Question about Dometic NDR 1292 Refrigerator
Light in refrigerator does not go out when door is closed. We replaced the switch but the light still stays on when door is closed. Can you tell me what the problem is?
  • Dometic Master
  • 4,655 Answers
To make your search simpler and understand the way to search Norcold Manuals is to always remember Norcold and Dometic models will always come up with different search names. Confused? Click here to bigin your search=> Norcold If you are unable to get results then click=> HERE Once and at top and bottom of page=> Here you may contact me for more answers to your questions regarding your NDR1292, Thanks, Sea Breeze
Posted on Mar 20, 2011
The light is staying on when the doors are closed
Press the door swtich inside the fridge. If you press the door switch close and the lights still don't turn off then you have a faulty door switch. They are cheap to replace.
James Memije
Head Technician
Accufix Appliance Service Centre
Oct 22, 2010 | LG LFX25960ST Stainless Steel French Door...
Lights stay on in fridge
HI. The door switch will be the culprit here.
The interior light in most refrigerators, and the fan in some, are controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Dec 10, 2009 | LG LFX25960ST Stainless Steel French Door...
Light stays on when refrigerator door is closed
If you can find the 'Plunger" for the light switch......push on it to see it turns off the light. Once you know that is working you can add a "shim" to the door with a piece of tape. But if the plunger isn't working nothing else you do is going to fix it.
The plunger is usually located somewhere on the fridge on the same side where the door hinges are
Jul 07, 2009 | Viking VCSB483 Side by Side Refrigerator
What is the light switch button for in the fridge section? why does the light stay on in the fridge with the door closed when the switch inside is on ?
The switch is curved so when you close the door the light will also close.How do you know if the light is on when the door closes?Try pushing on the switch and you will see that the light will close.If that is what you are asking.If you push on the switch and the light stays on then you have a faulty switch. hope this helped:)
May 11, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Refrigerator light stays on even when door is closed.
Turn off the Low Ambient Switch on the upper panel of the Refrigerator door. That will turn it off.
May 06, 2009 | Dometic NDR 1292 Refrigerator
Refrigerator light will not go off
How do you know it wont go out if you close the door? More than likely the light switch is bad its located in the middle at the top when you open the door.Push it in, if the light stays on see if something it blocking it, if not replace the switch.
Feb 17, 2009 | Amana 22.6 cu. ft. Side-By-Side...
INTERIOR FRIG LIGHT
replace the switch before the seal, nothing wrong with gasket., you may need to raise the refrig door a bit by , remove the door and install a small spacer to raise the door slightly for better contact
Oct 22, 2008 | Frigidaire FRT21H8 Top Freezer...
Light stays on when door is closed
The GE GSL22JFPH refrigerator door gets lower over time. When it gets low enough the light stays on when the door closes. There is a vertical bolt along the hinge line. Push down the hinged plastic "hinge cover" under the door right on the hinge line and you can get a wrench on the bolt to raise the door. I have to do this every 6 months/
Jan 18, 2006 | Hoover HCA331FFK
Dometic NDR 1292 Refrigerator Logo
314 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
