Question about Dell OptiPlex GX520 PC Desktop
My dell optiplex gx520 has detected sata hdd on bios but cannot boot. i have been compare the hdd to another dell cpu and its work.
    Problem Solver:
  • 11 Answers
The reason why windows won't reconize it as a boot drive is because you have to format the harddrive to NTFS. You have to connect it as a secondary drive on another machine and format it. To do this you have to
click on start, right click on 'computer' and click on 'manage'. Once on 'computer management' click on 'disk management' and select the disk you want to format, right click on it can click 'format'.
Hope this helps.
Posted on Mar 20, 2011
How to change boot options to usb in dell optiplex gx520
Go into BIOS buy pushing F2 when the machine boots. Once in BIOS, look for boot options and make sure to select USB/External Drive is an option.
Alos, make sure that your current BIOS is able to boot via USB. May have to update your system BIOS
Oct 23, 2012 | Dell OptiPlex GX520 PC Desktop
SATA Hard Drive Type The Dell Optiplex GX280 Takes?
It makes no difference providing the computer motherboards support SATA interface.
SATA 1 and 2 drivers are in the BIOS. If all the computers have SATA 1 you can upgrade the BIOS to latest version via Dell's support website.
Regards.
Jul 08, 2010 | Dell OptiPlex GX280 PC Desktop
OptiPlex GX110 PC Desktop: Hello.. I'm having Dell Optiplex machine.When I t...
Generally an indication that the Hard Drive isn't detected
Things to check, go to BIOS F2, reset defaults and reboot, see if the HDD is seen. If it is, the battery on the motherboard is likely dead and needs replacement (Watch battery at Walmart, 3 dollars)
If the HDD doesn't detect after resetting the BIOS, then most likely a Hard Drive failure
May 18, 2010 | Dell OptiPlex GX110 PC Desktop
Unable to upgrade onboard graphics on dell gx520
Try disabling your onboard graphics in the BIOS. Some BIOS allow this. If you have a sound card, disable the onboard sound too. Count your beeps. they contain a code. Go online and "Google" bios codes. This should give you a starting point to diagnose the problem.
Oct 10, 2009 | Dell OptiPlex GX520 PC Desktop
I'm trying to install a DVD burner into my Dell GX520 (mini tower) and can't work it out ... can anyone help?
If you install the DVD drive on the same IDE cable as the hard drive using the second connector, then the jumper on the DVD burner has to be set to SLAVE.
If you elect to install the DVD burner on the cable which is connected to the second IDE controller (this is the preferred way), then the jumper setting can be set to either MASTER or SLAVE provided there are no other devices on this cable.
When the computer boots up go into the BIOS configuration to see if the BIOS detects the DVD burner, if not then the jumper settings on the DVD burner is not correct.
Oct 09, 2009 | Dell Optiplex GX520 Desktop PC - Intel...
Dell Dimension E520 has "NO BOOT DEVICE AVAILABLE" message. Pressing F1 F2 doesn't help. What should I do?
Shutdown the system and disconnect the power cable.Disconnect external peripherials.Hold the power button for 10 secs to drain static power.connect the power cable to the computer.turn on the computer and hit the F2 key to boot in bios.If you are in the bios turn on the caps lock,scroll lock, and numlock key.then Hold the Alt key + E, then Alt key + F, Alt key + B. Computer will restart check for hdd or boot device.If hdd is detected it should boot to desktop.If issue persist .Shut down the system.disconnect power cable.Hold power button for 10 secs.Open the tower and disconnect the hdd from the sata or ide cable.Connect hdd in a different sata or ide connector.Connect power cable and turn on the computer and follow steps 1.If still getting same error possible hdd gone bad.Good Luck.
Sep 03, 2009 | Dell Dimension 8400 PC Desktop
The service tag is 19sfy91. At first I could not get past BIOS error "Alert! System Halted. Incompatable processor" I flashed BIOS and the PC boots up but I still get the error message with option F1 to...
The new series of Intel G1 stepping Pentium 4 processors (Prescott) is not backwards compatible with all the latest BIOS versions for OptiPlex systems.
Jun 05, 2009 | Dell OptiPlex GX520 PC Desktop
Dell OptiPlex GX520 PC Desktop Logo
309 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
