name, if necessary, and then press STORE to con? rm.
Copying a Redial Number to Memory
1. Press REDIAL/PAUSE while on-hook. Redial number will display along with PICKUP PHONE.
2. Press STORE.
3. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If there is a number already stored in the memory location, it will appear on the display. Use the RIGHT or LEFT buttons to select a di erent location.
4. Press STORE twice.
5. Enter name, if necessary, and then press STORE again to con? rm and save.
Dialing Numbers Stored in Memory
1. Press DIAL.
2. Press a memory location button or use LEFT or RIGHT to scroll through stored memory locations to ? nd the desired number. The number in that memory location displays.
3. Press SPEAKER or pick up the handset to dial the displayed number.
OR
1. Lift the handset or press SPEAKER.
3. Press DIAL again to dial the stored number.
Jun 11, 2015 | Uniden CEZ260 Corded Phone
Where can I find operating instructions for a Jazz 4400 telephone. I want to change the speed dialing to 10 digit but can't find the original instructions.
Jazz 4400- Programming an Autodial key: 1) Lift handset wait for dial tone 2) Press SAVE key 3) Dial the number you wish to save 4) Press SAVE key again 5) Press the Autodial key that you want to save number to. // Notes: The number can be up to 16 digits. If you need to add a pause (for PBX system) press REDIAL key. //
Jazz 4400 has 10 Autodial keys each can store 2 numbers for a total of 20 saved numbers. Press SHIFT key before Autodial key to access second number. Their is a HOTLINE key to store one frequent or emergency number programmed same as Autodial.
Aug 20, 2014 | Nortel Jazz Plus 4400 Speakerphone -...
Where is the re-dial?
Hi, Hope this helps.
Making a call using the redial list
The last 5 phone numbers dialed are stored in the redial list.
  1. 1 {REDIAL}
  2. 2 Press {^} or {V} to select the desired number.
  3. 3 phone icon.
I have also inserted a link to the manual below: http://service.us.panasonic.com/OPERMANPDF/KXTG5631S.PDF
Hope i have helped, ALAN
Jun 28, 2011 | Panasonic KX-TG5632 Phone
How to fax?
This section describes dialing and sending faxes directly using the Numeric buttons.
note:
  • A PBX (Private Branch Exchange) is an on-site telephone switchboard. If your machine is connected through a PBX or other telephone switching systems, you have to dial the outside line access number first, and then the number of the party you are calling.
Sending a Fax with the Numeric Buttons .
Click here for other useful sending methods.
1. Preparing for sending a fax.(1) Make sure that the power is turned on.
(2) Load a document on the Platen Glass or in the ADF.
important:
  • When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
(3) Press the FAX button.
The fax standby screen will appear.
(4) Adjust the density (scan contrast) or image quality (fax resolution) as necessary.
See "Adjusting the Sending Quality"
2. Sending the fax.
  • When the document was loaded on the Platen Glass:
(1) Use the Numeric buttons to dial the recipient's number.
(2) Press the Color button for color sending, or the Black button for black & white sending.
important:
  • Color sending requires that the recipient's fax machine supports color faxing.
(3) Press the OK button.
The machine starts sending the fax.
note: When loading two or more documents
  • Load the next page, and press the same button as you pressed in (2) of step 2. Repeat the same procedure to scan all pages of the document, and press the OK button.
  • When you have sent the first page with the Black button, the following pages will be sent in black and white.
When the document was loaded in the ADF:
The machine scans the document automatically and starts sending the fax.
important:
note:
  • To cancel sending a fax, press the Stop button, and follow the instructions on the LCD.
  • If documents remain in the ADF after pressing the Stop button during scanning, "Close the feeder cover [OK]Eject the document" will appear on the LCD. Press the OK button so that the remaining document is automatically fed out.
Automatic redialing
  • When sending a fax and the recipient's line is busy, the machine will redial the number after a specified interval. Auto redial is enabled by default. Auto redial can be enabled or disabled by selecting ON or OFF. Select ON to specify the number of redialing in Redial times and redialing interval in Redial interval.
Redialing the Number Dialed with the Numeric Buttons
1.Prepare for sending a fax.
(4) Adjust the image density (scan contrast) or quality (fax resolution) as necessary.
2. Select the telephone number recently dialed.
(1) Press the Redial/Pause button.
Most recently dialed fax number using the Numeric buttons will appear.
(2) Use the g0016984.png (-) or g0008875.png (+) button to select the number to redial.
The selected number will appear in the fax standby screen.
3. Send the fax.
important:
Jun 03, 2011 | Canon PIXMA MX340 Wireless Office...
