Question about Ikegami HL-DV7AW Camcorder
Ikegami HL-DV7AW Camcorder Writes down a sound and video only the black
  • 17,130 Answers
Did you mean that the video is recorded only in black and white. Please confirm that if this was what you had meant.
If so the fault must be checked with you display unit, check if the format matches the display unit.Also if this is also seen as B&W on the LCD display then the fault can be failure on the processing board.
This will require a highly technical work and must be checked, confirmed and estimated by a authorised service center.
Posted on Mar 21, 2011
My camcorder will record sound but not vision any Ideas
Does the recording show a black image or no video signal? If the image is black, is the cover being left on the lens? Is the lens broken or something perhaps internally obstructing its view. If there isn't a video signal, and it reads as only an audio file than have you checked you've set the camcorder to the correct setting so the video camera portion is turned on?
May 04, 2014 | Canon MV630i Mini DV Digital Camcorder
I need a lens for my ikegami HC200. Jose
You can look for any 1/2" B4 Mount lens on the market. I'd go for a Canon PH Lens (especially a PH15x7B or a PH14ax6.6B). Lenses ending with KRS have no extender, lenses ending with IRS are with extender, lenses with an "a" before the x are internal focusing lenses. They sell for about 80$ to 400$ depending on condition.
Dec 03, 2012 | Ikegami HC-400W Camcorder
SD Card locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 06, 2012 | DXG DXG531V Digital Camcorder 3 LCD CMOS...
Coby camcorder cam 4000 Model 716829640005 sd card locked when I turn unit on Cannot take pictures
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jul 16, 2011 | Coby CAM4000 Flash Media Camcorder
How do I find the hours of operation on the camera>
The answer wiII be in your manuaI. Search for "hours of operation" or "totaI hours of operation", etc. I tried to find a manuaI onIine to Iook it up, but couIdn't find one, so this is the best advice I can offer.
Good Iuck, and hope this heIps.
Jun 09, 2011 | Ikegami HL-DV7W Camcorder
How do you unlock card on a jazz dv150 camcorder?
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 02, 2011 | Jazz DV150 Camcorder
Hi! Panasonic Digital Camera would be my need NV-GS15 his software Windows the 7. -hez. Please writes it from where I would be able to download it. Best regards:
May 07, 2011 | Panasonic NV-GS150 Mini DV Digital...
I have just purchased a KWorld DVD Maker 2 and set it up as per instructions and the DVD Maker itself says by pushing the button it will start flashing blue, well this does not happen and it gets very...
The 1 yellow and 1 black female outlets are likely for RCA Phono jacks and older VCR connections. DVD Maker sounds like you would use a camera that has USB cable to the computer and the computer writes DVDs using the Kworld DVD Maker 2.
If this is an older (1990s) camcorder with tape, then it won't work with your computer or DVD player.
I'm not sure by your description what Sony video camera it is, exactly.
One can look this up at the sonyusa.com website.
Aug 17, 2010 | Cameras
How do I tranfer video from my camcorder to my computer?
Hello there...
There is another way to transfer video from you camcorder if you camcorder support USB streaming. I usually use this method with my Sony Camcorder because more simple and don't need additional hardware.
Steps:
1) Install you camcorder driver to your PC/laptop.
2) Connect your camcorder to PC/laptop.
3) Open Windows Movie Maker.
4) Create a new project and select source input device to your camcorder.
5) Start record on your Windows Movie Maker application and press play on your camcorder.
6) Wait until camcorder finish playing and press stop in your WMM.
7) Save the file as WMV (later you can convert to another format using any video converter or even burn to CD)
PS: you can even edit the movie frame or add some opening text or end credit.
Hope this helps.... :D
Mar 27, 2010 | Video Cameras
Missing parts
Give up now mate! It was a great kit in 1986 but cameras have moved on get a HC 400 OR the new HC 500 that came out in 2005 Its still standard def and relies on a dockable recorder with the appropriate adaptor but it is light years away fron your HC200 you might want to use the DVCAM format which is proven recorder like a SONY DSR 1 OR for Europe the DSR 1P the P denotes PAL format. it bolts to the dockable camera head.
Regards
Andy
Woodland.studios@btconnect.com
Mar 11, 2009 | Ikegami HC-400W Camcorder
Ikegami HL-DV7AW Camcorder Logo
51 people viewed this question
Top Ikegami Video Cameras Experts
Marvin
Marvin
Are you an Ikegami Video Camera Expert? Answer questions, earn points and help others
