Question about Karcher RC3000 Bagless Robotic Vacuum
My brush does not turn, not even the brush motor, the belt system is ok. (Karcher RC3000) tks regards
  • 783 Answers
How long have you had it? when did it just start having problems?
Posted on Mar 20, 2011
My belt is burning do I need anew belt and just align and clean brush. Motor sounds ok
Belts start burning because they've become too worn and loose to keep a good grip on the brush and motor shaft. You do need a new one. When replacing, ensure it's in the correct position by rotating the brush a few times. Make sure you've got the correct amount of tension on it. Too loose and the belt will slip and burn out again. Too tight may cause breakage as well as excessive stress on the motor.
It's often best to allow even a simple fix to be done by a service tech.
Dec 21, 2010 | Panasonic MC-V7720 Bagless Upright Vacuum
How to change a belt on a shark v15z vac. tks john t
John -
Your vacuum doesn't have a belt - only vacuums with rotating brushes use drive belts.
What problem are you having - why do you think you need to change the belt?
Please rate my solution if you find it helpful.
Oct 14, 2010 | Euro-Pro HEPA Shark EP035 Bagless Handheld...
After 2 ½ weeks storage, my RC3000 will not charge
Rechargeable batteries tend to decline when left in a discharged or partially charged state.
Jun 09, 2017 | Karcher RC3000 Bagless Robotic Vacuum
Rotating brushes will not turn
If belts are ok then possibly needs new front brush motor replaced.
Nov 05, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
No suction
Are you saying that the motor runs but there is no brush rotation ?
If yes then firstly switch machine on then when you pull handle back as if to vacuum the carpet the clutch drive dial must turn to (drive, start, on,) position if it is stuck on (park, off. Stop, p,) position rotate it to drive etc as you pull handle back providing the clutch & both drive belts are ok the brush will spin.
The clutch drive dial knob is situated looking from the front of machine lower left hand side approx 50mm or 2” in diameter.
Please do this test & let me know results
Regards Chris..
Sep 28, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Eureka 5197 self propelled bagless upright
Did you check the brush roll when you changed the belt? The smell of rubber would inducate a belt slipping. So if the brush roll (part #61308-2)isn't turning, the belt would get hot and would be slipping. If the motor sounds real loud, then you could have a bad motor(part #60775-4).
Feb 14, 2008 | Eureka 5197AT Upright Vacuum
Karcher k2.94
there was a techinal update on this machine a few months ago, the oil may be leaking from the swash plate housing
Sep 26, 2007 | Karcher RC3000 Bagless Robotic Vacuum
Karcher RC3000 Bagless Robotic Vacuum Logo
44 people viewed this question
Top Karcher Vacuums Experts
kbright1
Level 1 Expert
richie46
Are you a Karcher Vacuum Expert? Answer questions, earn points and help others
