Question about HP Pavilion 533w (P9859AR#ABA) PC Desktop
Ok when i turn on my aoc monitor colors like blue green red white pop up i can never use my desktop
    Master:
  • 389 Answers
I would suggest that you try another monitor. If the monitor continues to light up with these colors and you do not see your computer desktop, then I would tend to think that your computer may have a problem with the video card or driver. Do you get a message on your montor with words like "no connection" or "No signal". If so, this means that the monitor is getting no video signal from you desktop. Try disconnecting your monitor plug and removing power from the monitor in an attempt to reset the monitor. Try also to turn off and unplug your computer. Leave the computer unplugged for about 10 minutes and start it up again. This may reset your computer. If you monitor video cable will disconnect from the monitor, you may want to get a new cable. These cable do go bad sometimes and are available and inexpensive on Ebay.com
Try these ideas and let me know how you do.
If you found this answer helpful, please remember to leave positive feedback. If you need more assistance, let me know.
Thank You,
Brian
Posted on Mar 20, 2011
  • forgivennuke Mar 20, 2011
    Ok thanks but i tried to put the cable into my laptop and it works fine. i believe its my comps fault
    because if i plug the cable into comp then colors pop up.. but if i put in laptop it works fine
Turned on computer today and my screen is blue green, does not change using monitor buttons?
Sounds like you are using an analog standard VGA cable interface. Since the menu has the correct coloring, it is not the monitors fault. Check the connections of the video cable at each end to ensure they are tight and not kinked. If they are ok, try using a different video cable. If thew problem still exists after that, it is probably the video card in the computer.
Apr 11, 2015 | AOC Computers & Internet
Packard Bell monitor showing colors
Replace the monitor, is dead.
Aug 04, 2012 | Computers & Internet
My dell inspiron 530 shows a block with red, white, green, and read, can't get to the my programs????
That "red white green and blue" block is a color pattern tester. that means the monitor is on, but is not receiving a signal, so its running tests. If your monitor has Digital input and VGA input, you may just need to switch inputs. Look for 1 or VGA if youre using the blue hook up. look for 2 or digital or dvi if youre using the larger white hook up. Some monitors also have 'auto detect'. If you are in "auto detect' bbut the color box is still there, then your monitor is not receiving video signal from the computer. It could indicate a bad cable or no signal being sent by the machine. If you try another monitor, you can see if the machine is working. I would try a monitor setting for VGA-1 first, since thats most common.
Jun 25, 2010 | Dell Inspiron 530 Desktop Computer
I have an Envision AOC 32 tv monitor and want to hook my WII up to it, It has yellow white and red wires. The back of the monitor has HMDI, PC Cable, and coax connectors. It also has speaker out puts and...
Yellow Is VIDEO, Red & White is your AUDIO. (Stereo). They should go color to color on the TV's AV input. This is AV, and you use 3 wires to connect this way.
The Red, Green, & Blue, is called COMPONENT, & is ONLY VIDEO, the AUDIO, still must use Red & White. So to connect with Component you use 5 wires, altogether, 3 for Video, 2 for Audio.
Plug them in color to color & choose the right INPUT on the TV, and turn on your input device.
Feb 26, 2010 | Envision L32W761 32 in. LCD TV
AOC LM725 Color Cycle
AOC brand are disposable, now if your going repair its chips, its definitely work or not... i tell you this monitor is very deliquate to work normally.... buy a new one...
Jun 16, 2009 | AOC LM729 17" LCD Monitor
Dell flat screen goes white and colored block appears and floats
Check that your monitor is connected properly and tightly to the computer. If it is, then the monitor may be bad. Borrow a friend's monitor and try to see if it works, if someone else's monitor works, then replace your monitor.
Mar 11, 2009 | Dell gx 150 p3...
Aoc LCD monitor problem
If some of the pins inside the monitor cable are bent or broken you can losr primary colors and cause this. Check them. If they seem OK try reseating both ends of the cable. If no go, then try the monitor of a differnt computer to see wether its the videocard or the monitor thats defective.
Jan 06, 2009 | AOC LM729 17" LCD Monitor
Crt monitor video chroma processing
first you check the signal cable continuty by multimeter then correct it if faulty .if ok then give -ve click at red cathode on crt base in on condition if red raster comes on screen then red cathode is ok same thing for green and blue cathode if green cathode do not shows green raster after -ve click then crt is faulty then give -ve click at R point at color raster ic which has heat sink if red color comes then ic is ok same thing for green and blue if ic is faulty then replace it if not then check bipolar capacitor if faulty then replace it
Sep 15, 2008 | AOC CT720G 17" CRT Monitor
RADIO INSTALLING
there is a code for color!? ok, wait im searching...
found it! here you go, hope it helps...
Wiring color codes are the identification colors that color the wires in your automobile. For example, if you have a British car the blue, blue and white , and blue and red wires are for the headlights. The red and white wires are for the instrument lights, and the green and white and green and red wires are for the turn lights. The color code simply identifies what that wire does. Could you imagine if all of the wires were the same color. You couldn't identify anything in a harness.
Jun 19, 2008 | 2001 Chevrolet Tahoe
HP Pavilion 533w (P9859AR#ABA) PC Desktop Logo
141 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
