Question about Microsoft Video Game Consoles & Games
I got a error code e74 what's it mean - Microsoft Video Game Consoles & Games
    President:
  • Microsoft Master
  • 1,623 Answers
There is a problem with your graphics chip, if it is still under warranty then return it to microsoft, if it isnt then you will need it to fixed professionally as this is not something that can be fixed by a home user as the chips needs reballing as its a dodgy connection between the CPU and GPU due to a short or bad connection
Posted on Mar 20, 2011
My xbox said error 74 and i dont know whats wrong with it??
"E74"error code is caused by a memory storage device attached to the Xbox 360 encountering a hardware error. You can try to remove the HDD and restart the console without it, if the E74 code won't appear it means that you need a HDD replacement. But if it still does appear, there is a general hardware failure in the system and it might require servicing. You can contact Microsoft Xbox Support for it to be fixed, out of warranty console will be charged $99 dollars by the way. The warranty period is three years.
Thank you !!
Jul 03, 2010 | Microsoft Xbox 360 Console
Code e74 one red light bliking
Thank you !!
Jun 23, 2010 | Microsoft Xbox 360 Console
E74 flashing on my xbox
"E74" error code is caused by a memory storage device attached to the Xbox 360 encountering a hardware error. You can try to remove the HDD and restart the console without it, if the E74 code won't appear it means that you need a HDD replacement. But if it still does appear, there is a general hardware failure in the system and it might require servicing. You can contact Microsoft Xbox Support for it to be fixed, out of warranty console will be charged $99 dollars by the way. The warranty period is three years.
Thank you !!
Jun 16, 2010 | Microsoft Xbox 360 Console
Our 360 has one red light what does that mean
Do you get an error code on the bottom of the screen? e.g. E74, E73, E68 ? If yes, what is it?
May 24, 2010 | Microsoft Xbox Console
Hi what is system error E 74
Thank you !!
May 20, 2010 | Microsoft Xbox Console
I have 1 red light and showing E74
E74 error code is caused by a memory storage device attached to the Xbox 360 encountering a hardware error. You can try to remove the HDD and restart the console without it, if the E74 code won't appear it means that you need a HDD replacement. But if it still does appear, there is a general hardware failure in the system and it might require servicing. You can contact MS Xbox Support for it to be fixed, out of warranty console will be charged $99 dollars by the way.. Cheers!
May 13, 2010 | Microsoft Xbox Console
Getting error code E74. What does that mean??
means the switch inside your device is off.... tear off ( unscrew ) the bottom hatch ( or top ) inside are a bunch of devices. look around for 2 small batteries hooked together with glue... lift them up and underneath is a red switch.... flick it on..... put everything back to normal ( dont gorget the batteries.... if you dont put the batteries back done exactly where they were, your xbox or ps3 or whatever may blow..) now you are ready to play!!
Apr 24, 2010 | Microsoft Xbox Console
E74 fault code. Red light in lower right sector of power display
Try using a lens cleaner these are cheap to buy.e74 and 1 red ring usualy indicates a disk read error
Oct 25, 2009 | Microsoft Xbox 360 Elite Console
Error code E74
Here is what the E74 means courtesy of the xbox scene message board:
http://forums.xbox-scene.com/index.php?showtopic=484726
From my experience it has to do with the two chips on the board overheating. It also explains on the board on what to do.
Sep 02, 2009 | Microsoft Xbox 360 Halo 3 Special Edition...
Problem with my xbox 360
error code E74 probably means that there's something wrong with your so called 'scaler chip' (wich is located near your AV-cable connector).
It can also be caused by a faulty AV-cable so check that first.
In some cases it is a problem with the graphical processing unit and may be repairable by doing the so called 'x-clamp replacement'
A tutorial on how to do the 'x-clamp' replacement: http://xe.brothersoffreedom.com/en/tutorial.php?n=xclampeng
Oct 08, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
32 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
