Bacnm@Verizon.netCan not turn Ton or off with remote,or control volume, but can change channels.
    Top Expert:
  • Televison & ... Master
  • 75,786 Answers
Hello
It is remote control handset trouble. Cleaning it will solve the problem. To do cleaning, you have to open it, by anyway. Normally remote controls are two part slip type covers, which can be seperated by using any sharp instrument like a screwdriver or a knife, pressing it on the slits of the two joints at the side of the remote control. Inside it you can see a circuit board, with three or four compontens, including an IC. Clean the cirtuit board where the touch pads comes in contacts. Use only mild solvents lide rectified spirit of medical quality turpentine. Never use petrol or such strong solvents, as it will damage the rubber parts of the touch pad. allow some time to dry the solvents out from the board, and reset the remote as it was. This process will solve your remote control problem. During long time of use, the rubber parts inside the touch pad will get powdered and will stick to the touch contacts, and this is the fault in most remote controls. OK.
Posted on Mar 20, 2011
Lg tv volume and mute control
It is possible that you need to program your remote control for your LG TV. Take a look at this link, it has all the info in it: www.verizon.com/support/residential/tv/fiostv/remote+controls/setup/setup.htm
Oct 02, 2017 | LG Televison & Video
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
Magnavox 27tp82c101
Check it with an other code. Codes to check with Magavox with Verizon Fios are 1481,0081, 0057, 0733,0829, 1281 Select the code that give you maximumum functionality
Jun 05, 2013 | Televison & Video
I need the remote code for the insignia sound bar to use with my verizon fios remote control
Jeff Phillips What I did was connec the soundbar audio directly to the Verizon STB audio out and changed the remote to control the STB volume instead of the TV. Then I plugged the soundbar into the switched outlet on the back of the verizon STB.
Nov 25, 2010 | Televison & Video
Controller will only turn equipment on and off. Can't do anything else, ie: adjust volume, change channel, etc. Universal MX-900 Remote
Hello, Reset the remote control and use with the equipment . If it does adjust volume, change channel. then use have to get another one of different model
May 20, 2010 | Universal MX-900 Remote Control
Verizon fios remote codes for samsung receiver
I have the Samsung Sound Bar WS1R model. I tried all of the Samsung codes; TV, audio receiver, and audio amplifier. The DVD code 3918 worked for my Verizon FiOS remote. Program it to your AUX button and it will control the volume while your other buttons; channel, menu, etc work the set top box. I hope it works for you too!
Feb 20, 2010 | Samsung Audio Players & Recorders
Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Feb 15, 2009 | Samsung LW20M21C 20 in. LCD Television
Verizon remote won't work
I am a Verizon tech and the remotes we use work for Vizio sets just fine. If for some reason the remote wont work and he tried 3 different ones then it has to be your set. I set FIOS up all day and have no trouble with those TVs
Mar 09, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
