Question about Watches
How do you change the time on an eddie bower model 220 stop watch
I have an application whereby I want to glue a magnet to the back of the watch and attach it to a metal shroud. I need to remove it and reattach it to the shroud several times a day. Will the operation...
Generally an LCD watch is not affected by magnetism. A mechanical or quartz watch will be effected. My advice is to set a magnet on the watch and see what happens. A mechanical and quartz(or any watch with analog hands) will stop. Michael
May 24, 2011 | Sportline 220 Sport Timer Stopwatch ...
I have the timex 1440 wr50m radio control watch. I changed the time zone when I went on a trip and now I can't set it back to where it was. The manuals online are for newer watches, I guess, they have 6...
Good day Sir, This model (WR50M) has four buttons, from left to right, top to bottom: 1) Set; 2) Start/Stop; 3) Mode; and 4) Indiglo.
To set or change the time:
1.Press and hold Set and Start/Stop simultaneously; the seconds will start to blink
2.Release both buttons
Use Mode button to toggle through to Hours, Minutes, etc.
3.When desired number (such as Hours/Minutes) starts to blink, use Start/Stop button to change number
4.When done, hit Set
have a nice day.
Oct 15, 2009 | Timex 1440 Nylon watch
Eddie bauer watch runs slow
This usually means the battery is dying. Usually the backs on these are very tight, and the back has to be taken off to replace the battery. You might be able to get the back off without damaging the watch, but you probably will not get it back on without breaking the crystal. Best thing to do is take it to a reputable watch repair place or jewelry shop and have them replace the battery for you. Before they begin, make sure they are willing to replace the crystal for free for you if they break it!
Aug 06, 2009 | Watches
Eddie bauer ibeam watch
If your watch is the same as mine, push the mode button 4 times, which will put you in the alarm menu (AL 1). Then, push the ST/STOP button until "chime" disappears.
Jan 25, 2009 | Bulova Watch
Get the back off my eddie bauer watch
when you look at the back are there three small rectangular indents evenly spaced on the edge on the back? If so you'll need a special tool for opening waterproof watches. the tool adjusts to fit the three indents then press down as you turn counterclockwise. you can find the tool on amazon.com or your local jewelry store. make sure the gasket is in place and not damaged before screwing the back on.
here is a link to the tool
http://www.amazon.com/Pavilion-Professional-Waterproof-Adjustments-Caseback/dp/B000K3SK0Y
Jan 16, 2009 | Timex Expedition 84601 Wristwatch
Can't turn off alarm
press mode four times until you get to the alarm screen (on mine it is four), then press start/stop to cycle through turn the alarm on, chime on, alarm off, chime off
Dec 26, 2008 | Watches
Can't set time on my Eddie Bauer watch
Nothing on the net, so, you will have to go back to the store.
Sorry....
Dec 20, 2008 | Watches
Eddie Bauer watch.
these watches are waterproof so the stem is screwed down to seal out water. Try turning the stem to unscrew it somewhat , then pull out the stem to set.
Jan 05, 2008 | Watches
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
  1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
  2. Press ADJUST to set SECONDS to zero.
  3. Press START/STOP to select MINUTES.
  4. Press ADJUST to change.
  5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
  6. Press MODE when done.
  7. To display DATE from Time display , press START/STOP.
  8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
  9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
  1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
  2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
  4. Press ADJUST to change.. Press MODE when done.
  5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
  1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
  2. With time displayed, press MODE to select Chrono Mode.
  3. Press START/STOP to start.
  4. Press ADJUST to view lap time. Press again to sesume lap timing.
  5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
  6. Repeat for successive laps.
Have fun! - Not a bad watch for the money! - - Silver Bullet
Mar 16, 2007 | Timex 5B841 Wristwatch
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
