Question about Bissell Vacuums
The steam in my handheld steam shot does not seem to be very hot therefore the surfaces, specially cloth ones do not get clean properly. What should I do?
    Genius:
  • 1,267 Answers
If it steams it is as hot as it is going to get. Water steams at 212 degrees F at sea level so the only way to increase that heat is to pressurize that steam to a higher density than sea level which is about 32lbs per sq. in. Your steamer has no method to pressurize that steam to increase that heat. Conversely, as the pressure decreases, say you live in Denver which is about 5000 ft above sea level, then that steam will only get to about 203 degrees F. (See: http://whatscookingamerica.net/boilpoint.htm) Steam Cleaning at best is a poor method of cleaning as all it does is saturate the clothing item with water, which in theory loosens dirt, but no way is provided to remove the dirt. A rug shampooer has a vacuum that sucks the dirt away from the carpet along with the suds for a better cleaning method. In my opinion a hand steamer will only remove wrinkles at best.
Posted on Mar 20, 2011
How do I get the handheld steamer to lock into the steam mop?
You can purchase the replacement part from Govacuum.
We offer 11% discount for Fixya readers - Use code FIXYA11 to get exclusive 11% discount. You will also get free shipping over $35.
https://www.govacuum.com/products/s-3101-shark-pads-and-blue-coral-pad-for-xt3101-s3202-s3250-by-zvac-2
Jeethu
Govacuum Team
Jun 11, 2015 | Euro-Pro S3901 Shark Lift-Away Pro Steam...
Haan sI70 unit gets hot but no steam is generated, so not hot enough. Anything I can do?
It sounds like the internal temp thermostat is detecting that its hot enough when its not, and cutting the power as its supposed to, but too early. It may not be worth time/effort/money changing this part, in case its a problem with another part. Its a bit desperate but you could turn it off and half fill it with cold water then shake it vigorously to see if washing the internal surfaces impoves things.
Dec 15, 2013 | Haan SI70 Multi Sanitizing Floor Steam Mop...
Www bissell com
Hi Therese. The Little Green doesn't create steam. It uses hot tap water and BISSELL Formula to clean your carpet.
Aug 14, 2013 | Bissell 1425 Little Green ProHeat Handheld...
Aquamark AM680 potable steam cleaning System. I tried it but the steam is not coming out. Kindly, anyone has a solution? Thanks
hi there sorry i dont have a solution i'm looking for one, did you manage to know the problem, i have the exact same one with the same cleaning steamer, thanks
Aug 04, 2013 | McCulloch MC1246 Handheld Steam Cleaner
My steamer gets hot but no steam if very little is coming out what do i do
clean it with lime away where the steam comes out it has had hard water build up that has clogged your openings
Apr 06, 2012 | Euro-Flex Monster 1200 Handheld Steam...
My Eureka handheld Hot Shot, will heat up, but won't spray. I have put 1 c distilled white vinegar and 1 c water in and let it heat up. I have repeated this twice, but no luck. I have only used this...
unfornitually the metal that makes up the steam vessel oxidies when water is left in it, when it has not ben drained, which causes a white powder around the valve which is almost impossible to remove, almost. yes white vinager can remove it and will also cause more oxidizatinn if not rinced very throuley the valve has a thermoplastic part covering it if you deside to remove it it will usually break off making the unit unusable.The carosion around the valve is the problem that causes the valve to stick. if not very carfull you can cause this thing to blow the plug out of the top steam is very dangerous. dan
Mar 30, 2011 | Eureka 350A Handheld Steam Vacuum
My handheld hot shot pressure is not as forceful as it use to be. How do I unclog or clean it. or how do you fix it?
Thank you for allowing us to help, please respond with further questions and concerns
Spanish speaking available for all problems
Before you leave feedback, ensure that your concerns and problems are addressed completely with me.
PLEASE do not forget to award/PROVIDE "POSITIVE" FEEDBACK
PROVIDING FEEDBACK WILL ALLOW US TO CONTINUE SUPPORTING YOU IN EXPERT SOLUTIONS Before you leave feedback, ensure that your concerns and problems are addressed completely with me.
Hello, thank you for sharing your problem with us, I would personally be happy to provide the most accurate and up to date information for you.
1. You may use VINIGAR with HOT water to flush out the calcium bulidup in the sprayer.
2. Before using anything stronger, consult your manual to ensure you will not damage the device
Jan 10, 2011 | Eureka 350A Handheld Steam Vacuum
Shark handheld steamer heats up but does not spray
Try rinsing it out with CLR, it gets rid of calcium, lime and rust deposits i heard its very good.
Jul 10, 2009 | Euro-Pro Ultra Steam SharkTM II Hard...
Gets hot but will not steam
Adding a little salt to the water seems to help the steam come stronger. Good Luck!
Jun 22, 2009 | Scunci 52001 Handheld Steam Vacuum
My scunci steam cleaner has a white build up and is clogged. How can i clean it?
I had not used my scunci for a few months and now it is completely clogged. I tried vinegar over night and removed a lot of sediment, but it is still not working. My last shot was going to be to use lime-away. Any suggestions. All parts look in mint condition, but it just doesn't work.
Sep 28, 2008 | Scunci 52067 Handheld Steam Vacuum
Vacuums Logo
166 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
