Question about Amana Refrigerators
Amana ARS2365AC Refrig. Noise from under refrig. Refrig getting warmer inside. It clicks like a switch is trying to turn on them gives off a high pitch hum for about 30 seconds. I have made sure that it is clean for air plow. Is cube maker not working at all.
  • Amana Master
  • 2,699 Answers
First thing to check is the timer,remove the bottom kick plate,on the left side you'll see a knob,if you can turn it by hand turn it slowly or use a screw driver and turn it until it clicks,it could be stuck in defrost,if the compressor runs then you need to change out the timer.if nothing happens turn the timer until it clicks again.now go in the rear of the machine,unplug the fridge,remove the bottom rear panel and you'll see the compressor,there's a start device on the compressor and they do fail.remove the clip and before you remove it look and see where it clips on to,so when you have to put it back on or replace the part you know where to clip it again.slide off the start device,shake it,if you hear a rattling noise like a piece is broke off inside it or if it smells burnt this is your problem,the part number is W10189190 and it's like 20 dollars.when you call your parts store,give them the model number off the fridge and give them the p number and they will make sure the part number i gave you is correct.now from what you are discribing it sounds like the compressor isn't running,is this correct?and the machine is getting warm.when you change out the start device and if the compressor still doesn't start then you have a bad compressor and most likely you'll need to change out the machine.let me know what you find
Posted on Mar 20, 2011
  • Sal De Mar 20, 2011
    also,if you think the compressor is running,feel it,is it hot?you can check the condenser fan motor to make sure that's working,you can read it out with a meter but if it's melting out inside like you say it sounds like the compressor isn't running and for 20 bucks i'd start with the start device
The ge refrig. is 9 years old. Regardless of the refrig. setting, from 5 down to one it is too cold. set on 3, after 24 hours it is 28 degrees in the crisper and 32 degrees in the main refrig. tried...
ok u ok u turning wrong knob..turn other knob the one with the letters. make the freezer colder than u make ref. warmer. that knob controls a flap that controls how much cold air flows from the freezer to ref. ok
Feb 12, 2011 | GE Refrigerators
Amana refrig refrig wont get lower than 42 degrees
that is defrost timer every 8 hrs it turns on heater to defrost evap coils, unless there is major ice behind freezer panel after 1 day which i doubt, that would not be problem ...im trying to go through steps i would take as tech at your house
Jan 03, 2010 | Amana Easy Reach 18.1 cu. ft. Bottom...
Sweating and condensation just above the door
If you see a switch inside the refrig about , click to " save energy " , click it to " not save energy " . This will turn a heater on behind the strip , which will keep moisture from being between the frig and freezer door .
Nov 21, 2009 | Amana Refrigerators
The water dispensor line clogged.
you will need to replace the line from the back to the dispensor
Nov 21, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Water line stopped pouring. where is a good place
Remove the toe plate at the bottom of the refrig . Follow the water line about 6 " to the connector . Push in on the white ring while pulling out on the small line . Press the dispensor for water , and see if a steady stream comes out from the line under the refrig . If so , then the water line inside the door is frozen . If not , then the solution , is to replace the dual water inlet valve behind the refrig . This is the piece where the wall water line connects to on the refrig . If the line in the door is frozen , you need to lower the freezer temp , reconnect the connector by pushing the line , back in the coupler . May take several days to thaw . Or , if you have a compressor , you can try blowing the line out , yet still turn down ( warmer ) the freezer temp .
Oct 21, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Why am I not getting any water from door dispenser for model GSS23KGSA BB
Pull refrig out , and remove the back panel . At the water valve (piece the wall water line connects to , push up on the white ring and pull the LARGER line from the valve . Activate the water dispensor and see if water comes out of the valve . If no water , replace the complete water valve . If water comes out , reinstall the hose by pushing back into valve , and remount valve and rear panel . Push refrig back into place . Remove the bottom kick plate and disconnect the water line about 6" under front , from the coupling (pushing in the ring and pulling hose ). Press for water again . If no water comes out , probably frozen resevoir behind the refrig crispers , so turn refrig temp slightly warmer for a few days , to unthaw (or use hairdryer) . If water shoots out from hose , then water line inside door is frozen . This would be a more difficult procedure to follow . You can try adjusting freezer temp slightly warmer for a few days to see if it will thaw . If it doesn't thaw , come back to this thread with " water in door frozen " and myself or another expert will be glad to help you .
Sep 09, 2009 | Refrigerators
Refrig and freezer not getting cold
HI, Can you hear the compressor running? Does it click like something is trying to start but can't? It sounds like the compressor is not running. The compressor should have a 5 year warranty. They are having problems with these compressors so, you might want to call Amana and see if it is under warranty. I hope this gives you some help. Please let me know if I can assist you further.
Thanks
Vic
May 31, 2009 | Amana ABB2227DE Bottom Freezer...
Amana Bottom Freezer control knob
http://amana.com
go here and scroll to the bottom of the page and click on "sitemap"
and you will find help information.
Mar 17, 2008 | Amana ARB8057CSL Bottom Freezer...
Amana Side by Side Refrigerator not getting cold
amana is having some problems with their compressors locking up. if the compressor is manuactured by tecumseh then tthe compressor is mostlikely locked up and will need replacing. good news is your refrig is most likely less than years old and should be in warranty to amana..
Dec 15, 2007 | Amana ARSE66MB Side by Side Refrigerator
Kenmore top freezer unit-refrig not cooling past 50degrees
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 03, 2007 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
70 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
