Question about Briggs Stratton IC Horizontal OHV Engine 305cc 1450 Series 145 Gross Torque 1in x 3 2132in Shaft Model 2053320537B1
Have replaced battery, gasoline, and spark plug. engine doesn't sound as if it is getting fire.
    Genius:
  • 1,267 Answers
That B&S engine has an electronic module that supplies spark to the plug. Those modules go open and will not allow the spark to the plug. I suspect that you will have to replace that module. See: http://www.northerntool.com/shop/tools/product_200356541_200356541 also see: http://www.briggsandstratton.com/engines/shop/parts-and-accessories/ for parts.
Posted on Mar 20, 2011
My 1986 Dodge motor home keeps running and backfiring after shutting engine off?
You can find out the tune up specifications by using the engine id numbers. 1st Check the timing! The engine sounds like it is trying to "diesel", which simpy means running with no source of spark. (A diesel uses compression in place of spark plugs). A Hot gasoline engine can produce these systems if something in the combustion chamber remains hot enough to ignite (or "fire") the cylinder(s) with the the ignition turned off.
My guess is your engine is firing too early (ignition timing) and the spark plugs are getting too hot! The longer or harder the engine works, the worse this condition will be.
GOOD LUCK
Sep 04, 2017 | RVs
I have a 97 Dodge Dakota that I replace the fuel
OBD Tools 365 Days Shop for car repair.
Find out if the engine is getting gas to it. Sometimes a plugged fuel filter or a problem with the fuel injectors can prevent the engine from getting any gasoline. To check this remove the air cleaner and smell inside the throttle body or air cleaner housing. If the engine is getting enough gas you should be able to sense a strong gasoline smell due to the amount of uncombusted fuel left inside the intake manifold.
Determine whether the spark plugs are firing. If there is plenty of gas but no spark, the engine will crank but not start. Unplug one of the spark plug wires and plug in a spark tester. Have a friend get in the car and crank the engine while you watch to see if the spark tester illuminates. You can usually purchase a spark tester at an auto parts store for about ten dollars.
Oct 10, 2014 | Cars & Trucks
Backfire
Backfire is cause by defective spark plug. The gasoline that not been combusted cause problem, it only exhaust to muffler so in the next stroke fire activated the fume gasoline will be ignite to cause the second sound firing blue flame. So Better change the spark plug. if you already change the spark plug still the same then check your ignition coil connection
Aug 20, 2011 | 2004 Honda XR 250 R
Manual 1994 jetta 2.0 4 cylndr . Car will not start...it will not turn...battery is still great...could it be an electrical problem? Where is a good place to start checking?
start with the fuses and the relays. some say ign or eng which is ignition or engine. if that is good, check the fusible link. if that is good, test to see if the started gets full voltage
Jan 13, 2011 | 1999 Volkswagen Jetta
Bought unit new last summer. Used it once last summer and once this year. It started fine both times. Today, it will not crank. I have replaced the spark plug, checked the air filter (it is clean), gas...
Unable to crank? Do you mean unable to start?
If you leave gasoline inside tank over long period of time, that will 'gum-up' and ruin carburetor.
To prevent problem, put additive in gasoline or empty gas from tank:: under gas tank should be a hex bolt that holds up gas filter > loosen bolt and drain gas.
Starting the engine:
Take off air filter and spray WD-40 directly into carburetor.
Start engine, engine should fire on the WD-40 accelerant.
If engine fires but does not keep running, try spraying WD-40 into carburetor continuously to see if you can keep engine going.
If engine stops each time after it no longer gets WD-40, then carburetor is bad or gasoline not getting to carburetor or gasoline is bad.
Try fresh gasoline.
Do not turn small engine on side or upside down or oil will get into carburetor.
Check gas supply: Go to gas filter under gas tank. Pull loose rubber hose that connects to carburetor and see if gas comes out rubber hose.
If gas is flowing to carburetor, then carburetor is gummed up.
Small engine repair might suggest 'gum out' or have other suggestions ... but you may need a new carburetor
If engine will not fire on WD-40
If engine will not fire on WD-40 at all, then spark coil may be bad or exhaust port is clogged
Check screen that covers exhaust >> is it covered with carbon and dirt or can air pass through it easily?
Check spark
Remove spark plug
Put spark wire back on spark plug
Hold spark plug by rubber spark cap so hands don't touch metal part of spark plug
Touch spark plug threads against hole where spark plug was removed >>> metal to metal so it conducts electricity
Pull start cord and look for sparking between spark plug threads and metal of engine (don't look at the spark gap ... look where metal meets metal
If you have no spark, the spark coil is bad >> time for estimate from small engine repair shop or get your part number and order replacement
Oct 13, 2010 | Craftsman Garden
No start on old gasoline forklift engine.
most likely the ign switch is ok if you are getting spark. so you have a hot spark at coil and weak fire at plugs? if you have a test light check the positive side of coil for power when turning key on and cranking. if it is dropping power on positive side then ign switch could be bad. can "hotwire" coil by jumping a wire to positive side of coil to pos of battery this will eliminate ign switch.
Apr 07, 2010 | 1978 Chevrolet C1500
Tw200 won't start
making eeee sound as the motor turning over but no fire, check if you get fuel and spark, two items that will make the any engine run, without it, it wont fire or run. check if you getting sparks, pulling the plugs out and crank the motor and see if any sparks exist, next check if you getting fuel. no sparks can be your coil. hope that help some
Jul 16, 2009 | 2005 Yamaha TW 200
Toro Recycler with Techumseh enging will not start
Make sure it can breath. Check the airfilter element. If its oil soaked replace it. Sounds like this engine cannot breath. This engine is set ,there are not jets to replace. Champion Plugs are not the problem FIRE IS FIRE . Fresh Gas if it aint less than 30 days old it aint fresh. Todays designer fuel goes stale quickly.
Jun 27, 2009 | Garden
My gilera RC 600 COBRA doesn´t start
Hi Jose ,
It seems the timming may not be correct thus the back-fire.
Please check the ignition timming and valve timming too .
Hope this helps
May 15, 2009 | 1991 Gilera RC 600 R
3000ise wont start by key. New battery
Is the battery charged? If not charge the battery and try it again. Generally most gasoline engines will start and run when these conditions are met:
1. good spark. If the spark plug is old, buy a replacement being sure to get the right plug. Then make sure the spark plug is gapped properly.
2. New fuel. If the fuel has been in the tank for more than two months replace it with new gasoline.
3. Air supply. Take a look at the air cleaner. If it is dirty clean it or replace it.
Food luck.
Jan 26, 2009 | Electrical Supplies
Briggs Stratton IC Horizontal OHV Engine  305cc 1450 Series 145 Gross Torque 1in x 3 2132in Shaft Model 2053320537B1 Logo
81 people viewed this question
Top Briggs Plumbing Experts
John Trevino
Jim Parker
Jim Parker
Are you a Briggs Plumbing Expert? Answer questions, earn points and help others
