Question about Rokenbok Rc Loader
My rc loader 2625 stops working every few seconds. If I remove and replace the batteries it will start again but only works briefly. I changed the batteries several times and I get the same result. Any ideas? Has anyone ever had a rokenbok vehicle repaired?
  • baylake Mar 20, 2011
    The batteries fit very snugly. The contacts seem to be working fine. As soon as the battery touches the contact the lights come on, even before the battery is snapped into place. I did try the sandpaper on the contacts anyway, and it made no difference. What can I try next?
  • Anonymous Mar 30, 2014
    The remote gliches. When I turn the power on, it sometimes freezes the remote and I can't drive my rc 211 loader and my rr 415. Instead I have to turn off the power while the lights flash and can't find the number that it has selected on the remote. Can I fix it or should it be taken to a fixit shop?
    Genius:
  • 1,015 Answers
One thing you might try is after you have removed the batteries is to polish contact points on vehicle and batteries.You can use a fine grade of sandpaper or steel wool for this. Check to see if batteries fit snugly and if not you can place a small spacer made out of aluminum foil on positive end of battery. Hope this helps you. Thanks.
Posted on Mar 20, 2011
  • Jack Spooner Mar 20, 2011
    About the only other thing I can think of is to check all wiring to circuit board to make sure there are no loose connections that are causing your problems.Thank you
MY PARKER REMOTE SUDDENLY STOPPED WORKING WHAT COULD BE THE PROBLEM
I had a remote stop working and took it in and all they did was remove the batteries over night and then it started working again.
Dec 30, 2014 | Televison & Video
My mini rc helicopter lands in a few seconds of flying time. So I decided to replace the battery(because I thought it is a battery problem). After replacing the battery, problem is not solved. Helicop
Some of those mini helicopters are just designed bad. Their motor is to weak, the whole setup battery-speed controller-motor-blades is slapped together "hoping it will work". The quality is ridiculous. One heli or one from a certain batch would fly descent, others woudl barely lift of and drop down after a few seconds. The best solution is to return it to the store and by something for more money. But if you want to experiment:
1) Try reducing weight: remove anything that is not necessary off of it. Also, try smaller/lighter battery with same voltage and current rating (smaller capacity=lighter)
2) Try slightly higher voltage. I.e., if it uses NiCD/NIMH batteries, add additional cell. With LiPo's it's a bit complicated, if heli is running of one cell (3.7V) adding another cell will burn it. If it is 2 cells, trying 3 cells might work or might overheat the motor.
3) Try replacing the motor with slightly stronger one. Now you will need to search online, ebay, hobby stores for similar size that you can fit in. Not the easiest thing to do.
4) Again, get rid o fit. it's not worth your time, unless you like to experiment. It will never fly the way you would like it to.
Nov 30, 2014 | RC Toys
How to fix a rc boat that works out of water but not in
change the esc its been wet and caused a electrical short. its almost cheaper to buy another zig zag or a totally different boat rather then repair that one.
Dec 31, 2012 | Hobby Zone Hobbyzone Zig Zag Racer 3...
Rc sunfire. remote works the steering but not the throttle.
try sync it to level 4 on it will turn green on full throtal I did it then I had to do it again because I charged the battery and had to sync it again try this when I did not do it second time it just stop tell me if that is the problem not a good discharge battery for 3000ninh 8.4
Sep 04, 2011 | Exceed-RC Exceed RC Brushless Pro SunFire
My sony vaio was runing when stop working for about a few seconds. then stat again ....after a couple of minutes stop working again then start...i replace memory ram and the hard drive for a brand new and,...
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Jul 19, 2011 | Computers & Internet
Power is connected and on, but I cannot start my laptop
Hi. This may be stuck in hibernation or standby mode or the system might be stuck in mid shutdown. If the power light is flashing, try holding down the power button for at least 10 seconds until the flashing stops. Now press the power button again, briefly this time and hopefully it will boot. If this does not work, disconnect from the charger, remove the battery (usually an easy task, using a sliding clip underneath the laptop). Then replace the battery and charger and press the power button to start. If neither of these tips work, listen out for beeps from the motherboard. If you hear multiple beeps, then count them let me know how many. This will indicate a hardware problem.
Nov 25, 2009 | Sony Computers & Internet
My bb pearl it`s flashing 3 times stop then 2 times i can`t start my bb i can`t upload anything my computer dosn`t see my phone.what can be done to fix my bb?
Perform a hard reset on the BlackBerry smartphone. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
If the display is still not working, verify that the battery is charged by trying it in a different BlackBerry smartphone.
If the battery is working, download the latest BlackBerry Device Software and install it using the application loader tool in BlackBerry Desktop Manager.
Nov 21, 2009 | RIM BlackBerry Pearl 8100
Phone just dies for a few minutes every so often--several times a day for the past ten days. Screen goes black and then there's a little white clock icon on the screen. A few minutes later it's fine...
A) Perform a hard reset on the BlackBerry smartphone.
A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:
smartphone.
B) If the display is still not working, verify that the battery is charged by trying it in a different BlackBerry smartphone.
C) If the battery is working, download the latest BlackBerry® Device Software and install it using the application loader tool in BlackBerry® Desktop Manager
Oct 19, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Ram change problem
There should be a reset button on bottom of laptop....if not...remove battery, power supply plug and remove the mbottom panels....under one of them is a battery the size of one of two....either 6mm in diametre or one of 22mm in diametre...remove it and leave laptop for about 5 min....remove memory,touch the memory's golden edges briefly with your fingers to discharge charge in memeory.put everything together...should solve your problem. JJ
Sep 13, 2007 | Dell Inspiron 6000 Notebook
Rokenbok Rc Loader Logo
217 people viewed this question
Top Rokenbok Toys Experts
Bill Boyd
Ernest
Ernest
Rahul Prajapati
Rahul Prajapati
Are you a Rokenbok Toy Expert? Answer questions, earn points and help others
