My computer will not pick up my drive when i put it in
    Master:
  • 389 Answers
The windows disk management utility will help solve this issue most of the time. Use the directions below:
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections.
The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive that is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters "F" or "G". In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
If you found this answer helpful, please remember to leave positive feedback.
Thank You,
Brian
Posted on Mar 20, 2011
How to copy micro soft word files from computer C drive to a CD in computer E drive using windows 8.1
Try Burnaware
Put at a CD in the E: drive.
Pick the Data disc, and compilation and then "add files".
Then you can select the files you want to from drive D:
And then Burn the files to the CD-ROM. Free Burning Software and DVD Copying Software BurnAware
Mar 05, 2015 | Dell Computers & Internet
How do i reformat usb flash
Stick in your USB port, start Explorer (for the computer, not the internet) then right click on the drive letter of the flash drive and select "format" from the drop down menu.
Jun 25, 2014 | Electronics - Others
Circuit board
Circuit board short circuit on your ext. hard drive?
Remove the drive from it's casing and put it in a new case... you can pick a new case up from Maplins and most computer shops.
Nov 07, 2013 | Toshiba Computers & Internet
Power supply compitable for cac-to5-uw?
ATX is a standard.
Any case described as ATX should accept any ATX powers supply.
The only thing you need to decide is how many watts the power supply needs to provide.
To find this out, put "Computer power supply calculator" into Google.
Pick one, or several, and enter the details of what you are going to put in the case.
Enter what you would like to put in the case finally, not just the bits you have to start with.
Like that second internal hard drive, and double the memory, Two DVD drives.
Extra cooling fans?
Then pick a pick a power supply that provides more than that.
No-one has ever run into problems with a power supply running too cool.
Feb 10, 2011 | Cooler Master Elite ATX Midi Tower Case...
L have so many hard disk drives(sea gate, western digital, max star) but when put in a computer they are not seen even when l change the jumpers.
Hi sky
Try installing 1 of the drives as slave,or cable select if you're familiar with that method,and then start it up.
Right click on the "My Computer" icon,then pick 'Manage",then down toward the bottom "Disk Management".
When your list of drives comes up,make sure that the new addition has a letter assigned to it.You need to choose the drive on the bottom listings,not at the top.Rt click on it,choose "change drive letter and paths..." then pick a letter to assign.
That might do it,let me know.
Good or bad,please rate my post?
Bob
Aug 11, 2010 | Seagate Barracuda 7200.7 40 GB Hard Drive
Unknown
Try to put new cd or dvd that you know the other PC can read.May be the one your putting on has file that had been corrupt.
Try cleaning the Optical lens with Q tips dip in alcohol(isopropyl).
Open the device manager and Uninstall the CD/DVD drive from device manager.and let the windows force install it.
Mar 17, 2009 | LG SecurDisc 8x External Double-Layer DVD...
How does sandisk 1 gb work and where do i put it?
If you have a sd card reader on your computer then simply slot it into the card reader and windows will pick the card up so you can transfer (copy paste, or cut and paste) the pictures onto your computer. Or is you have not card reader on your computer you can by a sd card adapter that can slot inside the usb port and will do the same thing a card reader would. They are very cheap and can be picked up in most electrical outlets that deal with pc's
I hope this helps
Dec 30, 2008 | SanDisk 2GB microSD Memory Card
Emachine 3623 boot up??
probley computer crash ,dont say what system you using try getting a onther copy of windows opeting system put in you cd drive and should pick it up, if not go into boot sequence in bios and d-drive your boot up first it should give you fresh operating system and maual load the drivers for your hardware manual if it has picked up
Oct 05, 2008 | E-Machines eMachines Desktop PC
Hard Drive -- Dead Computer
Jim
You can buy an external USB drive enclosure, mount the drive in the enclosure, then connect the old drive to the new system.
here is a popular model:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817729001
if teh old system is a portable, then there are 2.5 versions also available
Jun 25, 2008 | Computers & Internet
Computers & Internet Logo
109 people viewed this question
Alun Cox
David Payne
David Payne
