Question about LG GW300 Cell Phone
I cant find the mccidem.inf file in the MTK file it's in there without the .inf extension can you please help me with this problem .
Computer cant detect the printer
Go to C:/windows/inf and look for files called oemXX.inf oemXX.pnf.
Open the .inf files one by one and look for the EPSON label in them and when you find one just delete the .inf and .pnf file equivalent. There might be more than one EPSON files in the inf library.
Then unplug the printer, restart the computer, and the add wizard should pop again when you replug the printer.
Hope this helps.
Jun 21, 2011 | Epson TMT70 TMT70 C31C637001 Printer
I cant open local disk drive E.It says it needs formatting.
Try to chance the drive letter of E: to ex F:, If you do not use the drive letter F :O),
Go to Start- control panel- Administration- Computeradministration- Disk....(I have my computer in danish and here it writes Diskhåndtering, I do not know whats the name in english :O().- under this place you find all the drives you have on the computer right now, here you choose the drive E: and right click on that and choose chance drive letter. IF you want it back again you simply do the same again. :O)
Hope that helps
IF NOT then return here
Have a nice day
Please rate my answer
Oct 11, 2009 | Computers & Internet
Cannot install downloaded driver. Windows XP looks for a .inf extension which doesn't exist in the driver files
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokl-16
Aug 16, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Problem openinig c and D drives
Try This
1.) Go to folder option = select show hidden files = delete any file saying auto.inf extension.
2.) Try running a antivirus scan on the macine & delete the infected files.
3.) Format the machine backing up your data.
Mar 18, 2009 | Computers & Internet
I cant open disc D?
u can open drive D by typing "D:\" on the address bar or RUN
there is a hidden files u must delete them, to solve ur problem try these steps :
Go to command prompt and write this command
c:\> attrib -r -s -h autorun.inf
c:\> del autorun.inf
d:\> attrib -r -s -h autorun.inf
d:\> del autorun.inf
restart the pc
it will be solved
contact me if this problem still exist
Mar 14, 2009 | Computers & Internet
Uc-logic graphic tablet WP8060U driver installation problem
change the file extension of the setupext file in the first directory of the driver setup to .inf that should fix your problem
Dec 30, 2007 | UC-Logic WP8060U (689076313025)
UST Scandal.avi.exe
1. Start Notepad
2. Copy the following text. (note: Everything in between the square brackets should be in one line)
REGEDIT4
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\IniFileMapping\Autorun.inf]
@="@SYS:DoesNotExist"
3. Save the file with a name (anything) like DisableAutoRun.reg (The extension .reg is the important part)
4. Double Click your newly created registry file. Choose yes or continue to the warning that will appear.
But what if you are already infected with the virus? There are several programs on the internet that you can download. Here are some of those programs that can be helpful:
Taga Lipa Are Remover (or Noob Killer) by Leerz (<--click to download)
else
first download taskiller in http://www.rsdsoft.com/task_killer/index... and install it to
your computer because you cant use taskmanager to terminate the virus(the virus automatically close taskmanager).
-run taskiller and left click it on the system tray(the one with a skull icon)
-click processes
-to close the virus, select process and click yes to the question
(process to close)
1.killer.exe
2.lsass.exe
3.smss.exe
note: close only file that have the same icon of Funny UST Scandal.avi.exe
CMD STEPS
1-now, click "start" then "run"
2-type "cmd" without quotes
3-type "cd\" without quotes
4-type "attrib -h -s smss.exe" without quotes
5-type "attrib -h -s autorun.inf" without quotes
6-type "start c:" without quotes(a new window will open)
7-select smss.exe,autorun.inf,Funny UST Scandal.avi.exe and delete it
-if theres any drive or a partition type "d:" in command prompt without quotes
"d" is the drive letter then repeat the CMD STEPS number 4-7 above.......
-now type this on the command prompt "cd windows" without quotes(na naman!)
-type "attrib -h -s smss.exe" without quotes(uli)
-type "start c:\windows" without quotes(hay naku!)
-delete the file smss.exe
-now, goto c:\documents and settings\all users\startmenu\programs\startup
-delete lsass.exe
-click "start" then "run"
-type "regedit" without quotes then delete the registry entries above....
-thats all
(* from support forume)
Nov 22, 2007 | Computers & Internet
Virus from ym
try using bitdefender anti virus. it removes most of the viruses with no strings attached
Nov 21, 2007 | Microsoft Windows XP Professional for PC
LG GW300 Cell Phone Logo
63 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
