Question about Garden
I need to fine tune the fence on my delta shopmaster. Whatever I pass through the saw seems to rub against the back of the blade unless the blade itself isn't square
  • 710 Answers
Are you using a splitter? My saw did the same thing until I installed a splitter. Now, no problem.
"woodworker by night"
Handy Andie
Posted on Mar 20, 2011
Delta 10 Compound Miter Saw, Model 36-220, regarding the fence, why aren't the left and right side in line with each other?
You will need to co-plane fences . One fence has screws that you can loosen and place straight edge against one fence and bring the other to it. You will also need to check blade to fence angel It should be adjusted to 90 degrees. Every cut is referenced to blade-fence accuracy. there are sever you-tube videos on how to set up saw.. When I set my new 12 inch dewalt, I sent about 3 hours setting up accuracy.
Aug 04, 2017 | Delta Saws
I need a delta 9"
Please navigate to this link, choose the model that corresponds to yours most closely, and you'll get a list of available parts for your saw, with prices and so forth.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 04, 2011 | Delta BS100 Shopmaster 9 Inch Bench Top...
Need to line up the blade with the fence
I take the blade out of my tri square and lay it between the fence and the blade and let it touch the blade. Then I set the fence tight with the tri square blade.With the blade against the fence you can position the saw blade just where you need it.
I always add this for your information. If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the question queue. Thank You for choosing FixYa.com.
May 01, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
My blade on my Delta BS100 Shopmaster 9 inch bench top band saw wanders. It is impossible for me to cut a straight line even with a fence. I have adjusted the blade guides several times as well as the...
Check and see if one of the guides is out of alignment or if the blade is worn. Either one can cause the problem since you already checked the tension and guides. If the guides are worn they won't hold the blade true.
Dec 30, 2009 | Delta BS100 Shopmaster 9 Inch Bench Top...
Blade isn't cutting well. It smokes and the wood rides up as it is cutting. The saw is 14 yrs old but blade has only been used a few times. I think it needs alignment. Can I do that myself?
You should be able to adjust the fence but every model is different so I probably cannot tell you exactly how. My Biesemeyer fence has 2 set screws on front guide of the fence for parallel adjustment to the blade (this fence is a single piece fence). I had a Sears contractor saw that had 2 bolts on the top of the fence that needed to be loosened, the fence moved parallel, and the bolts tightened again (the Sears fence was a bolt together fence). Whatever fence you have I would think the adjustment would be on the front part of the fence. I would remove the fence (the fence only, not the guides) from your table saw and take a close look at it for any adjustment screws (the Biesemeyer set screws are somewhat hidden) . If the fence bolts together you will probably need to loosen the bolts to do the alignment. There is a quick check you can make to verify the problem is the fence not being parallel to the blade because your problem could also be caused by a bent saw blade arbor (the saw blade would wobble as it turns)
ø Lock your fence down and measure from the front of the blade to the fence and from the back of the blade to the fence. These measurements should be within 1/32” (ideally is should be zero).
ø If the fence passes the test above, you can see if your saw blade shaft is bent by sliding the fence very near the blade, locking the fence down, and rotation the blade by hand (unplug the saw first). If the blade rubs on the fence as it rotates then you could have a bent arbor, a bad arbor bearing, or a bent blade.
Oct 03, 2009 | Craftsman 10" Table Saw
Need bandsaw manual
Go to this link: http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=43116&typeId=9930&documentId=29416
Instead of clicking on Instruction Manual, click on the model number of the saw. This takes you to a page showing the parts diagram.
In the upper left of that page see 2 links to manuals. You want the one that begins EN...
If I've managed to answer your question or solve a problem, please take a sec to rate this post....thanks!
Mar 29, 2009 | Delta BS100 Shopmaster 9 Inch Bench Top...
Delta shopmaster bs 100 band saw
Hi, This Delta saw uses a 59 1/2 inch blade ( 1511mm).
Good Luck, this should Fixya!
Mar 06, 2009 | Delta BS100 Shopmaster 9 Inch Bench Top...
Blade Alignment?
By splitter I take it you mean fence. If this is correct there could be a couple things that I would look for. UNPLUG saw and check the blade at 0 for being inline, make sure flanges are on correctly and finally what I would look at is the adjustable table bringing the fence toward the blade. Loosen lever and move it to the first slot where the guide would go align the front of fence and lock lever then check the back of the fence to make sure it is straight. If not you would have to adjust the back rail to align it. What I made to do this is 2 of the rails from the guide slide into the slot and on the back of the saw are 2 10MM bolts that need to be loosened and the rear slide moved one way or the other after loosening the lever push the fence tight to whatever you use as a guide and snug the bolts move the fence away and then bring back rechecking alignment sometimes you might have to try a couple times but it should work. Tighten the bolts and again recheck If not let me know and I will find a manual for you to download
Feb 20, 2009 | Dewalt DW744S 10" Portable Table Saw with...
Delta shopmaster saw blade stuck down and won't go back up
sounds silly, but on the right side there is a blue knob.Push down on the saw handle and pull out the blue knob. That should release the saw arm.
Oct 08, 2008 | Delta JT160 Shopmaster 10 Amp 6 Inch...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
