Question about Home Security
Need hard drive or drive image for a Lanex NetDVR-sd Verint no longer supports this model
    New Friend:
    Problem Solver:
  • 5 Answers
Send me a message and I can find you a resolution.
Posted on Jan 24, 2013
  • 1 more comment
  • hugo alfaro
    hugo alfaro Mar 13, 2014
    hi aaron, i need same solution, can you help me too?
  • Duke-Jinx Feb 08, 2015
    Same here. :/ Bought 'working unit' only to find the HDD removed. Thanks ahead of time...
  • Mark K
    Mark K Oct 28, 2015
    If this thread is still alive, I need a hard drive solution as well to keep some of these units alive as the hard drives age and start to fail.
Tip
Restore win 7 from system image on toshiba portage m200
This should apply to other brands and models...
the original problem: bad hard disk, need to restore from win 7 image disks however The portage m200 lacks an optical drive and cannot be booted from usb (only options are to boot from LAN or from a specially created SD card).
Solution:
you will need a second pc that can boot from an on board or peripheral optical drive. Swap the second pc's hard drive for the one that you are restoring. Now boot the second pc from the restore disk and follow the onscreen instructions. Once completed the pc will try to reboot and you will get an error about how windows couldn't repair start-up. Now power down and swap the hard drive back to the portage. You should now be up and running, much easier than trying to create a boot-able sd image or boot from a PXE server.
on Oct 10, 2010 | Toshiba Portege M200 Tablet PC
I need windows xp operating system
Windows XP Is no longer supported you might be able to find a torrent for an ISO image but I would think so. your best bet is to try and find someone who has a copy and then run XP as a virtual machine
Jan 13, 2014 | Western Digital Caviar AC36400 6.4 GB Hard...
Swan dvr wont record
It sounds like a problem that might be an easy fix. Since the system CCA board doesn't see the HDD. Can you view any previously recorded images? How are the connections to the drive? Bad IDE ribbon cable (yes do do fault), power to the HDD and how about the drive? Some of my DVRs require the manufacturer drive, not a simple off the shelf (i.e. Lanex or Verint).
Try that and reply back. :)
May 22, 2013 | Home Security
DELL/EMC AX150i Storage Array OS
If all you need is an image. These guys can make one for you remotely.
http://FreeDataRecovery.us
Aug 24, 2012 | EMC Insignia CLARiiON AX150i Hard Drive...
Need user manual for a Lanex/Verint netDVR. Also need the procedure to reset the netDvr to its default status. Thanks in advance for your assistance.
Let me guess - you aquired a netDVR with no hard drive and put one in and it doesn't work. The hard drives are encoded with some data that is specific to Lanex, so you have to buy the hard drive from them at a large markup. This is my only pet peave with Lanex as otherwise they are one of the best on the market. Do you have the application to talk to the netDVR? If you do then the default password is 'admin'. this should let you in to make changes to the configuration.
May 01, 2010 | Computers & Internet
SD as hard drive--windows XP download
An SD card isn't usually used as Hard Drives as they don't contain enough space. Although they are getting bigger and bigger capacities all the time!
I think what your after is booting your computer off the SD card which will have Windows on it? Some computers can boot straight from the SD card, my old laptop used too!
What needs to happen is that you need to go into your BIOS settings (which are your motherboard settings) and in ther you can set boot sequence, so by default most are set to Hard Drive first. The computer looks there first for the operating System. So you need to tell your Motherboard to boot from your SD card 1st. Now your motherboard needs to be able to support this feature, my guess is that it probably wont.
Go into the BIOS and find the boot sequence and scroll through the available options, if SD is in there, set it. If not your motherboard wont support booting from SD.
Mar 21, 2008 | SanDisk Memory Media
Jumper settings for a Maxtor hard drive, Model 87000D8
Here's the chart that lists the jumper settings for all of the various models of Maxtor hard drives:
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
The first drive above is a DiamondMax 1750, and
the 2nd is a DiamondMax 4320
Feb 08, 2008 | Maxtor Hard Drive
Jumper settings for an older maxtor hard drive
Support can be found at Seagate.com in case this is not the exact drive. The model number you listed was not an exact match.
Nov 25, 2007 | Maxtor Hard Drive
Home Security Logo
519 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
