Question about Denon AVR-886 Receiver
My unit will not respond to the remote control. I performed a reset, which worked only temporarily, now I can't get any control from the remote. Everything on the unit works fine, but I would like to adjust some audio properties. Is there a way to do that without the remote? Is there a process to re-activate the remote?
  • b_cadieux Mar 24, 2011
    yes. Changed the batteries twice just to make sure.
  • 1,591 Answers
I know this may sound stupid, but have you changed the batteries in the remote? they may simply be almost dead!
Posted on Mar 20, 2011
  • Norman Skinner
    Norman Skinner Mar 24, 2011
    open up the remote (if it's not under warranty) and check to see if the emitter LED has a cold solder joint or if the battery terminals have cold solder.
  • Norman Skinner
    An easy test for a remote is to point it at a webcam or camcorder and press a button. The led should flash almost white in the video stream.
Controls on unit does not work
You have to point it at the lower right front corner of the DVD player where the sensor is or the remote doesn't respond.
Feb 02, 2013 | Craig CTFT712 9-Inch Swivel Portable...
My airwell aircon won't respond to my remote, my
FROM THE AIRWELL RC-4 REMOTE CONTROL MANUAL
NOTE THE COMMENT ABOUT THE RESET AND THE SIMULTANEOUS SELECTION OF THE + - SET and CLEAR BUTTONS to effect a reset after replacingg batteries
HOW TO INSTALL BATTERIES Remove the lid in the rear part of the remote control unit.
Insert two AAA alkaline batteries of 1,5 V-DC. Make sure the batteries point in the direction marked in the battery compartment.
The batteries last about six months. Depending on how much you use the remote control unit. Remove the batteries if you do not use the remote control unit for more than one month. Press the +, -, SET and CLEAR buttons together after batteries replacement.
(This operation allows you to reset correctly all the programs. The remote control unit is to be set up again).Replace the batteries when the remote control unit lamp fails to light, or when the air conditioner does not receive the remote control unit signals.
The batteries of the remote control contain polluted substances exhausted batteries must be disposed according to the laws in force.
https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwi_8IKByO3UAhVDVbwKHQB1B5AQFghUMAU&url=http%3A%2F%2Ftrade.jng.com.au%2Fhome%2Ffile%2F9031&usg=AFQjCNGiMLYsIf_M8G3-H0Ccni6xhE_0Ig&cad=rja
Jan 12, 2013 | Heating & Cooling
Panasonic DVD player not responding to remote control
Press enter and 1 on the r/c together for more than 3secs
Oct 17, 2009 | Panasonic DMRES15 DVD Recorder
Garage door opener will not respond to security plus remotes
Reset the Liftmaster unit. There should be a red reset button on the unit in the garage. If this does not work, reset the breaker. Good Luck!
Jul 03, 2009 | liftmaster Chamberlain Garage Door Opener...
Control seems to be working but unit not responding.
Check your remote control by using a camera or cellphone camera as your eyes to confirm if the remote control is ok. Point the remote control transmitter to your camera and check if a light emits in your remote control transmitter. If no light then the remote control is defective, but if the light is present then the remote is ok and the unit receiver board itself is defective.
Check also if there is a reset or rst button on the remote control, press the button and test the remote.
Jan 21, 2009 | Fujitsu 24C1 Air Conditioner
Samsung AS12ABMC A/C (about 3 years old)
heres a clever way i use to check remotes are working. put your mobile phone into camera mode and point your remote control toward the camera while pressing any button.if working you will see a blue light emiting from your remote on phone screen.
Jul 08, 2008 | Samsung AS18A6RB Air Conditioner
AIR CONDITIONER REMOTE
- Check if the battery is ok.
- Some remote control have reset button, you can find it at the front or back at the compartment of the battery push the rst button with pin or ballpen to reset it and try.
- Some remote control have selector switch in both remote control and at the board inside the unit. Try to transfer the switch button from A to B and also at the board inside the unit and reset the remote control and try.Or need to reconfigure the remote control to select the frequency.
- Try your remote control to other unit with same brand as yours to confirm if your remote control is really need a replacement. If it works then your receiver board in the unit is need a replacement. Or if wont work then you have to buy a new remote control. But if you have no budget then try to switch on the unit using emergency button to operate the unit.
Dec 26, 2007 | Heating & Cooling
It is not responding
This is one of the best solution to do, look for unit who have same model as your unit( to your friends or neighbors) and test your remote control. If it wont work in another unit with same model then the remote control is defective, but if it works then its the receiver.
But try this solution first, if there is a reset button in your remote try to reset it then try the remote to your unit.
Note: sample only(reset button can be found either infront or at back of the remote control inside the battery compartment.)
Nov 27, 2007 | Heating & Cooling
Split system airconditioner Panasonic model CU-A28CKR.not responding to remote
Try turning of the power to the unit.Wait 60 seconds and try it again.This may reset the unit.
Nov 24, 2007 | Heating & Cooling
Denon AVR-886 Receiver Logo
164 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
