Question about S3 Trio64+ Graphic Card
LOGITECH QUIKCAM my wires were pulled out og the camera and the clip is missing also that goes to the camera board. I need to know which color wire goes to which pin on the camera board?
    Scholar:
  • 144 Answers
Look for the technical part in your manual or check if it is available online, sometimes a complete electric schedule is in the manual.
Posted on Aug 08, 2008
EDTV RCR
Hello
The fault is due to loose contact in the connecting wires from its T'Con board to display panel. If you are aware in electronics, unplug all the flat cables thaconnected with T'Con board to display panel, Just unplug it, and replug in. If any loose contact in between the contacts of the wire strip's connecter end, will get right by this. But you must be vary causious not to damage the wires.
This is the picture of the tCon board to your set. It will be normally within an shelded condition. Just see, the connectors that hold strip wires. Juslt look release the clips that holds each connector wire end. You can see it on either side of each connectors. Just pull the clip up to release the strip wires. Pulling up, will loosen the connectior's hold to wire. Take each of the fully out, one at a time, and replug it. Switch ON and check each time after repluging each connection wire. In this way, you will get an idea about the loosed connection too.
Dec 14, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Logitech quickcam express for xp
required logitech quikcam express driver forxp
Jan 08, 2010 | Logitech QuickCam Express Web Camera
PXC250 headphone cable ripped out from electronics box
here is the schematic showing where the wires go. the thick copper is the copper that goes around the rest of the wires. it is not neat like the other wires, but lots of single strands. if you are missing some wires, cut 3 centimeter or so of the lead, the wires missing are probably broken further up the lead.
Getting the solder to wet these wires are notoriously difficult. For me the flux inside the solderingwire was not helping, so i took a match, burned of the lacquer of the end 5mm of each wire, scraped the soot of with a knife, and put flux from a box onto the wire. Then i got the solder to wet the wire. Do this with all the ends of the loose wires. Then solder them to the green board as instructed on the the schematic (it is the top of the two drawings that you want to use).
Be careful not to overheat the PCB. make the solder wet the fire first, then solder the wire to the PCB (green board)
Aug 15, 2009 | Sennheiser PXC 250 Consumer Headphones
2006 ford expedion blower motor only has high speed
Remove the RH lower instrument panel insulator under the dash you should then see it,has one screw holding it to the blower case.It will have OG/BK,LG/WH,YE/RD,BK wires if it is a manual system.If electronic climate control the wire colors will be VT/WH,TN/OG,RD/WH.BK
Feb 17, 2009 | 2006 Ford Expedition
Car raidio
speakers: L/F - OG/LG [+] LB/WH [-]
L/R - GY/LB [+] TN/YE [-[
R/R- OR/RD[+] BN/PK [-]
R/F- WH/LG [+] DG/OR [-]
WH/YE HOT f2 20 amp fuse box
BK/PK HOT VPWR
RD/BK illumination
RD/LB Hot in start f2 5 amp fuse box
BK ground
BK/LB ground
BK/OG ground
as far as I know there isn't a "remote" wire unless you are dealing with steering wheel switches
Hope this helps!!
Feb 02, 2009 | 2002 Ford Explorer
We installed the Logitech quikcam S 5500 successfully then fails
Hi.
If you cannot see a device in Device Manager, than the device is not properly attached, which means that it is possible that USB port is not working properly. Try attaching it in different USB port. If you know that USB port is functioning properly (other devices that you attach to it work), than camera might be dead.
Your responses are intended to improve the level of service provided. Please rate your experience.
Jan 17, 2009 | Logitech QuickCam Communicate Personal Web...
Webcam
The driver for the Logitech Quikcam Communicate STX is located at the following link. Simply choose your operating system and that will lead you to the page where the download will be located.
http://www.logitech.com/index.cfm/435/352&cl=us,en
Nov 08, 2008 | Logitech QuickCam Communicate STX Personal...
Cable/ribbons
Which cable do you need, the one that goes from the video board to the main control board? Also the power cable clip can be found anywhere, its one of the most common clips.
If you just pulled the wire out of the plastic shroud, you can lift the leg that holds the wire in with a pin and shove it back in. If the wires broke, you can solder it back together or I probably have a replacement here.
Sep 05, 2008 | Akai PDP-5016H 50 in. HD-Ready Plasma...
Logitech Quikcam
Well if its askin for a cd then it needs a cd. If you dont have one I don't know how you installed it in the first place. If you can't find or buy a cd i suggest buying a new webcam. I'm sorry I couldn't help more!
Apr 28, 2008 | Logitech QuickCam Pro 5000 Webcam
Computers & Internet Logo
Top S3 Computers & Internet Experts
David Payne
David Payne
Are you a S3 Computer and Internet Expert? Answer questions, earn points and help others
