Question about Intel Motherboard
I have a gigabyte g41combo mother board what are the setting in bios and cmos to boots from cd. I tried to set orimary drive to cd and secondary hard drive.Can anyone please gguide me for the same as i am trying to format my pc please reply solution as soon as possible Thanks in advance :)
  • 961 Answers
Http://www.gigabyte.us/support-downloads/download-center.aspx
This is Gigabytes download center. I have loaded your info. Hit search and you can choose VGA"S, BIOS, etc.
Posted on Mar 20, 2011
  • David Petry Mar 20, 2011
    If you need assistance let me know at "add a comment"
    Dave
Need bios password?
Thats why they tell you not to save the information on a file on your hard drive. You should have it written down. I bet you won't make that mistake again!
May 29, 2014 | Acer AZ5771-UR21P 23-Inch All-in-One...
Toshiba Satellite L355D-S7815 re-soldered cmos battery onto mother board and re-set the bios, now I have the f2 and f12 option available, tried to boot cd/dvd drive with windows 8 disk and it will not
Go into the BIOS setting abd check it the BIOS detects the hard disk and CD/DVD drive.
If it detects these drives then go to the boot device order and select the CD as the first boot device then the hard disk as the 2nd boot device.
Apr 03, 2013 | Computers & Internet
Had a problem with my drive getting on internet installed new hard drive now can not boot up dont see drives
it sounds that you have problem in the mother board, you can hooked up your drive to other pc as slave just to ensure if it will read. if ok, then their is no problem in your hard drive also with other drive.
Nov 19, 2012 | Dell Dimension 5100 (D51L1) PC Desktop
What are the setting in bios and cmos to boots from cd. I tried to set orimary drive to cd and secondary hard drive.Can anyone please gguide me for the same as i am trying to format my pc please reply...
please state EXACTLY what motherboard it is then i can give you precise instructions. You need to go into the bios setup and choose boot priority, then select the cdrom as first device changing the primary drive to cd wont work
Mar 20, 2011 | Intel Motherboard
My pc400 will not detect hard drive while in clean window install mode. All primary and secondary are set to auto detect. Boot sequence set to cd while installing from cd rom
You can change the pata cable ,if you have a spare.or fit the cable again.
Follow the link.set for boot priority.
http://www.windowsreinstall.com/articles/bios/
Phoenix BIOS setup and help
BIOS - The setup program used in desktop and laptop computers/PCs - Page 1 of 2
Or you can setup bios "load fail save default"na d pers F10>hit
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Jan 17, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
After replacing on board lithium cell, computer will not boot up. Goes through BIOS ok but no further, even tried replacing hard disk and booting from removable media drives (after setting BIOS...
Did you swap the Cmos jumpers from 1-2 to 2-3 to clear Cmos before replacing battery and if so, did you return them to their original position (normal as opposed to clear cmos)? If the jumper is still in the clear Cmos position, the board will not boot.
Try changing the Cmos battery, it may appear to work but may not be suited to the board
Disconnect all drives except the hard drive, unplug usb and sound cables, if fitted, remove graphics card and either test with another one or use the onboard graphics.
Jan 11, 2011 | ASUS A7V333 Motherboard
Can't enter window
check you cables from drives to mother board make sure they are all pushed in tight
and check the jumpers are set properly on all your drives then retry if it deosn't work you might need new motherboard or one o your cd or hard drives is faulty
Jul 09, 2010 | Gigabyte GA-K8VM800M Motherboard
CANT GET COMPUTER TO START ASKS TO PRESS DEL TO RUN SET UP THEN PRESS TAB TO DISPLAY BIOS POST MESSAGE
Hi:
Not sure what sort of process got you to where you are needing this, but you might try reseting your motherboard by clearing the CMOS , by pulling the battery. If that doesn't help, have your power supply checked.
Nov 10, 2009 | ASUS K8V-MX Motherboard
Blank screen on start up
Try removing all cards with the exception of the video. Remove all memory leaving (1) to boot from.
Disconnect power and reset the processor.
If you have a boot disk or copy of XP on disk, try to boot from the CD or DVD.
If the unit boots at all the problem may be the HD.
If not try downloading the BIOS update for your chipset.
Remove all extra drive, like secondary CD or DVD drives, Floppy or Zip drives.
You may have burnt the processor but I don’t think so.
Power supply is OK or you would not power up. Their are 3 or 4 supply voltages from supply, +- 12 volts, +- 5 volts and +-3.3 volts.
You may have a secondary 12 volt 4-pin plug but that is for on board video.
Try a boot disk and flash your BIOS, if you can.
Hope this helps.
Jul 26, 2009 | Gigabyte GA-M55plus-S3G Motherboard
Disk boot failure
Your boot sector is corrupted you need to install windows again from a bootable windows cd...
Feb 28, 2009 | Intel D845GVSR Motherboard
Intel Motherboard Logo
69 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
