Question about Intel Motherboard
What are the setting in bios and cmos to boots from cd. I tried to set orimary drive to cd and secondary hard drive.Can anyone please gguide me for the same as i am trying to format my pc please reply solution as soon as possible Thanks in advance :)
    President:
  • 1,623 Answers
Please state EXACTLY what motherboard it is then i can give you precise instructions. You need to go into the bios setup and choose boot priority, then select the cdrom as first device changing the primary drive to cd wont work
Posted on Mar 20, 2011
Toshiba Satellite L355D-S7815 re-soldered cmos battery onto mother board and re-set the bios, now I have the f2 and f12 option available, tried to boot cd/dvd drive with windows 8 disk and it will not
Go into the BIOS setting abd check it the BIOS detects the hard disk and CD/DVD drive.
If it detects these drives then go to the boot device order and select the CD as the first boot device then the hard disk as the 2nd boot device.
Apr 03, 2013 | Computers & Internet
Boots only to bios settings, then blank screen after save and exit. will not take a cd boot.
Hello, since it can boot to bios setting, then have you try configuring the boot order,the cd drive should come first,after that your hard disc, if the hard drive comes before the cd rom then it would not recognise it. Change the settings and Save this settings, then try to boot from the cd again, if this does not work then i am rest assured that your hard drive has a problem,and you need to find solution to it by getting a new one. cheers Regards
Dec 01, 2010 | Acer Aspire One Netbook 8.9" Notebook
CANT GET COMPUTER TO START ASKS TO PRESS DEL TO RUN SET UP THEN PRESS TAB TO DISPLAY BIOS POST MESSAGE
Hi:
Not sure what sort of process got you to where you are needing this, but you might try reseting your motherboard by clearing the CMOS , by pulling the battery. If that doesn't help, have your power supply checked.
Nov 10, 2009 | ASUS K8V-MX Motherboard
ASUS P5S800-VM Motherboard configuration
Serial ATA drives are pretty much plug and play. You just need to install them and set them up as a primary drive in your bios settings. The IDE devices can be connected on the same ribbon cable but need to have jumpers set on the back to determine which device is primary or slave. If the IDE devices are on different ribbon cables then most likely the hard drive jumper setting should be set to master or master (single drive). The CD-ROM drive jumper on master. BIOS should detect all drives You also need to assign the boot order in BIOS. CD-ROM should be the first boot device to load and install the new OS onto the primary hard drive.
Mar 20, 2009 | ASUS P5S800-VM Motherboard
BIOS doesn't find SATA HDD
Hi fallacy,
If you have the system disks and you can boot from CD, I would just follow the prompts to reload the operating system. If the computer cannot see the CD or HardDrive you need to reset the BIOS setting to factory default settings and that should restore the drives to be used. Note: Hard Drive should be Primary Master and CD-Rom, (not DVD-Rom if you have one) should be Secondary Master. If you have a DVD Rom drive I recommend unplugging both power and data cords from it and making sure the CD-ROM is set to Secondary Master, NOT Secondary Slave.
This should allow you to boot to a CD and reload the operating system. Unfortunately your files are lost.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Oct 18, 2008 | HP Compaq d530 PC Desktop
Maxtor diamondmax plus 9 6y080l0
If you have you primary HDD set on Cable select, and the secondary HDD is set on anything other then Cable select (with the jumper settings on the back of the HDD) then there will be an error.. Also, if you primary is set to master/slave and the same for the secondary, it will cause problems.
Another thought, if one of your drives is SATA and the other IDE, if the IDE is set to master, there may be an issue as SATA HDD's will try to post as the master drive
Mar 24, 2008 | Maxtor Hard Drive
Harddisk
Check the jumper settings on the back of the drive, if this is the primary HD, set it to master, if secondary, set it to slave, if secondary still does not recognize, switch the ide cable so that the two drives are not on the same one.
Nov 19, 2007 | Computers & Internet
1st and 2d eide conector on mobo
Hi, Does not really matter whether slave via jumper or cable select on the secondary IDE. Your mb will boot to whatever HD you set it at in the BIOS/CMOS as the first boot device. The 3rd drive will be recognized as secondary whatever and if your CMOS/BIOS is set right it will boot from the primary master on IDE1. Good luck and kind regards.
Oct 09, 2007 | Computers & Internet
Install CD won't boot from cdrom drive
Maybe you need to check the boot process in the BIOS and make sure that it tries to start from the CD-ROM and not the hard drive. Usually, to get to the BIOS (I don't know how much of a tech that you are), on start up, hit the "del" key when you turn it on to get to it. Once in BIOS, hit the right arrow button to goto "Boot" and move down to "Boot Priority Device" and make sure that it goes to your CD-Rom first and then your hard drive. Let me know if you have any further questions.
Apr 06, 2007 | EliteGroup nForce3-A Motherboard
Intel Motherboard Logo
35 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
