Question about Sony Televison & Video
Hi, i bought a KV-HP212M83 4 years back. 1 year back, due to some over voltage in the line,the circuit board burnt away.since then we have been searching for its board and didnt get anywhere.its really sad that such a cool and good TV sitting idle at home ! It would be so kind of you to help us find the board of our TV and make it functional again.Patiently waiting for your reply. regards Anees Kurikkal +919946816899
  • Sony Master
  • 1,229 Answers
Call Union Electronics at 1 800 648 6657. Be sure you have your TV model# and the board you are looking for. The other place is Andrews Electronics at 1 800 274 4666. These are professional services. I have used these services to replace boards, that were over my head in repair. Hope this helps, thanks for asking and show a few hands of support!
Posted on Mar 20, 2011
  • Sony Master
  • 6,771 Answers
Unfortunately Sony does not provide a board replacement anymore, your only option is to check tv repair shops to see if they even have used working board, "long shot" even flee markets hold surprises. But! maybe a well placed add nation wide may give you the edge you are looking for.
No LED light?
check voltage from wall then transformer voltage
Apr 24, 2012 | Pentair Control Board - 42002-0007s
9 blinks on standby LED
Hi Baddragon,
I do not want to get in between you and Besee. however, since you are thinking of Throwing in the towel. I suggest you think of stepping back from component level repair on Circuit baords, and think about going to PC board level troubleshooting. This is easier, more expensive, and your more apt to succeed.  It is very tedious working with Surface mount components. Basically overly time consuming.
We can get the circuit boards you need from www.partstore.com
 Just get the part numbers from the Circuit boards you have been soldering on.   You may want the challenge of component level repair.  You did say your staying away from surface mount components, a new circuit board solves that problem.   I hope this helps you.
Oct 13, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
When we turn tv on,it will click right off,and shows a stand by timer light. what could be wrong with this? My tv is 10 years old
Hi. I see this type of problem alot, and this seems to always be the problem.
The vast majority of these are due to capacitors either built itno the power supply, or on the main circuit board.
These capacitors work like a booster battery, giving a sudden charge of electricity all at once, that way it energizes the t.v..
These capacitors seem tro be failing alot, probably due to the fact that alot are manufactured in countries where quality standards aren't what they would be if they had been made here in the U.S.
Good quality capacitors should last around 30 years or so, before failure, however, alot of the are only lasting around 1/3 of that time.
Some are only lasting a couple of years, some are lasting 8-10, but all of them are not lasting to their life expectancy.
I would look at your circuit boards, and look for swollen or exploded capacitors.
If they are exploded, they will look like an exploded battery, where it splits down the side.
This is most likely the condition here.
As for repairing, good quality capacitors are not cheap, and can be the difference between getting it repaired and just buying a new t.v.
I hope this is what you were wanting to know.
Jan 31, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
TV was unplugged for 1 year and when it's plugged
if u quit using a tv for along its l.o.t(line output trasformer) will become faulty.. u must replace lot& line oo/p trasistor also
Mar 14, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Panasonic 32" tube television that is only 6 years old (Model CT-32D31) that we bought from Sears. We suddenly have nothing but a horizontal white line across the screen, which "grows" into a...
Sounds like 'bad' or 'dry' capacitors in the vertical deflection circuit. Please note that leaving the white line on the screen too long can burn in the screen, which is permanent damage.
Jan 31, 2018 | Panasonic CT-32D31 32" TV
Blows main fuse. Found burnt place on circuit board where connection 1 is. It's the board that's mounted to the heat sink with fan at the back. Disconnected connector 3 that goes to con 1. Now fuse does...
Chances are a power transistor has shorted. Sometimes input rectifier diodes short or electrolytic caps.
Here is a hint to troubleshoot this: Connect a 150 watt lamp in series with the hot side of the power line to the amp. This will limit the current (and voltage) and prevent the fuse from blowing. You can do a lot of troubleshooting at the much reduced voltage.
If board is burnt to carbon, this "cancer" needs to be cut out and removed as the blackened board is slightly conducive instead of an insulator. Often a circuit trace has fried the board. One must install jumpers around ones that have smoked.
Sep 24, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
No Power Problem with KV-27s15 Sony TV
Barry, remove the back cover by removing the screws with an arrow next to them. The fuse is located on the left side as viewed from the back, where the power cord connects to the circuit board.
Aug 09, 2009 | Sony KV-27S15 27" TV
Could this hard drive have failed plain due to long period of disuse?
Generally drives can be left sitting for a year or more without problems but if it was bumped or jarred hard enough the heads may not be releasing from the park position, otherwise clicking sounds usually mean problems with the circuit board. If you give it a visual inspection(requires removal with a torques 5 or torques 8 bit) you can look for any signs of a burnt out circuit.
Respond back on this post if you have any further questions.
Chris
May 08, 2009 | Western Digital Caviar SE WD1600AAJS 160...
Green screen and distorted picture sound is good but no picture
It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
Have it service by a qualified person.
Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Experience
So you don't have experience of tv repair. I would recommend you to get help of local repair shop or find a friend who has knowledge of electronics.
You need KV-36FS120 service manual, tools like volt meter to test voltage etc, knowledge of parts recognition, must know good solder work to replace defective parts what ever found in tv, must know and recognize high voltage area in tv etc.
what do you think now, let me know.
Oct 11, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