How to delete chat
follow these steps:
Step 1- Open up skype as then click on "tools" in the top right hand corner.
Step 2 - Select "options"
Step 3 - Choose the "Privacy" icon on the left hand side then click on "Privacy Setttings" from the exanded tab.
Step 4 - Look in right side of the menu about the middle vertically. You can see the option " Keep Chat History for" just select "no history" click save and you are done.
To also delete your old chat history just follow the same steps above then
Step 5 - Click on the form button that says "Clear Chat History"
Click save and you are done.
I hope this helps you all out there. I know privacy is a big concern of mine online and I would not want anyone else snooping in my chat history. Good luck
vote for me
thank you
Nov 16, 2010 | Skype IM
How to specify fax machine to dial '9' before fax number?
Hello ilay,
This procedure is from the Brother FAX-4100e FAQ link:
Storing Speed Dial numbers:
You can store Speed Dial locations on your machine(*). Once you have programmed the Speed Dial number on your machine, you can dial the number by pressing Search/Speed Dial, #(Pound Sign), the Speed Dial number, and then Fax Start.
*The number of locations you can store varies by machines. Please refer to the User's Guide for your machine. The latest User's Guide is available in the Manuals section.
To store Speed Dial numbers follow the steps listed below:
1. Press Menu.
2. Press the left or right arrow key to select Fax and press Set.
3. Press the left or right arrow key to select Set Auto Dial or Set Quick Dial, and press Set.
4. Press the left or right arrow key to select Speed-Dial and press Set.
5. Use the dial pad to enter the location (Speed Dial number) where you wish to store the number and press Set.
6. Enter the number you want to store (up to 20 digits) and press Set.
Note:
If you want to enter a pause in the dialing sequence (to wait for an outside line, for example), press Redial/Pause as you're entering digits. Pressing Redial/Pause enters a 3.5-second pause when the number is dialed, and a dash appears on the screen. If you need a pause longer than 3.5 seconds you can press Redial/Pause as many times as needed.
7. Use the dial pad to enter the name or company name (up to 15 characters) and press Set.
If you want to store the number without a name, just press Set.
8. Return to STEP 5 to store another Speed Dial number or press Stop/Exit to exit the menu.
[Here's the web address for the Brother FAX-4100e FAQ]
http://welcome.solutions.brother.com/BSC/Public/Templates/FaqEndPage.aspx?NRMODE=Published&NRNODEGUID={30FA9470-D303-4B5B-8BDC-89B1CBA491AE}&NRORIGINALURL=%2fBSC%2fpublic%2fus%2fus%2fen%2ffaq%2ffaq%2f000000%2f002000%2f000004%2ffaq002004_010.html%3freg%3dus%26c%3dus%26lang%3den%26prod%3dfax4100_us&NRCACHEHINT=NoModifyGuest&prod=fax4100_us%C2%AE=us&c=us&lang=en#one_7
[Here's a link to the FAX-4100e users guide]
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002079/FAX4100e_UsaEngUsr.pdf
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 10, 2010 | Brother IntelliFax-4100e Fax
3" wide swath no toner laid down
Try replacing the toner cartridge. They will exhibit those symptoms when the toner is low.
Nov 30, 2008 | HP LaserJet 1200 Printer
Jumper pin settings
Hold the samsung SP1203N hard drive in your left hand with the lable facing upwards (then power cable connectors will be on your right hand side and the IDE cable connector will be on your left ahnd side). There are two raws of jumper pins in between the above two connectors
Master - join the first two column of pins on the left with a vertical jumper
Slave - leave all pins free (without jumpers)
Cable Select - join the third column of pins from the left with a vertical jumper
job done !!
Udai De Silva
Oct 16, 2008 | Samsung (SP1203N) 120 GB Hard Drive
Ge corded telephone 29438B
1 - Press the STORE/IN button on the right hand side (middle of phone)
2 - Enter the number you want to store.
3 - Press the STORE/IN button again
4 - Press the button for the location you want to store the number at.
Mar 22, 2008 | GE Telephone
Speed dialing
· Without lifting the handset, press redial button. Press the button on the strip you wish to store the telephone number on. Note that these 5 buttons are position numbers are 100, 101, 102, 103 and 104. 100 is the first button above EXT PICKUP, and 104 is the first button below DND. These numbers can also be programmed using the method in Step 2 below and entering the position number (100 – 104).
· Enter the telephone number. Be sure to program the 9 in front of all local numbers, and 9+1+(Area Code) in front of long distance numbers.
· Press redial.
· To use the numbers stored on these buttons, lift the handset and press the button.
Oct 29, 2007 | Toshiba DKT-2010 Corded Phone
Cell Phones Logo
326 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
