How do i find my password or key on my wirerless modem
    Genius:
  • 1,098 Answers
The default password is password. If you no longer remember it, you can reset the modem to it's factory settings.
Locate the small hole on a the router, push it with an unfolded pin for about 10 secs until the lights go out. Your modem is back to default settings after that. Default password is password.
Thank you!
Posted on Mar 20, 2011
  • 98 Answers
The modem only gives your router an ip in order for it to communicate with your ISP (internet service provider).
1. turn off your wireless antenna and plug you PC directly into the router with an Ethernet cable. then type 192.168.1.1 (linksys) or 192.168.0.1 (D-link) go into the security settings and your key will be displayed
Hope this helped plz rate thx
Trying to connect to internet to down load netflix. Error code 51330 ~ unable to connect. Wirerless connection locked w/ password to SSID OWNER-PC_network. Input password and error code appears each...
Are you sure that you're selecting the right type of key? [[WPA or WEP]]
Other suggestions:
  • Did this connection used to work but has suddenly stopped? "Power cycle" your router and modem. To do this:
    • Unplug both the modem and the router from the power outlet.
    • Wait a few minutes, and plug the modem back in.
    • Wait a couple of minutes for the modem to initialize, then plug in the router.
    • Try to connect the Wii online and test for proper response
  • Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker.
Jul 09, 2011 | Nintendo Wii Console
Where do i find the wpa on my modem?
How to find your computer's WPA key Step 1: First of all, you need to launch an internet browser. Press "Windows + R" keys to open the "Run" prompt and type "iexplore" without quotes to open Internet Explorer. You can also type "firefox" to open Mozilla Firefox. On the address bar at the top, type http://192.168.1.1 (Belkin routers use 192.168.2.1 as the default IP) and press "Enter" key.
This address belongs to your wireless modem or wireless router to which you are connected.
Step 2: A window asking for username and password will appear. In the username field, type "admin" without quotes and in the password field, either type "password" without quotes or leave the password field blank. Press "Enter" key to continue.
If password is correct, you will be redirected to the modem/router's "Settings" page, otherwise, you will have to reset the modem/router. Check beneath the modem/router or check the manual for correct password.
To reset a Linksys modem/router or Belkin one, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
Repeat the step 2, in order to gain access to "Settings" page.
Step 3: On the modem/router's "Settings" page, find "Wireless" option. Click the "Wireless" link to populate the wireless settings. Now, locate and click the "Security" or "Advanced Security" option.
On the security page, you will find "Network Authentication". Different options available under the Network Authentication menu are open, shared, WEP, WPA, WPA2, WPA-PSK, WPA2-PSK, etc. Select either WPA or WPA2, to find your computer's WPA key and insert this key when asked for.
If in step 2, you had reset the modem/router, you will not find any WPA or WPA2 key, and you will have to manually assign one. Select any of the WPA-PSK or any other authentication and assign a key to it. A key can be 8-63 long. For minimal security, you can choose 8 characters key, like "iN\/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBD\m+oMp$nrXj5XPVRTvVA5fpwGSGI\RVz4RdQ7V3y\l$P1NrT9Be".
After you have assigned a key, save/apply the changes and reboot the modem/router.
Note: The procedure shown above is common to most of the modems/routers. If this doesn't apply to you, check your modem/router's manual to find the wireless security option.
Read more: http://www.brighthub.com/computing/smb-security/articles/44810.aspx#ixzz1FOMsyJkq
Mar 01, 2011 | Video Game Consoles & Games
What is a security key
WPA (Wi-Fi Protected Access) is an advancement over WEP (Wired Equivalent Privacy). While connecting to a home network, you are often asked to insert a WPA key or a password to which users often ask, "How Do I Find My Computer's WPA Key?" WPA stands for Wi-Fi Protected Access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over(Wired Equivalent Privacy) Wep is standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
While connecting to your home network, you are often asked to insert a WPA key. This WPA key is either located in the modem or in the router you are using. In order to find your computer's WPA key, follow the steps given below:
To Reset a modem/router, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Jan 20, 2011 | Buffalo Technology AirStation Nfiniti...
Error code 051099-1
This seems to be a problem with your wireless router. Check to make sure you put in the proper WEP/WPA Security Code. If you aren't sure what I'm talking about...
Jan 01, 2011 | Nintendo DSi Blue Console
Hi i want to have internet on my PSP but it says type your wpa key and i dont know it.
It's a bit different for each router but I can show you how it would look in a regular setting:
Jan 01, 2011 | Sony PSPgo White Console
How to find the network key in my modem
I'm assuming you are talking about a wireless router requiring a security access key. They are password protected. If you don't have the password your only option is to reset the modem (literally, press the reset button) and set up a new password. If you have the setup menu password you can log on to the modem and look at the wireless configuration menu. Some models allow you to actually view the password - there is a toggle setting that changes the password from **** to displaying the actual characters.
Sep 19, 2010 | Computers & Internet
I don't know where to locate the network key for my belkin g wirerless router so I can connect to the internet
connect any one of the computers to the router with a ethernet cable. open internet explorer, clear out the address bar on the top, and type 192.168.2.1. when u hit enter, u'll get a router set up utility. in this page u'll have an option -security- below "wireless". when u click security, it'll ask for a password, leave it blank and hit submit. on the next window, u will find the password there.
Aug 15, 2010 | Belkin (F5D7230-4) Router (587009)
What Is The WEP For A Westell Modem, Model 7500 A90-750015-07
The WEP key is located on the silver label on the bottom of each unit under the Serial Number and is clearly marked on my unit.
Mar 21, 2009 | Computers & Internet
2 wire modem
look at the back of your two wire modem, you would find a 10 digit number that would be the default password, try it out, or else you need to login to your modem setup page to get the wireless settings, contact 2 wire they would help you to login and get the wireless settings
Jan 20, 2008 | 2wire (1000-000057-000) Modem
Print server software stops at select a printer
did you verify that the HP6210 is supported?
Oct 29, 2007 | IOGear GPSU21 Print Server
Computers & Internet Logo
Alun Cox
David Payne
David Payne
