Question about Visonik Vpb210pk Complete Dual "10" 1,000 Watt Subwoofer System with (2) "10" Subs in a Factory Matched Sealed Enclosure Box + 1,000 Watt Amplifier + Compelte Installation Kit
Instructions for the 500 watt amp - Visonik Vpb210pk Complete Dual "10" 1,000 Watt Subwoofer System with (2) "10" Subs in a Factory Matched Sealed Enclosure Box + 1,000 Watt Amplifier + Compelte Installation Kit
1/remove positive cable from battery.2/install rca jacks to rear of your radio/unit.3/find a suitable safe out of veiw area to mount amp with adequete ventilation [because it will get hot] .4/run and tuck your rca's agian outta site,never in a door jamb.5/also most install kits have a auto on/off wire that runs with the rca wires,that gets tied on to your power antennea wire on the stereos wire harness6/once you have rca,automatic on/off hooked,or near your amp ready to plug in.,you can then , cut as short as possible ,the ground wire[that should be black in color]the shorter the ground wire ,the less feed back you will get! under 14 inches is best .mount the ground very secure under a front seat, loosen a mounting bolt to the seat then wrench tight[making sure it is metal to metal,no paint can be in between contacts then run the power wire [red to red] straight to your battery positive cable [very securely] you should find a access point to push the wire thru the firewall someplace do not hook up the battery though finish runnin the power wire to amps destination after the amp is secure ,add power wire plug ins to amp then runn your speaker wires to box re-attach battery terminals [will be a small spark ] dont panic . upon turning on listen to your favorite song loud,so you can adjust the amplifier to yer liking
Posted on May 21, 2011
What are some best cheapest bass amp under 500$?
'Best' and 'Cheapest' are seldom in the same category, but have a read of these links.
12 Best Subwoofer Amplifiers for Your Car or Truck - BestProducts.com
www.bestproducts.com/cars/parts/g662/subwoofer-amplifiers-for-your-car/
  1. Cached
  2. Similar
Jul 19, 2016 - If you want big bass, choosing the right subwoofer is only half the battle. Be the loudest car on the block with the help of these new mono amplifiers for your car or truck. ... 14 Best Rubber Floor Mats for Your Car or Truck.
Best Car Amplifier 2016 ' Top Rated Auto Amplifiers - CarAudioNow
https://www.caraudionow.com/best-car-amplifiers/
  1. Cached
Looking for the Best Car Amplifier of 2016? ... And if you are going to add a subwoofer, a monoblock amp is an absolute necessity. ..... Two-channel A/B ZRX516.2, 500 watts; Four-channel A/B ZRX616.4, 600 watts; Four-channel ... (PCBs) that can perform under the most rigid and extreme conditions attesting to the brand's ...
Bass Packages Under $500 at Crutchfield.com
www.crutchfield.com > ... > Car Audio, Video & GPS > Car Subwoofers & Boxes
  1. Cached
Under $500 - Shop for Bass Packages with the help of real A/V experts. ... package includes Magna Bass MB212P mono amplifier (250 watts x 1 at 4 ohms) and ...
Can you guys recommend me a combo amp under $500? ' TalkBass.com
https://www.talkbass.com > ... > General Forums [BG] > Amps and Cabs [BG]
  1. Cached
Jan 19, 2012 - Hey guys, I'm currently in middleschool and I need a new amp thats preferably 400-500 watts, but under $500. We currently have a bassist, ...
Need good advice on a sub+amp combo, $500ish budget - Car Audio ...
www.caraudio.com > Forum > Car Audio Discussion > Subwoofers
  1. Cached
  2. Similar
Oct 13, 2012 - 12 posts - ‎1 author I'm new to both the forum and somewhat new to car audio in general so please excuse any ... So i need a great sub and amp to complement them for around $500. ..... other subs for under 200 bucks id rther have over type r
World Record Budget Build w/ Drew Wesley's $500 Car Audio System ...
z? 2:32 https://www.youtube.com/watch?v=NOatL_DzZL0
  1. Similar
Oct 3, 2013 - Uploaded by EXOabigdeal World Record Budget Build w/ Drew Wesley's $500 Car Audio System ' 4 12" VVME Subs & Bass Amps ...
Top 10 Best Car Amplifiers To Buy for 2016 - MyCarNeedsThis
mycarneedsthis.com/todays-best-car-amplifiers/
  1. Cached
Whether you're looking for an amplifier to power your entire cars component speaker ... power outputs come in 3 settings (of 800 watts, 500 wats, and 300 watts ). ... Rockford Fosgate R750-10 Class D 4-Channel Subwoofer Amplifier ... Talk about power when it comes to getting some serious knocking under the trunk.
Oct 30, 2016 | Car Audio & Video
I have 2 15" dvc 4 ohm kickers 1000 watt / 500 rms &a1000 watt avionixx 4 channel amp what would be the right wiring scheme?
need to know the ohms on the amplifiers then might can tell you best solution for system
Mar 05, 2013 | Car Audio & Video
Given 1hp motor how to compute the exact amount of amphere use in circuit breaker
You're not going to be able to do this with just a known Horse Power.
There are 3 elements to the equation, with any two, you can work out the third.
If you want to know how the amperage, you will need to know the voltage and wattage of the motor. I imagine that you already know the voltage (It's going to be 220V or 110 volt)
Watts divided by volts = Amps
Examples:
A 220v 1000 watt motor (1000 divided by 220) will draw 4.55 amps
A 110v 800 watt motor (800 divided by 110) will draw 7.27 amps
Bear in mind that most washing machines have a couple of windings for wash and spin. As an average, the was winding will usually be about 500 watts to spin and about 250 watts to wash. ALSO, bear in mind that if you are using this data for a WASHING MACHINE, then there is a water heating element in there too and that draws about 2Kw (2000 watts)
Dont just take this as read, you DO need to check wattages, but, working on what I have just said, the max consumption on a 220V machine will look like this:
At Spin, with a 500 Watt consumption: (500/220) = 2.3 amps
While Washing with a 250 watt consumption: (250/220) = 1.14 amps
Consider that the WASH and HEAT may be running at the same time.
