Question about eMachines eM3502074 Tablet PC
Netbook is in hibernation and i cant get it to work, ive tried holdin power key in for 10 and shutting it down but it still wont come on, ive tried fn and F4 but still nothing.
  • 98 Answers
Turn the PC off, unplug it and take out the battery for atleast 5 min. i had the same problem and this method worked amazingly.
Posted on Mar 20, 2011
I have the trio g5 10 and it gets stuck on the loading screen that says android and wont just wont turn off ....ive tried everything
Hi try holding down power button for approx 30 second's if this doesn't work hold Down power button & volume button at the same time & hope it reboots .cheers
Nov 04, 2017 | Tablets & eReaders
My chrome tablet has a blue dot wont turn on or shut off whats wrong
Shut it down by simultaneously:
Holding down power button
Holding down volume down
Holding down Home button
For 10 seconds.
After shut down, restart it.
Aug 31, 2017 | Tablets & eReaders
Unable to move cursor on lenovo x61
Are you trying to move the cursor with the trackpoint, a usb mouse, or the pen? Have you tried restarting your computer? Restarting would likely solve the problem. If you can't move the cursor to the start menu, you can open the start menu with the windows key, use the arrow keys to navigate to the power options. Use enter to select the power options and shut down or restart the computer. If this does not work, press and hold the power button for 5 or 10 seconds to force the computer to shut down.
What happened before this occurred? Did you install any programs or updates recently, or change any settings on your computer?
Apr 12, 2015 | Lenovo ThinkPad X61 Tablet PC
I have a trio stealth tablet and i locked myself out by fogetting the password, ive tried to factory reset it by holding down power button and volune up buttkn till boot menu comes up but it never gets...
Restart the device and power it on while holding the power button and volume down until the boot screen clears, keep holding the volume down key as this will allow you to get to the root settings and wipe/cache partion resets and delete user install data. :-)
Jan 29, 2015 | Tablets & eReaders
TF700 WON'T TURN ON
There are a couple things to try.
Possible Problem: The tablet may have gone to sleep and a newly installed app or update is preventing the tablet from coming out of hibernation.
Solution: The tablet likely needs to re-start.
The trick is to know whether your tablet is in hibernation (actually running but not screen is turned off) or if it is actually turned off.
Scenario 1, tablet is on but is in hibernation mode
1. Press and hold the power button until you feel the vibrate. Then release. Wait 3 minutes (to make sure the tablet shuts down). After the 3 minutes go to scenario 2
Scenario 2, tablet is turned off.
1. Press and hold the power button. Keep pressing even after you feel the vibration (for about 30 seconds).
Other possible solutions:
If that does not work, then ...
2. Disconnect the tablet from the keyboard and press and hold (same as step 1 scenario 2).
3. If the others methods do not work, connect the tablet to a PC (with internet connection). Leave the tablet connected for a minimum of 30 minutes, but upto 2 hours. With the tablet connected to the PC, press and hold the power button (same as step 1 scenario 2).
If none of those worked, connect the tablet to a TV or monitor using the HDMI connection. If the TV/monitor displays the tablet, then use the display on the TV to reset to factory defaults and force a re-boot. While it is shutting down, disconnect from the TV.
If that does not work, check the user manual for how to reset the tablet to factory default settings.
Last but not least, contact Asus support because you might have to send it for service. But I suspect scenario 1 will work for you.
Feb 12, 2014 | ASUS Transformers Pad Infinity TF700TWIFI...
Frozen screen
Force it to shut down by pressing the power button down for 10 seconds, then release and turn on again.
Jan 15, 2014 | Microsoft Surface RT
My galaxy tab 2 7.0 wont reboot. when I shut it off and turn it back on it wont go past the samsung logo. I have tried to plug it in, it shows the battery icon and its full. I hold the power button down...
At frist turn off your smart tab&then press [(Volume+)+home key] on that time you have to press power key again and again.then you get cwm recovery.then select update from sdcard by using vol - key and click it by using home key.then select your zip file which is dwonload you before for root your phone.
Thank You
-Mitin Sakib
Aug 27, 2013 | Tablets & eReaders
My daughter had a pattern password but forgot it,the tablet wont accept her email and password is there anyway we can unlock it, we have tried to go through the email process but dont work. all we get is...
Hello Jachin, if you still have this problem. Try doing a "hard reset"
- Turn off tablet
- Hold down the power and volume "down" key together
- when red text appears select "yes" by holding down power key for 10 secs.
Reformatting shall commence
Please note that this process works on most android tablets.
Hope this helps
Apr 09, 2013 | Android 4.0 Tablet PC
Hiberation mode ,,what do i do/
Hibernate mode is a power saving feature for computers. In hibernate mode, the current state of a computer is saved to the hard disk, and the computer shuts down. A user will have to power on the computer to restore the previous settings. When a computer resumes from hibernate mode, it reads the saved settings from the disk and restores the system state as it was before it entered hibernate mode. By default, hibernate mode is disabled. If a computer is not ACPI-enabled or APM-enabled, users will have to enter hibernate mode manually. Users cannot set the computer to automatically hibernate after a certain time. With ACPI-enabled and APM-enabled computers, users are able to set hibernate mode automatically
How to enable Hibernate:
Please follow this steps below to enable your Hibernate features:
1. Go to Main screen in your windows then right click your mouse to an empty area in your main menu.
2. After clicking the right click please select the properties then go to Screen Saver Tab.
3. Please Click the Button name Power then click the Hibernate Tab.
4. Please check the CheckBox name Enable Hibernation to enabled the hibernation if it is not hibernated.
5. To try test the Hibernate process please follow the steps in How to start using Hibernate below.
How to start Using Hibernate:
Please follow this steps below to active your Hibernate Features:
Make sure all necessary programs are closed prior to shutting down. Hibernating will put all programs to "sleep," but some programs won't start up properly. Experiment after this to figure out which programs perform as intended.
  1. Click Start and Shut Down,
  2. Point the standby button and maintain the shift key pushed,
  3. A new hibernation button appears: click it while still holding the shift key: voila your PC will hibernate.
Thanks
Aug 07, 2009 | Averatec C3500 Tablet PC
Hibernation
Remove the battery and unplug the laptop. Hold the power button down for 10 seconds. Plug it back in, pop in the battery, turn it back on.  Let me know if that works.
Feb 02, 2009 | Acer TravelMate C110 Tablet PC
eMachines eM3502074 Tablet PC Logo
147 people viewed this question
Top eMachines Tablets & eReaders Experts
Are you an eMachines Tablet and eReader Expert? Answer questions, earn points and help others
