I have a problem with my new internal CD/DVD burner. I have installed it per the instructions, all of the cables are connected, the tray opens and closes fine; but the computer does not acknowledge its existance.
    Problem Solver:
  • 25 Answers
The connection on the motherboard may be bad, if the harddrive cable has two connection try connecting the cd drive on the second connection. if it works you connection on the motherboard is bad
coastal-connection.com
Posted on Aug 02, 2008
LG dvd external drive not recognized by computer
ERROR 43? Check your SATA connection.
HERE'S HOW I FIXED MINE.
(IE. Computer tries to install driver for BD burner, but ultimately fails, and gives the message. "Unsuccessful" and/or "Microsoft Windows stopped device. Error 43") The SATA CONNECTION on my BD burner's EXTERNAL CASE had gone bad.
TO TEST IT. I used a SATA/IDE to USB Adapter Cable I bought for about $10 on amazon.
  • I unscrewed the external case to get at the internal drive, and plugged the SATA adapter cable directly into the internal BD burner drive (bypassing the case assembly), and plugged the other end into my computer USB port.
    • PS My BD burner POWER was working OK, so I left the big white 4pin power adapter connected to the original external case.
VOILA! Both my laptop and my desktop PC recognized the LG BD burner again and assigned it a drive letter (like it used to do).
  • Now I either need to (1) Buy a NEW EXTERNAL case ($10 - $30), (2) install it as an internal drive (could get problematic if "ANYDVD" is installed) or (3) just leave it connected via the cheap adapter cable.
It's super EASY (& inexpensive) to TEST this before spending $$$$ on a new equipment.
Hope this helps someone. It had me miffed for a while there.
Jan 02, 2014 | LG GSA-2166D DVD RW Dual Layer Burner
Need install cd burner in windows xp
IDE or SATA connections ??????
To enable CD burning for your computer is a relatively simple process in Windows XP.
All you need is a CD burner drive installed in your computer, the disk with the drivers and software that goes with it and an XP-loaded personal computer.
Once your driver is installed, the process is almost automatic.
Here are the steps you should follow to begin creating your own CDs.
Check your system requirements before installing the CD burner and make sure that your system can handle the speed and memory requirements of the drive.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Turn off the computer, disconnect the power cord and remove the cover from the case.
Check the IDE cables inside your computer.
You may be able to connect the optical CD drive to the same ribbon cable as the hard drive if it is set up as a secondary or slave drive or to a separate ATA/IDE channel by a second cable.
Find an empty CD drive slot, remove the plastic cover from the outside, slide the drive in through the back and screw it in place.
If you are using a SATA CD burner, you'll need to connect the red SATA cable from the CD drive to the SATA connection on the motherboard or on your SATA drive controller card.
With SATA drives, you don't have to fool with jumpers.
Attach one end of the separate ATA/IDE cable to the motherboard if you have an IDE drive and the other to the back of the CD burner.
If slaving the drive, hook the drive to the second connection on the main hard drive cable to the burner drive.
If you do that, you'll have to set the jumpers on the CD drive to the "slave" position.
The drive's installation instructions will show you where the jumper pins are and how to set them to the slave position.
If using a separate IDE cable, just leave the jumpers in the factory setting.
If this is an older drive, you may have an analog audio cable as well that connects to the motherboard.
Follow the installation instructions for hooking it up.
Close the case and reconnect the power cord and other cables.
Turn on the computer and let it boot up.
Open the "My Computer" folder and make sure there is a new icon for the drive that you just installed.
XP will generally recognize it automatically, but if it doesn't you'll have to reboot the computer and open the CMOS setup program.
Follow the instructions for your particular PC to open the CMOS window.
Check the ATA channels to make sure both are enabled in setup and that, if you are using a master/slave setup, that the CMOS selections match that setup.
Reboot the system.
If the CMOS settings are correct, the XP operating system will set your drive so that it uses either digital CD playback (no audio cable) or analog playback (with audio cable). To check, open the "My Computer" window, choose "Properties" then "Hardware" then "Device Manager".
