I have a problem with my PiN&iP address setup.
  • 98 Answers
You dont have to set anything up.
just try connecting to the router and if it fails to connect then all you got to do is click the diagnose and repair button. this usually solves the problem, sometimes it will just tell you whats wrong because it needs admin privileges to perform the action.
feel free to re-write to me
hope this helps plz rate thx
Posted on Mar 20, 2011
Setting ip address
go to host interface< network setup < select ip address & subnet mask & gatway. then save
Jan 08, 2014 | Printronix P7220 Matrix Printer
Pin
1) reset your browser (internet explorer).
2) connect your access point (AP) to your pc directly using LAN port and CAT5 cable
3) type in default IP address of AP->192.168.0.50 (Or Current IP address of Ap) in browsers address bar.
4) username = Admin and blank password (i.e. password is no text)
5) Click on Advance Button then click on Wi-Fi Protected Setup button on left menu pan.
6) See the image below record your current pin, if you wish to change it just press generate new pin button.
7) Don't forget to say thanks :)
Apr 13, 2013 | D-Link DAP1360 IEEE 80211n (draft)...
How to change admin username & password on cisco 2911 router
agree that turn off your modem first before trying to open the router's setup page. By default, there's no username and the password is admin on Cisco 2911
http://www.3anetwork.com/cisco-cisco2911/k9-price_p238.html
Nov 04, 2011 | Cisco 2911 Router
I have a set Motorola Canopy 2400BH but i forgot ip address and username and password, how can i access it for using.
You need to user an Override Plug, which can be fabricated this way:
To fabricate an override plug: 1. Install an RJ-11 6-pin connector onto a 6-inch length of CAT 5 cable. 2. Pin out all 6-pins. 3. Short (solder together) Pins 4 and 6 on the other end. Do not connect any other wires to anything. The result should be as follows: Pin 1 ? white / orange ? Pin 1 Pin 2 ? white / green ? Pin 2 Pin 3 ? white / blue ? Pin 3 Pin 4 ? green ? Pin 6 Pin 5 ? blue ? Pin 5
Regaining access to the module To use the override plug 1. Insert the override plug into the RJ-11 GPS sync port of the AP. 2. Apply power to the module through the Ethernet cable. RESULT: The module reboots with the default IP address of 169.254.1.1, password fields blank, and all other configuration values as previously set. 3. Set passwords as desired. 4. Change configuration values if desired. 5. Save the settings. 6. Remove the override plug. 7. Power cycle the module.
You can view more details at:
http://www.canopy-wireless-solutions.com/AppicationNotes/APManualIss5.pdf
Apr 30, 2011 | Motorola CANOPY 2400AP (2400APBC)
I have a belkin g+ mimo router and am currently trying to set it up as an access point to interact with my d-link dir-615 router. when i add my d-link routers ip address string, the belkin disappears. i...
Hello...
Steps To Convert your Belkin Router as an Access Point.
- Connect your D - Link Router to your PC & Check the Default Gateway It Might Be 192.168.1.1 or 192.168.0.1
( Finding Default Gateway: Right Click on Local Area Connection & click on Status - Click on Details For Win 7 & Win Vista & For Win Xp - Right Click on Local Area Connection & Click on Status, Select Support Tab & Click on Details )
- Now Connect the Belkin router to your Com .. Open Internet Browser & Go to 192.168.2.1
- Towards your Left Corner Under Wireless Clink on Use as Access Point
- It will Prompt you For a Password Leave it Blank & Click on Submit
- Select the Radio Button Next to Enable
- In Specify IP Address Type in IP Address in Range of your D - Link Router Eg: 192.168.0.254
- Select Subnet Mask - 255.255.255.0
- Click on Apply Changes
- Now Open the Router Setup Page Using the Ip Address which you gave EG: 192.168.0.254
- Connect an Ethernet cable From your D - Link Router to Any 1 of the Wired Slots on the Router ( Note: We are using Wired Slot as we have Disabled the NAT on the Belkin Router It Gives you IP Address From your D - Link Router & the DHCP on the Belkin Router is Turned Off)
- Power cycle the D- Link Router & Belkin Router For 15 Seconds Each ( Unplug the Power cable & Plug it Back After 15 Seconds)
- Now go to the Router Setup Page & Check the Internet Status in the Top Right Corner It Would Be Connected.
