Question about Bosch Axxis WTL 5410 Electric Dryer
My Bosch Axxis 5410 dryer won't start. The time lights up and the status light says drying, but the dryer doesn't start. There's a little dot on the lower right hand of the time remaining which hadn't appeared before.
    Top Expert:
  • Bosch Master
  • 9,472 Answers
This type of diagnosis will require accessing the internal components & making voltage & resistance checks with a volt/ohm meter. There are several different components that could cause this symptom & yes it is possible that the door switch is bad. This model of dryer should only be worked on by an experienced, trained technician due to all of the electronic controlled parts. My Bosch Axxis 5410 dryer won't start.  The time - richroth_121.jpg
Posted on Mar 20, 2011
How do I fix dryer that stopped working?
Check the little button that the door pushes in when you close the door (door switch).
May 01, 2014 | Bosch Axxis WTL 5410 Electric Dryer
Dryer not starting
Check your lint filter first, and then try to restart it. Also, make sure the door is completely shut. If this doesn't do it, check your condensation hose for blockage. These dryers are very sensitive to lint build up, so make sure to change your lint trap after each load. It's not only a good practice, but it's necessary with this machine
Feb 27, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Bosch axxis wtl 5410 dryer takes too long to dry.
You should have a cycling thermostat. this is most likely bad or your dryer vent may be clogged. Something is cutting the heat off before it gets hot enough. Both these cause this problem.
Nov 17, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Error Code
open the thing up and locate the service manual. once located it should list what that error means. alternatively call bosch and ask them.
Aug 25, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Axxis Condensation dryer not working
Try to vacuum clean inside the door contact breaker (female part). If you can remove the dust it should start working again.
Jun 08, 2009 | Bosch Axxis WTL 5400 Dryer
Load capacity of WTL 5410
7 kg is the max this is quoted as dry load not wet halfed when wet.
May 30, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Bosch axxis wtl 5400 dryer
I found that the dryer will not start because the door isn't fully closed. My wife has basically split the plastic door a bit, but if you firmly close the door, it will start.
Jul 25, 2008 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Dec 15, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Axxis WTL 5410 Electric Dryer Logo
539 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