You'll see a "DVD/CD-ROM Drives" icon.
Click the plus sign next to DVD/CD-ROM Drives folder.
Click it, then right-click the icon for the new CD burner drive.
Now choose "Properties".
If you don't have an audio cable, left click on the selection box for "Enable digital CD audio for this CD-ROM device".
Insert the CD burner software disk that came with your CD burner.
Insert the disk that came with the drive into the CD drive and install the software following the prompts.
If the drive doesn't come with CD burner software, Windows XP comes with a lite version of Roxio's Easy CD Creator that detects blank CDs.
Just insert a blank CD in the burner and XP offers you a "burn CD" option when you have autoplay set up for the CD-drive.
There are lots of freeware burning software on the internet.
http://download.cnet.com/instant-cd-dvd-burner/3000-2646_4-10393316.html
Burn audio, video, and data CDs/DVDs and create and burn ISO files.
Instant CD & DVD Burner is the ideal choice for anyone looking for a simple but full featured CD/DVD burner.
http://www.freeware-downloads.com/nero_essentials.htm
nero 8.1 essentials free
This is the newest version of the most known CD and DVD burning software, but now with the capability to burn HD DVDs, and Blu-ray Discs
http://nero-free.soft32.com/
Nero 9 .4.12 free Create, rip, copy, burn, edit, share, and upload online
Nov 10, 2013 | Broderbund Computers & Internet
ASUS 22x Internal CD/DVD Burner not working
Look into the little jumpers on the back.
If its SATA its np But if its IDE you need to set the jumper to master or slave or cable sellect.
May 01, 2012 | ASUS 22x Internal CDDVD Drive Burner
Memorex 3202-3223 dvd burner disc tray won't open
Try reseating the DVD drive so it makes proper connection.
Mar 05, 2012 | Computers & Internet
The CD rom does not open?
Take a paper clip now straighten it push it in the tiny hole on the front of the CD ROM drive
the drive should open
Apr 12, 2011 | LG (GCC4243N) CD-RW/DVD-ROM (Combo) Burner
I replaced an old CD/DVD R/W drive with an LG GH22N550 22X Internal SATA Super Multi DVD drive. The old drive was an IDE, I believe. After installing the new drive, the system wouldn't boot. It kept...
Look on the back of the old drive to check the jumper settings (master/slave) and set the new drive exactly the same. If that doesn't work, you may have to connect the drive to a different IDE connection on the motherboard... Also, check the BIOS settings for your IDE drives and make sure the one for the CD is set to AUTO or CD-ROM.
Oct 25, 2010 | LG CD/DVD-ROM Drives (DRGDR8163BI) Burner
Disc tray keeps opening/closing on DVD recorder
my dvd player sony cinema entertainment system dav-dz111 the tray is opening again after closing
Sep 22, 2009 | Televison & Video
I just installed a Pioneer DVR-115DBK cd/dvd writer (burner). My computer recognizes it, it says it's working properly, but the little green light on the front of the burner keeps flashing. Whenever I...
disconnect the dvd rw and again reconnect the cables then try once again and check the device is in master mode or slave.if again not solved then Contact the dealer from where you purchase dvd writer.
Jun 25, 2008 | Pioneer Computers & Internet
Ativa CD/DVD with LightScribe
the driver is packaged with nero 7 essentials (Grrr...)
Apr 26, 2008 | QPS Que! Fire CD-RW Burner
CD-RW Problems
First, try this:- Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete. Restart the pc and windows will find the drive again automatically and install the drivers. If that doesn't work, take off the side of the pc and and look to the back of your burner. You will see an ide cable connected to the back, either try a new cable or try the cable that is connected to the hard disk drive, as there will be another connector available. If you do use the burner on the same cable as your HDD then you will have to set the jumper on the back of the burner to slave. It could be a bad cable or faulty ide motherboard connection.
Mar 11, 2007 | Lite On LTR 52327S CD-RW Burner
Computers & Internet Logo
David Payne
David Payne