- Try Going Online... :)
Feb 19, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Every time I run the DSL-504 ADSL2 Ethernet Router CD disc to setup my internet connection, always get the dslultility.exe message say "modam not deteched....." but everything is...
To release and renew IP address, go to Start > Run. Type in CMD and press Enter. At the prompt, type in ipconfig and press Enter. This will display the adapter information such as IP address, Subnet mask, and default gateway.
To view additional information such as Mac address, DNS servers, etc, type in ipconfig /all.
To release IP address, type ipconfig /release.
To renew IP address, type ipconfig /renew.
If you are not able to get an IP address try setting one statically:
Windows 2000
Step 1 Right-click on My Network Places and select Properties.
Step 2 Right-click on the Local Area Connection which represents your network card and select Properties.
Step 3 Highlight Internet Protocol (TCP/IP) and click Properties. Enter your IP information for your network.
If connecting to a router, make sure the default gateway and a DNS server is the IP address of the router (192.168.0.1).
Windows XP
Step 4 Click on Start > Control Panel > Network and Internet Connections > Network connections.
Step 5 See Step 2 for Windows 2000 and continue from there.
Nov 06, 2010 | D-Link Computers & Internet
How to change router ip address to the same as computer and xbox 360
Hi David,
I got your issue, You have an option to change the IP address of the router
1. Open Internet explorer and in the address bar type 192.168.2.1 and hit enter
2. You will be logged into the belkin router setup,it will ask for login password, leazve it blank and click on submit
3. In the left side Under LAN setup , click on LAN sttings
4. You can see the IP address of the router as 192.168.2.1, if you want you can change the ipaddress
Note : You cannot change the IP address of the router similar to the comp and your XBox
But You can change the ipaddress of the comp and Xbox in the range of the router
For eg: If your router is 192.168.2.1, then the Xbox can have as 192.168.2.2 and computer may have as 192.168.2.3
Thanks & Regards,
Prema
Oct 11, 2010 | Belkin (F5D7230-4-SN) Router
I am not able to connect my laptop to ITI modem. I have tried both by connecting with wireless connection &amp; with ethernet cable. It says limited or no connectivity &amp; throws error " IP...
Is the router setup as a DHCP server, you'll have to login to it to check its settings. Then on your laptop, in Network Connections, for either the ethernet or wireless connetion make sure the TCP/IP settings are set to "Obtain and IP address automatically"
Jun 15, 2010 | Computers & Internet
I cannot access 192.168.0.1
check the manual of your device if that's is the IP address assigned by default;if you are out of manual.try 192.168.1.1;it's usually assigned by the manufacturer.
otherwise if you know all the IP address of your network devices then download Cisco Network Magic Pro from purenetwork Company.
 the url is http://www.purenetworks.com/
click the try it button and download it.
It will  automatically scan your network and display all the PCs & network devices.pin point the one Ip address that you have miss out.it should be the IP address of that particular switch.try Default username & password  as admin  for both.
Let me know if it's helpcul to you
Dec 09, 2009 | 3Com Computers & Internet
How to set Static local IP Address for D-link DCS 5220 IP Camera? Am using Linksys WRTG54 Router, with SSID & WPA. I had set the D-Link DCS wireless to use the same SSID and WPA, but once I plug out...
To set a static IP on the camera, do the following:
1. Chose an IP address for the camera that is outside your normal DHCP range but within your network subnet.
For example, if your router uses DHCP and gives out addresses in the range of 192.168.1.1 up to 192.168.1.10, you should chose an IP address beyond that (e.g. 192.168.1.20).
2. Login to your camera's current IP address and go to Setup -> Network setup
3. Turn off DHCP and type in the IP address that you chose into the configuration.
4. Restart your camera.
The above should fix your Static IP address question.
With regards to your Wireless question, you should make sure of the following:
1. Your router is set to broadcast its SSID
2. Your router is setup to use WPA (not WPA2)
3. Your AES password in the camera config is the same as that as the routers
Hope this helps
Nov 24, 2009 | D-Link DCS-5220 Network Camera
Computers & Internet Logo
16 people viewed this question
Alun Cox
David Payne
David Payne
