Question about Delta Faucet 470-DST Signature Diamond Pull-Out Spray Kitchen Faucet - Blac
Replaced spray hose on pull-out delta faucet for kitchen sink. Still leaking at quick connect site. Proper o-ring placement and proper quick connect placement is my question. I get no resistance when I put quick connect hose on pipe fitting. HELP!
arealplumber
  • 33 Answers
SOURCE: Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Posted on Dec 05, 2008
arealplumber
  • 33 Answers
SOURCE: low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
arealplumber
  • 33 Answers
SOURCE: delta kitchen faucet mixed spray...diverter problem???
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
Posted on Dec 09, 2008
  • 2692 Answers
SOURCE: Delta single handle kitchen sink faucet
Tuen the stops off unsder the sink . Remove the alaen screw from the handle. Using a spanner wrinch or a needle nosed pliers spred apart unscrew the large nut that has two slots. Lift the whole assembly out. Take assembly to the plunmbign supply and match ius the kit that youy need with has two new rubber seals and two springs and maybe a new spanner nut. It also comes with the spanner wrench  and allen wrench  needed to renstall. Tip you may be able just to tighten the spanner nut(clockwise) and stop the leak w/o rebuilding it.
Posted on Apr 25, 2009
SOURCE: water pooling at base of delta waterfall faucet spout
I have the same problem. The part that is needed is found with a simple Google search for "Delta Waterfall RP22934 O-Rings"
Simply Slide the collar up at the base of the spout where it swivels.
Gently open the now exposed split plastic retainer so that the tabs near the bottom are pulled from their holes.
Lift the spout off the base to expose the o-rings.
Replace with the new o-rings and apply o-ring grease.
Re-assemble and enjoy a dry sink area.
Posted on May 23, 2009
Remove delta quick connect hose
pull the black plastic piece down. you should hear a click. then gently pull the hose out. no matter what , BE GENTLE. Those things do seat very well but you have to be careful on removing them. Installing is easy, just a push in until it locks.
Nov 09, 2013 | Delta 2402 Classic Single Handle Kitchen...
There is a leak where the spray arm connects to the water faucet under the sink. The connection is a snap connection rather than a screw on type.
With this type of faucet when you push the 2 pieces together there should be a small rubber O ring, if this is not in the correct position there won't be a proper seal. If you have some vasalien rub it on the O ring and it should help it fit better, it also should click when you push it together.
Mar 16, 2013 | Moen Monticello Single-Handle Kitchen...
I think our Signature faucet is leaking through the metal pull out coil. It is intermitten. Can a replacement coil be purchased. I'm not sure if this is the real problem though. It is leaking under the...
these are really well designed.take a flashlight and go under and look up.most leaks come from stop valves.if the hose is leaking,you can change o rings.oooooor you might have a bad hose.delta will be happy to replace it. I've found there customer service easy to deal with.
Jan 29, 2011 | Delta Faucet Delta 470-BL-DST Signature...
My delta kitchen faucet model 21902 quick connect spray hose leaks where it connects to the faucet. Help
Is there a little rubber O-ring that may need replacing or is missing? You might try removing and flushing out the line and replacing it.
Dec 03, 2010 | Plumbing
The O rings need to be replace, but you can not get the handle off because if the hose. How do you disconnect the hose so you can remove the handle.
handle should have an allen screw rite under the handle coverd by a little cap mite have red and blue..shouldnt have to take hose off but that just snaps off from under sink.
Nov 21, 2010 | Delta Faucet Delta 470-BL-DST Signature...
We have a Delta kitchen faucet with a pullout sprayer everything was fine for over a year then it started making a bang bang rattle sound very loud only when the hot water is on it only does it about ever...
Delta comes with a limited lifetime warranty. call them to get free parts. I believe you will need to check several things. Remove the spray head from the sprayer hose, point the hose into the sink drain and turn the faucet on. If it no longer makes the banging noise, replace the spray head. You need to look for a leaking spray hose under the sink also. If the faucet is making noise, replace the ball and cam assembly under the faucet handle. One other thing that I have run into is that the shut-off valves under the sink can also go bad and cause banging and vibration.
Sep 06, 2010 | Delta Model 470: Signature Kitchen...
My grohe kitchen faucet hose won't retract
the first thing you need to check is the weight on the hose under your sink. if it is set too high or to low it doesnt allow the proper weight to pull the hose back into position. also check to see if the hose is twisted under your sink also. I hope these answers will help you out.
Apr 03, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Delta kitchen faucet mixed spray...diverter problem???
Delta Faucets
Dec 07, 2008 | Delta 473-WHSD-DST Saxony Diamond Seal...
Delta Faucet 470-DST Signature Diamond Pull-Out Spray Kitchen Faucet - Blac Logo
286 people viewed this question
Top Delta Faucet Plumbing Experts
Steve Wood Plumbing...
Level 1 Expert
joeiaaz
Level 1 Expert
doconnell13
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
