Question about Sharp EL9900 Graphic Calculator
My sharp el 9900 wont turn on even when i have replaced the batteries, any ideas?
2 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: Sharp EL-9900 wont start after
when you said it suddenly died, do you means after putting in new batteries,it did not turn on at all? If yes, below are some reasons for this problem;
Check the batter seat. I mean the position where the battery stays, look if you will find any rust of the battery terminal (metal). Rust can prevent the battery from contacting the unit, preventing it from receiving power. Get a flat screw driver, scratch the rust off, fix the battery back in and try again.
If there is no rust, then there is probably some disconnection inside the unit. This can be between the battery terminal and the board. Get a screw driver and remove all the screw. Take the unit apart and check for any lose contact between the battery terminal and the board.
I hope the above makes sense to you.......
Regards.
Posted on Apr 14, 2011
Need instruction book for EL 6710S
Initially, pls try here for the EL-6750, a slightly newer version..
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 18, 2008 | Sharp Computers & Internet
Batteries are dead
Contact your nearest SHARP outlet or SHARP office and they will replace the batteries for you.
Feb 25, 2014 | Sharp el-531x scientific calculator
Wet blackberry bold 9900 and flashlight wont turn off
Well first you went wrong by plugging it in, honestly your best bet now is to put it in a package of rice to soak up all the water and hopefully it works from there. Although I hope someone can give you some better advice.
Jul 12, 2012 | RIM BlackBerry Bold 9900 Cell Phone
Sharp EL-9900 wont start after replacing batteries.
Regards.
Apr 11, 2011 | Sharp EL9900 Graphic Calculator
When turn on Sharp EL1701c just appear: "P". Error
Hi, If you are running this on battery power (Not an adapter) then the P stands for power, once you replace the batteries it should work fine.
Feb 22, 2011 | Sharp EL-1701C Calculator
The calculator is intermittent: Most of the time
Not knowing what to do, I tried anything that could possibly help:
I installed fresh batteries and I pushed the reset button on the back of the calculator (Sharp EL-546L) and finally, it work all right after more than 5 years I own the calculator and where it did work correctly for 5 minutes. I tried the reset button in the past (long time ago) and it didn't work. This time it worked because, maybe, I've used fresh batteries.
Marcello
Jun 03, 2009 | Sharp EL-738 Scientific Calculator
Sharp EL 531w . the calculator doesn't turn on.
Press the reset button on the back. If that does not work, batteries may be dead. Once you replace them press [ON/C].
Hope it helps.
Apr 15, 2009 | Sharp EL-531VB Calculator
Sharp EL9900 Graphic Calculator Logo
257 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
