Question about Smart Modular SV3170A
Why wont myhp lcd monitor come on after checking the memory sticks i will turn on then display no vga input
  • 27 Answers
If your monitor is showing no vga input, here are a few things to check.
1. Verify that you are using a vga cable. HERE
2. Make sure the connections are tight on both the monitor and your video card.
3. Verify that your video card is securely inserted into your motherboard.
4. If you have both onboard vga and a vga video card, try switching the cord to the other.
I hope this helps. Any feed back you can give me about what happens when you try these, i will look over and try and help some more.
Posted on Mar 20, 2011
How do i fix when i hook up hdmi cord and the screen wont display and when i hook up vga it does but i want hdmi for my ps3?
You must have to make setting in your ps3 and Display device. Set the display device at auto option for input source. It may be set at VGA. that why you get output of VGA but it does not display output from ps3
Mar 30, 2015 | Hannspree HF199H 19 Flat Screen LCD...
No signal when i used vga monitor connector to pc, no problem in dvi
Michael,
I have both ASUS and LG monitors with multiple input choices. On both, when the monitor is turned on, it remembers the last input source. Both monitors (and presumably yours, as well) have an INPUT selection in their SETUP MENU.
So, I'm suggesting you search your monitor for an INPUT selection option, then choose "VGA" rather than DVI / HDMI / AV / COMPONENT / CABLE / ANTENNA, etc.
Hope this helps.
Sep 02, 2014 | Acer Computers & Internet
I want to connect my dell inspiron 1525 to my lcd hd ready tv but have no idea how to? Does anyone have any advice?
The 1525has a a hdmi port which you can plug a hdmi cord into. This may not support the audio. the tv and pc should detect the new monitor automatically or you may have to toggle it by hitting F4 key.
Apr 22, 2011 | Dell Computers & Internet
I have a dell dimension 3000, bought a new HP 2310E monitor with 3 ports. DVI, HDMI & display port. Told to buy a cable with VGA to connect to dell and DVI to connect to HP Monitor display port....
Hi sshorne9780,
I see that you are having a check input error on the Monitor/LCD that your are connecting to your Dell tower, please see steps below.
  • On your HP 2310E make sure that your HP is set to the input/source that you are using and make sure that you only use one type of video cable for the issue.
  • I see that you mentioned that you have a VGA cable and a DVI cable, you can only use one type of cable for a video connection.
  • VGA would be the Blue tipped cable connecting to the tower and going to the LCD monitor.
  • DVI this is a black cable connecting to a white port much bigger than a VGA port and is rectangular in shape unlike the VGA
  • and on your LCD monitor check the input type to see video from the tower.
  • everything seems to be OK you just need to change the input of your LCD monitor for the video to show up on the screen.
  • also if you are using HDMI for the video u will need to change the setting of your Audio and set HDMI as the Default to have Audio come out from the HDMI connection together with video, the HDMI viedo will automatically be detected as long as the LCD monitor's input is set to HDMI.
I hope that this will able to help resolve your concern.
Thank you for choosing Fixya,
mvincentc
Apr 18, 2011 | Dell Dimension 3000 PC Desktop
Samsung syncmaster 2033sw monitor, till now i was using a vga cable for the display, but recently i bought a dvi cable and connected it. but its not detecting the display of dvi cable. if i remove the vga...
LCD Monitors having multiple inputs have option and option to select and switch between the displays from analog (VGA) or Digital (DVI) inputs. Go to the LCD menu and select input source (DVI)
Hope this helps!
CreativeTECH
Nov 15, 2010 | Samsung Syncmaster 2033SW Monitor
When I switch my 22'' lcd monitor on it displays a message '' disconnected '', I have just bought it secondhand.
The message "disconnected" shows that the LCD not receiving signals from the input source.
Verify that the source is working properly.
If you are using this LCD as a PC monitor, connect it to the PC's VGA out via a VGA cable. Make sure that your PC's display output is working (are you able to use another monitor?).
Also try using another VGA cable to check if your old one is faulty.
After making appropriate connections, turn your LCD off and then back on after 10 seconds.
If your problem is still unsolved, it may be a sign of a faulty component inside the LCD but the chances are rare.
Nov 03, 2009 | Computers & Internet
Worked fine now no display
one of few possibilities, either no input form video card (possible bad video card), or loose video cord. or on flat video cards, you can choose from the menu to use digital signal or analog signal, if you have chosen what u do not have , u might have gotten that result.
Jun 17, 2009 | Acer AL2017 20" LCD Monitor
VGA input not displaying
Hi, insert the monitor driver of screen on swicth reinstall driver in order to detect screen.
Jan 17, 2008 | Samsung SyncMaster 713BM 17" LCD Monitor
Display input
You have to make sure the dvi connection is turned on.
Jan 03, 2008 | LG Flatron L1810B 18.1" LCD Monitor
Smart Modular SV3170A Logo
35 people viewed this question
Top Smart Modular Computers & Internet Experts
Stan Skaggs
Stan Skaggs
Are you a Smart Modular Computer and Internet Expert? Answer questions, earn points and help others
