Question about Home
I have just had my bathroom done and the builder didn't clean the grouting off the tiles afterwards and now i am left with a grout haze. i have tried washing with a sponge several times, washing with a half water half vinegar solution and scrubbing with a deck scrub brush all to no avail it just won't go away. is there any solution i can use to remove it?
  • 2,510 Answers
Try using a mild abrasive patent cleaner with Scotchbrite pads. This would be about the least invasive method of harsh cleaning, which you seem to need. If that does not work, there are industrial strength acid based cleaners available. These are extremely harsh and need to be used with care, gloves, eye protection old clothing etc, and adequate ventilation. Another less aggressive cleaner (I cannot vouch for its effectiveness) is equal measures of ordinary table salt and Baking Soda mixed together and used as an ordinary scouring powder - it would probably work better with Scotchbrite pads. Although the glazing on tiles is tough, it can be scratched and the luster take off with harsh treatment, especially if the tiles are of the very smooth type. Good luck.
Posted on Mar 20, 2011
How to I clean the grout on my kitchen floor?
There are many ways to clean stained grout. You could try one of the commercial cleaners sold on the market and scrub it with a brush. You can also try creating your own cleaning solution. This way you will avoid using harsh chemicals in your home, which is always a good thing. You could try making a paste of baking soda and some water and use it to scrub the grout with, or you could spread some baking soda on the grout and then pour some vinegar on it. After about half an hour you should be able to scrub off the dirt easily. In some cases the grout is so dirty, that the only option is to remove it and apply new one. You can check the website attached, the professionals there know a lot about tile cleaning and maintenance.
Oct 06, 2015 | Vacuums
How to clean glass tile after installation
Follow the steps
1.Rub the grout haze with a dry cheesecloth. Shake out the cheesecloth as you work to remove grout dust.
2.Scrub the glass tile with a nylon bristle brush and warm water if cheesecloth doesn't work. Wipe away the loosened grout haze with a sponge as you work. Avoid using the nylon bristle brush in the grout lines of recent tile installations, as the stiff bristles may loosen or cause damage to the grout.
3.Mix a solution of 1 cup of white vinegar to 1 gallon warm water if haze remains on your tile. Scrub the grout haze with a nylon bristle brush dipped in the solution, wiping away the loosened grout haze as you work. Continued use of vinegar can weaken grout, so only use this method to remove haze and not for regular cleaning of glass tile surfaces.
4.Apply a commercial tile cleaner to the glass tile if the previous methods fail. Scrub the haze gently with a nylon scrubbing pad, letting the cleaner do most of the work. Rinse off the tile cleaner with clean water. Use a tile cleaner that is labeled for use on glass tile.
5.Remove the grout haze with a tile cleaner containing phosphoric acid or sulfamic acid as a final resort. These acids are safe to use on glass tile and are highly effective for removing grout haze. Avoid using phosphoric acid on colored grout, as the acid may cause bleaching or discoloration. Read the labels of these products carefully before using, and follow all manufacturer's safety precautions.
http://www.regalotiles.com/productinfo/details/terrazzo-terrasso-polishing/17
Oct 06, 2015 | Bellavita Tile Glass Tile - Bellavita...
How to repair bathtub tile grout.
I would say to get a putty knife and try to carefully chissel out the grout thats there, and regrout it. Reply to my answer if you need to know how to actually grout
Oct 27, 2013 | Home
Best way to clean grout
I have used a solution of Baking soda and water....with a toothbrush but it only gets some of the dirt up.
The best thing to do is redo the grout and then SEAL it. The sealer seems to keep the grout looking like it's natural color for much longer.
My bathroom needs to be done right now and I was just starting to think about this.
I might try to do it myself first and if that small area doesn't go well then I might need to call my tile guy.
You should never clean the grout with a cleaner. That's what my tile guy said. Just water.
Chemicals turn the color quicker
Apr 05, 2012 | Maytag Vacuums
How install the soap dish
There are a couple of designs, one is surface mount and the other is recessed. Surface mount mounts with silicone (hard to imagine it would last) and the other installed similar to a tile, but using grout. The grout install gets a hole cut in the tiles, goop everything up with grout, and goosh it into the wall, clean same as you would when working with grout.
Both designs need support until the adhesive dries.
Dec 12, 2010 | Daltile Bathroom Accessories Resin Soap...
Hi I moved in to a recently renovated home one year ago. The kitchen had new ceramic tiles installed, with sanded grouted filled in the 5/8 inch joints. I sealed the grout after moving in as I was told...
I have a similar problem. My builder used dimensional lumber for the joists. I asked him if thet would be sufficiently stiff for tile floors, and he said yes. Then after the cracks started, I asked him why the cracks, but he said he didn't know why. It's not necessarily the subfloor but the combination of joists, subfloor, and concrete backer boards under the tile. If you can access the joists under the floor, perhaps you can reinforce them with additional joists or stiffeners before regrouting.
As for me, I have done neither so far. Wife has not complained, so I spend my spare time helping people on FixYa. Like you, I fear regrouting will just lead to recracking, and I no longer have access to the joists. :o(
By the way, your question was sorted as a Harley Davidson question. You weren't riding you bike in the kitchen, were you?
Sep 10, 2010 | 2003 Harley Davidson XL 883 R Sportster
Listello resin 3 by 12 : tile;white grout stuck on the tile
yes, you should seal all tile with a 3-5 year sealer. there are many brands to choose from. excess grout should be removed with a sponge and water before it dries. clean food splatters with any safe kitchen cleaner.
Jul 31, 2009 | Daltile Bathroom Accessories Resin Soap...
Home Logo
120 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
