Question about Plumbing
Mercury outboard 9.9 4 stroke. replacing the water pump impeller does or should the kit come with washers for either side of the impeller and are they of a nylon type or soft steel washer. It shows this on a parts diagram that a friend showed me.
    Master:
    Sergeant:
  • 411 Answers
Now a days you have to buy the washers where you bought the impeller ya there only a dime but they will cost you big
Posted on Mar 20, 2011
NEED IMPELLER KIT PART # FOR 2.5 LITRE V6 2 STROKE SERIAL NUMBER OD145403
available from any merc outboard service shop
if there is none close , the kit may be generic so mariner pump may fit
talk with outboard shop spares
Nov 15, 2017 | Boating
Mercury outboard problems
Is this a two stroke?-If it is you most likely have a primary seal going bad (crankcase seal on the ignition side will lean it out,leaking seal on the other-side of assembly will do just what your describing)Hope this helps you out.....
Aug 07, 2014 | Mercury 4-Stroke 3.5 HP Outboard, Manual,...
Mercury 9.9 outboard 2 stroke Serial number OD127396
by removing the connecting bolts and shift rod connector
May 30, 2014 | Boating
2000 Mercury 115 ELPTO impeller replacement. The Quicksilver replacement kit comes with various washers / face seal. The water pump housing didn't have a seal on top of the old one. Am I supposed to use...
if you mean a large flat sided 'O' ring then this is to help keep water in the impellor housing !? some housings have gaskets between the base plate and housing , check the impellor in the housing and see if it stands proud as then you need the gasket ! compare with the old one as it mite have been forgotten !! check the seal and tube for the water pipe also ok!
Sep 23, 2013 | MERCURY / QUICKSILVER Mercury/Quicksilver...
1982 55 yamaha outboard ,water not coming out the water pump hole in strenght
First thing to check: Disconnect the tiny hose between the check outlet and the engine. Disconnect it at the engine side.
With an airgun, blow in the check hole from outside to engine side.
With an airgun, blow out the engine connection.
Start the engine, check waterflow out of the engine connector. If water, reconnect the hose and check the water at the checkpoint.
If still no water at the engine connection: replace the impeller!
Mar 28, 2013 | Clymer Marine Maintenance and Repair...
Water pump not working on Johnson 3.3 outboard 2 stroke.
sounds like you need a new water pump impeller.
to access the impeller the bottom of the motor needs to be unbolted and the impeller is fitted to the shaft, it is keyed so it only goes on one way. ( impeller kits will come with new gaskets,grease.O-rings and a new key ). re-bolt the lower unit and test.
c...
Jan 01, 2011 | Sport & Outdoor - Others
Mercury 20Hp impeller/water pump location
It is located inside the lower unit housing. They are fairly easy to replace. Most Mercury authorized service stations will charge around $120 for this task.
Triton72
Mar 26, 2009 | Sport & Outdoor - Others
Need oil change in water
If its a 2 stroke, there is no oil to change, if its a 4 stroke, you can pump the oil out with a small diameter tube pump.Depending on the motor, you can get it through the dipstick or the fill opening. If you need to change the gear oil, there is no way to change it while in the water. Stop by a marine supply store and get some oil absorbsion pads (diapers) in case you happen to spill any oil into the water
Mar 11, 2009 | Light Outboard Motor Boat Bass Fishing...
Plumbing Logo
488 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
