Question about Garden
How to adjust tension on speedaire hose reel model 2z864b
Simple, take off the hose and wind up the reel to the desired tension, replace hose and your good to go!
Posted on Aug 01, 2013
My hozelock auto reel has stopped locking. Have tried pulling it all the way out and then releasing but it does not solve the problem.
40 meter Hozelock auto reel would not lock when winding back into the drum.
1, Make sure the Hozelock hose has fully retracted into the drum.there should be no tension on the hose reel spring.
2, Use a Black & Decker Workmate.
3, Carefully opened the side cover taking out all of the Torx screws (10 in total) remove handle.
4, Turned the reel over and placed the auto reel onto the Black & Decker Workmate.
5, Placed a socket into the Workmate vice then line up the centre shaft bolt on the auto reel onto the socket, this will hold the steel spring in place so that I could undo the 2 security Torx screws. Slowly remove the 2 screws- there will be a little spring tension when removing the 2 screws, take care.
6, Lever up the centre shaft up out of the reel to expose the internal hose reel, take note the rotation of the plastic cog inside the cover.
7, Remove the brake locking arm from the side cover.
the arm had broken in half, I used a soldering iron to weld the two halves of the brake lever back together.
8, Rebuild in reverse order.
8, When rebuilding the auto reel use the ratchet and socket to tension the steel spring, I unwound the hose out of the drum then slowly wound the spring using the ratchet and socket. This wound in the hose onto the drum up to the hose stop then a couple more turns on the ratchet for a little more tension.
9, Whilst holding the ratchet keeping the tension on the spring. Replace the 2 security screws on the centre shaft .
10, This link on Youtube I found very helpful (46 sec into video) you can see the internal working and the brake lever.
Apr 24, 2015 | Hozelock 2490 Auto Reel 20m Hose 12.5mm
How can I set the drag on a shimano R 2000 spinning reel
The letter "R" on a Shimano reel typically indicates it has a rear drag.
you should find a know on the bottom end of your reel that allows you to adjust drag tension. Just Remember to back off or loosen your drag when not using your reel to keep your drag in proper working condition.
Dec 06, 2014 | Fishing
Thread is bunching up in bottom.
It sounds like you have no tension on the bottom bobbin reel. Did you check your tension on the bobbin reel. The tension must be right on both sides. When pulling on the cotton when the reel is in its bobbin case you need to feel a little resistance. Adjust the tiny srew on the bobbin case to tighten the reel to avoid it to turn in the casing.
Jan 11, 2014 | Brother PE770 Computerized Sewing Machine
How do I fix Frontgate retractable hose reel
If the problem with your Frontgate retractable how is that it simply won't retract, on the assumption that the hose hasn't gotten off the coiling wheel and become tangled, and that there isn't a problem with the hose distributor - which runs off a rubber drive belt, or some other mechanical problem, it is possible to re-tension the spring on a retractable hose.
The principle of these retractable hoses is similar to the energy that is stored in the spring when you pull the starting cord on your lawn mower - which then retracts the cord when you release the pull handle. With the hose completely recoiled, using the blade of a screw driver, you can pry off the triangular cover on the left-hand side of the unit. You'll note four Phillips head screws which secure the round, black, plastic plate to the body of the caddy. If the tension is already "out" of the spring you can remove these screws and nothing will happen. If there is some residual tension remaining, the plastic plate may rotate clockwise a couple of turns when the last screw is removed (it won't spin like an airplane propeller, so don't worry . . .).
To re-tension the spring, I used a crescent wrench and opened the jaws so that the width matched the gap between the two slots you'll see in the plastic plate, and inserted the wrench into the two slots (the wrench will be at a right angle to the plate, at this point. Then, while holding the crescent wrench in place, I used a metal bar, and inserted it through the hole at the other end of the wrench (for better leverage), and turned the plastic plate counter-clockwise five full turns. Then, while keeping the tension on the plastic plate, re-insert all four Phillips head screws, and fully re-secured the plastic plate.
If the inner spring isn't damaged, this should restore the tensioning to the hose reel, as the spring will be further tensioned then automatically, as the hose is uncoiled - which will then be the stored energy that recoils the hose.
Chris D.
Severn MD
Sep 13, 2013 | Frontgate Retractable Hose Reel Post -...
Lost return tension when replacing hose
Where can I get a replacement tension spring for my auto reel hoselock 2490 ? I have tried everywhere but without success. Any help is much appreciated
Mar 19, 2012 | Hozelock 2490 Auto Reel 20m Hose 12.5mm
The bobbin thread keeps breaking! It is very loose and then snaps?? I've replaced the needle to make sure it was sharp, I bought the highest grade thread I could find, adjusted the tension... then...
Sounds more like the way the bobbin has been wound, is it loose and uneven or tight and smooth. Is it properly into the tension spring? being loose doesn't sound right, a thread under correct bobbin tension is usually pretty firm.
Is it loaded into the bobbin holder the right way ?
Also check the bobbin itself hasn't been damaged in some way, not worn/bent. It needs to turn smoothly in the bobbin holder so if one edge has been bent a little this will cause problems.
When winding bobbins, you must have tension on the thread so it winds smoothly with consistent tension on the thread. Most machines have a little tension disc on top or the thread goes through the regular tensioner in order to achieve this. But I always wind bobbins at about 3/4 speed and also add a little extra tension by holding my scissors handle on top of the thread spool so it doesnt bounce around. Also start winding with a little tail pulled through a hole on top of the bobbin and wind until this starting end is covered, then stop and snip off the tail. Then continue winding and watch the thread, giving it a nudge so that it fills evenly across the bobbin, not just all in the middle.
Think of it like the garden hose reel; if you wind it really fast the hose all goes into the middle of the reel, then jams up and you can't get the whole hose onto it. Same thing, wind smoothly and evenly across the whole depth of the bobbin so that the thread is smooth and even. Then when the thread feeds off it will be smooth evenly tensioned and should stitch out evenly.
There is some good trouble shooting information on this page too which might help you to work out what is causing this thread breakage.
http://sewing.about.com/od/sewingmachineindex/a/mtroubleshot.htm
Jul 17, 2011 | Necchi Sewing Machines
Problem adjusting tension when sewing. Could be bobbin tension or reel tension. Advise please
the bobbin tension should never need to be adjusted! however, it MIGHT need it, but highly unlikely. check which of them needs changing by sewing a dark thread onto a light piece of material (or vice versa). this makes it easier to see what's happening. any thread which is looped through to the other side is too loose. if a thread is stretched very tightly it needs to be slackened. try to adjust the reel tension first as this is usually the problem.
Jul 07, 2009 | Singer 7422
Can't find parts for a Speedaire Model 5Z705
not sure of a relay you are referring to but check Grainger for speedaire which they are sold there.
Apr 09, 2009 | Air Tools & Compressors
I have a pioneer RT-909 reel to reel unit. When the playbutton is pressed,the motor starts the tape then it continually stops. I'm assuming that the motor or belt(?) is bad?
Hello I had the same issue the take up reel tensions need to be adjusted try this thread tape so that there is no slack hold one of the tension guide reels try the right one first hold it so that it is in the 12 oclock postion this is so that it wont retract to the left which will prevent the motor from stopping or going into the cut off position if it continues to play with you holding it in this position the the tension for the reels need adjusting this can be done by slightly turning the blue adjustment knobs that read PLAY / TU 7 FWD 10 one is for 7 inch reel and the other is for 10 inch reels it's the board at the very top of deck when you take the cover off turn them slightly to the left until problem is gone this is what I did and it worked
Oct 04, 2008 | Pioneer Audio Players & Recorders
Garden Logo
268 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