2Kw heating (2000/220) = 9.1 amps PLUS 1.14 amps for the motor - Total wattage 10.24 amps
Watts / Volts = Amps
Amps x Volts = Watts
Watts divided by amps = Volts
Aug 25, 2011 | Washing Machines
What is the standard plug for stoves newhome el916. Is it the general 13A plug
I can't find an online manual for the model of the appliance you are talking about, so I'm unable to figure out the wattage it draws. Nor do I know where you are in the world and the voltage you are running at, so I can't tell you straight off. But I can tell you how to figure it out very easily:
I imagine that know what your main power supply voltage is (either 240 volt or 110 volt).
You can look at the appliance and there will be a data sticker with the wattage rating on it somewhere (or it will be in the install/Owner manual).
Now you have these 2 bits of information we can do a simple sum:
Watts divided by Volts = Amps
Therefore example calculations look like this:
If you have a 500 watt appliance on a 240 volt system 500/240 = 2.083 so use a 3 amp fuse
An appliance with a 750 watt motor on 240 volts: 750/240 = 3.12 so use a 5 amp fuse
A 2KW (2000 watt) appliance like a hot air blower on a 240 volt system: 2000/240 = 8.33 amps so use a 10 amp (or more commonly 13 amp) fuse
A 500 watt motor on a 110 volt supply 500/110 = 4.5 so use a 5 amp fuse
A 1KW (1000 Watt) appliance at 110 volts: 1000/110 = 9.09 amps so use a 10 amp (or more commonly 13 amp) fuse
etc etc etc.....
If the sum comes out below 13 amps, you can use a 13 amp plug. If it doesn't you need to hardwire it into a proper cooker supply.
Jul 29, 2011 | Stoves Ovens
How many amps a fuse in breville mixer
Not knowing the model of the mixer you are talking about, or where you are in the world and the voltage you are running at, I can't tell you. But I can tell you how to figure it out. Simply do this:
You obviously know what your main power supply voltage is, either 240 volt or 110 volt
You can look at the mixer and there will be a data sticker with the wattage of the motor on it
Therefore, if you have a 500 watt mixer on a 240 volt system 500/240 = 2.083 so use a 3 amp fuse
a 750 watt motor on 240 volts 750/240 = 3.12 so use a 5 amp fuse
a 500 watt motor on a 110 volt supply 500/110 = 4.5 so use a 5 amp fuse
etc etc etc.....
Hope this helps
Jul 26, 2011 | Microwave Ovens
Installation instructions for a Kinter MA- 150 500 Watt 2 Channel Amplifier CD.dvd.mp3.USB
hi I'm Linda the kinter ma-150 car amp 500w what watts speakers can u put on it can u put 180 ways on or is is not build for that find me on Facebook lindavanzyl I'm a young blond 18 years old
Jul 13, 2011 | Car Audio & Video
Need Aube by Honeywell TI032-3W-5/U instructions
http://waterheatertimer.org/pdf/Aube-TI032.pdf
Manual for Aube T1032
Internal rechargeable battery
7 day programmable timer for halogen, incandescent, florescent
Aube T1032 has 40 Watt mim & 500 Watt maximum (5- 100 watt incandescent bulbs etc)
Buy Aube-1033 for heavy 20Amp 2400 Watt maximum
Replaces single-pole switch or 3-way switch (slight modification needed in 2nd 3-way switch)
Buttons
Oct 12, 2010 | Honeywell Aube by TI0323W5U 7Day...
Ppi dcx 1500.1 is it 2 powerful 4 da 12in. L7?
Hello montyski20,
The amp outputs 500 watts RMS into 4ohms, 750 watts RMS into 2ohms and 1000 RMS into 1ohm.
The L7 can handle 750 watts RMS (375 watts per each coil). If your L7 is the 2ohm version, you should wire the voice coils in series, the positive marked coil to the negative unmarked coil. Then connect the remaining positive and negative to the amp terminals. This gives you a 4ohm load (500 watts). If your L7 is the 4ohm version, wire the voice coils in parallel, both marked and unmarked positives together, likewise both negatives and then to the amp terminals. This gives a 2ohm load (750 watts).
Paralleling the 2ohm sub will result in a 1ohm load (1000 watts) and that is too much for the L7.
Hope this helps.
Aug 02, 2009 | PPI DCX-1500.1 Car Audio Amplifier
I have a memphis amp that puts out 250 watts @ 4ohms and 500 watts @ 2 ohms. I want to hook up 3 sony 12'' explods @ 4 ohms a piece. How do I wire them to the amp to get the maximum output of 500 watts?...
well to be honest your amp probly cant handel 3 speakers because of the impedance levels so just hook up 2 bridges out to + to - on one Speaker then from that same speaker run + and - to the next one
A= amp
S= speakers
A:::::::::::::::::::::::::::::::S:::::::::::::::::::::::::::::S
Mar 22, 2009 | Car Audio & Video
Visonik Vpb210pk Complete Dual "10" 1,000 Watt Subwoofer System with (2) "10" Subs in a Factory Matched Sealed Enclosure Box + 1,000 Watt Amplifier + Compelte Installation Kit Logo
167 people viewed this question
Top Visonik Car Audio & Video Experts
xxxxxx xxx
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
