Have LG Brada front loader washing machine - door wont unlock - showed nd on the display - how do I get the door to unlock
    Brigadier General:
  • 6,277 Answers
'nd' for LG's is likely to indicate 'no drain'. I would advise cleaning the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside. Once the water is removed the door should unlock.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 20, 2011
The door on LG front loader washing machine won’t unlock
hi Margaret.
If the washing machine malfunctions or you need to stop the cycle and retrieve the clothing, you can force the door to unlock.
  • Open the door after the "Door Lock" indicator turns off. ...
  • Press the "On/Off" button, if the washer is not already on.
  • Select the "Spin Speed" button to turn on the Drain & Speed cycle.
  • or go to this link and have a read up.
LG front loader washing machine wont unlock Google Search
Dec 12, 2017 | LG Washing Machines
How do I unlock door of LG front loader washing machine
If all else fails, use a length of taut cord to squeeze between the door and the water seal to pull back the catch.
Jan 25, 2015 | LG Washing Machines
Lg front loader wd-8050fh door wont lock
Hi just read your posting.Sounds like the door lock switch is faulty.Do you get any error codes on the display?Check the door latch that is attached to the door.It is the little hook that latches into the door lock switch.The tension on the hook should be quite firm.Please reply with answers to the question and the condition of the door latch.Looking forward to your reply.
Jul 14, 2012 | LG Washing Machines
LG WD12020D Inverter Direct Drive 7.5kg front loader. Has never had visible water level in the drum. I have even stopped the machine, turned off the power, waited for the door to unlock, pushed the wet...
No water that high. But you may have an extra water button that allows you to add slightly more water to each wash load. Water should be just above bottom of inside drum in the back of the drum as it rotates
Jul 01, 2017 | LG Washing Machines
My maytag front loader washer is saying nd so i turned it off but the door wont open to get the cloths out how do i get the door open ???
Hello
ND error in your Maytag Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Kevin
Nov 08, 2010 | Washing Machines
Can't get the door to unlock? Load in washer is beeping ND..not draining but after several attempts inlcuding shutting power off..still can't get the door to disengage?
In front loader machines there is a safety latch that stops you from opening the door if there is water in the machine. I think it needs power to release the latch, I am not familiar with this model.
You probaly need to drain the water off somehow.
Dec 16, 2009 | Maytag MAH2400A Front Load Washer
My Maytag Neptune Washer showed "nd" on the display screen, and now the door will not unlock. What can I do?
ND is NO drain
The water level fails to drop below the Low Water level reset within 15 minutes, before a spin begins.
Sep 22, 2009 | Maytag Neptune MAH6700A Front Load Washer
LG Sense Clean DD error code "FE" front loader washer/dryer combo
my lg senseclean wash mashine shows the sign Cl on the display and the door cannot be open what does it mean?
Jan 03, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
LG INTELLOWASHER DD 7KG
You may need to have the door switch replaced but before that should be done, make sure the wire connector is securely in place.
Sep 02, 2008 | LG WM1814CW Front Load Washer
Front loader washing machine
This is normal, the unit usually goes into a SD or slow down mode. To stop this press the start pause button and the door will unlock.
Sgt 48
Jun 04, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Washing Machines Logo
324 people viewed this question
Top Washing Machines Experts
