Question about Kenmore HE2 Plus Front Load Washer
Why won't my kenmore (front loader) power button work?
    Brigadier General:
  • 6,277 Answers
Sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB. I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Posted on Mar 20, 2011
  • 10 Answers
SOURCE: kenmore front loader
the drain pump on this unit has a clean out. There is probably debris in the pump. remove the lower front cabinets. There are three screws almost at floor level that hold it in place and open the drain pump it has a handle on the drain pump that you can twist to remove.
Posted on Nov 04, 2007
  • 1314 Answers
SOURCE: Kenmore front loader washer
First if you have a wet vac pull the drain hose out of the drain spout and use the vac to pull the water out of the washer through the drain hose.If not you will need a pair of radiator hose clamps from the auto parts store. Pull the screws from the lower panel at the front of the washer and remove it.in side you will see a rubber hose coming down from the tub to the drain pump. Put the radiator hose clamp there if you didn't have a shop vac.On the front of the pump is a round part with a handle turn that and remove the pump filter .Clean any foreign objects out of the pump and look inside the pump to make sure no impeller blades are broken if any are you will have to replace the pump. put the filter back in and tighten it. If you had to use the hose clamp remove it now.reassemble and don't forget to give the tech his four boxes if this fixes it
Posted on Jan 25, 2008
My front loader stops at every cycle. Is there a simple solution to this?
Posted on Feb 06, 2008
SOURCE: unlock the control panel to a kenmore elite front loader
to unlock the controls
select and hold drain/spin for 3 seconds until the control locked status lights turn off.
Posted on Apr 12, 2008
  • 311 Answers
SOURCE: kenmore front loader he2t power button stuck
First of all, the power button is not a separate part. It's integrated into that whole interface and cannot be fiddled with. You need to take off top to get to console; you should see what else you need to take off to get the console off. There are some screws as well as plastic catches formed into the console that need to be depressed to disengage it. Thanks, please leave feedback or contact me again for more info if you need it.
Posted on Nov 29, 2008
Model 5000 front loader. Why doesn't pump work?
Whirlpool washing machine drain pump replacement and ...
? 17:45
www.youtube.com/watch?v=2abTptUYXH8
Feb 5, 2012 - Uploaded by HandySavesMoney The drain pump replacement procedure will apply to kenmore, whirlpool, maytag and other front-loading washing machines. ...does anybody knows about front loader whirlpool that won¨t start? i could use some help tx.
Oct 07, 2015 | Whirlpool Washing Machines
Washer just finished a load worked fine, went to start new load and power button doesn't work but light for the door is on. Kenmore front loader mdl 40441900
Make sure clothing is not keeping the door from closing right, and the machine has had enough time to reset between loads.
Nov 26, 2013 | Kenmore Washing Machines
Control locked light is on on my whirlpool duet front load dryer and it won't do anything
This advice is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Frigidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your specific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks
Nov 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My HE5t front loader not powering on
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 10, 2009 | Kenmore Washing Machines
My Kenmore Elite front loader has no power.
the power is on but the start button does not start the machine
Jun 29, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore front loader Model 48102 will not start
Mar 14, 2009 | Kenmore Washing Machines
Jan 22, 2008 | Kenmore 44832 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
35 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
