Question about Sanyo Televison & Video
My tv keeps asking me to pick either the home or store mode...then will search for high quality connections but will never go back to cable tv shows and keeps going back to ask which loaction my tv is at...its a sanyo
SOURCE: remote does work on panasnic tv
try to press 'enter' for more than 2 seconds and while pressing, try pressing button 1 just to change the 'coding' of the remote let me know if it works
Posted on Aug 09, 2007
  • 52 Answers
SOURCE: Tuner Mode - Air or Cable?
Direct tv, unless using there HD service will give a pretty crappy picture for high res displays. So if you spent the money on the set, spend the extra $9 a month for there HD service.. Is well worth it.
Posted on Apr 21, 2008
  • 280 Answers
SOURCE: Sanyo tv making high pitch noise from loose cable connector
The noise is coming from the fly-back transformer. By moving the cable connector you move the main board. Unplug the TV and remove the back. The transformer has a red wire going to a rubber cup at the top of the picture tube. Looking at the transformer you will see a dough nut shape with a metal piece going through it .. Drive some tooth picks between the dough nut and the metal core. That should reduce or stop the ringing.
  • 23 Answers
SOURCE: High temp warning
2 BLINKS: Temperature
Posted on Oct 01, 2008
  • 362 Answers
SOURCE: Auto Search for Local channels not responding
Hi elmergdavis,
Check and make sure your tv is set to CABLE and not to AIR or ANTENNA. This setting is usually just above the Auto Search utility on the meNU.
Let me know what you find and I can provide further assistance.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Jan 29, 2009
Can regent home theater system modle ht-2004 pick up radio signals or cb radio waves.
Most audio equipment will pick up radio waves of various kinds. The question is do you want it to?
If as I suspect you don't then you have a problem. You can get special filters that connect between the aerial plugs and the receiver. These are set up to remove CB radio signals. Your local electrical parts shop or aerial installers will stock them. Also fit cable connections that are good quality, designed with high quality screening built in.
Apr 14, 2015 | home Audio Players & Recorders
55inch full Hd led LCD smart tv, there is a pop up that keeps showing 'I'm plane switching' UBS ' it seems like a demo pop up to show customers what this tv provides, how do I get rid of it?!! It's...
ok when you set up the Tv it asks Home Or Store mode, seems you clicked store mode, go back to the menu, click system and setup and start again, this will mean everything, time date, and channel scanning. only way !!!
Aug 14, 2014 | Televison & Video
Connecting my new samsung blu-ray player (bd-fm57c) to my toshiba theaterview tv.
I don't think that cord will work. HDMI carries video and audio signals, you might get video but probably no sound. You might as well try anyway though so here goes... The red green and blue plugs are your video and the other red plug and the white plug is for stereo sound. The yellow plug is just a lower quality video plug. So plug in the red blue and green plugs into the component video inputs on the TV then the red and white plugs into the audio inputs. DON'T plug in the yellow plug. If this doesn't work go to your local home theater store and ask for a receiver or switcher that will downscale high def HDMI to component video and stereo audio. You can probably pick up a cheap one for around $100. Good luck!
Mar 29, 2014 | Toshiba 50 Inch Big Screen Flat Tv Theater...
Only 1 hdmi outlet on TV . I have a high def cable box and a sony blue ray dvd player. How do I connect 2 hdmi cables fron the components to the tv?
Don't used the Blu Ray player on the tv HDMI out put hub.Used the connections for of the Blu Ray player connections by a S-Video cable for the video and the RCA component cable R,W for the connections for the audio out.The high Def.cable box will not work for high Def. this way,but the Blu Ray player will.
May 30, 2011 | Sony BRAVIA KDL-40S2400 40 in. LCD HDTV
I ve Sony Bravia KDL55EX713 55" TV, it keep showing me input banner showing(Bravia,LED,presence sensor,Motion flow,Full HD, BE3, WIFI HDMI etc.) I have tried display button, and all settings on...
Your TV is in store demo mode.
To fix this, access the TV's menu and find the option to run initial setup. At the beginning of initial set-up, you'll be asked whether or not the TV should be put into Home or Retail mode. Choose Home.
Mar 15, 2011 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
My Philips Dvd home theater system HTS3100, how can i connect to my tv set
Hello
1. First things first, READ the Instruction Manual, I know most of you guys out there hate reading the instruction manuals but every system is different, so I'll generalize this article for an average system you can find at a retail store today.
2. Make sure you have the right cables to connect your TV to your Home Theater System, now days the best connection is called "HDMI" (High-Definition Multimedia Interface) this cable uses a digital signal to transfer both video and audio while giving you the best quality possible. But please make sure your Home Theater System has the "HDMI" as an input option. If it does not, you might have to resort to a analog connection such as "Component Cables" which will provide you with a High-Definition connection but with analog quality.
3. Now if you are using a current TV and a current Home Theater System and your system is able to use the "HDMI" cable, connection to said devices will be pretty easy, just hook one end of the "HDMI" cable to the "HDMI" input on the back of the TV, and the other end of the "HDMI" to the "HDMI" output on the back of the Home Theater System. Turn your devices on and make sure your input/outputs are configured for "HDMI" usage and vola! You should now be able to see and hear everything your heart desires!
4. Organization is key, after you have checked your connections and everything is working the way you want it to, utilize the cable/wire loom to organize your cables and use the zip ties to secure them in place, not too tight though, if you want to change things around in the future it's easier to cut the zip ties if you have enough room between the cable and the zip tie.
THANK YOU
Jan 27, 2011 | Philips HTS3100/05 Theater System
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    Panasonic Viera keeps going into picture refresh mode. How can I stop this?
    The tv is on "store" rather than "home" setting. If the message "going to refresh mode" keeps appearing every 5-10 minutes, do the following:
    -Unplug TV from wall and leave it for about a minute.
    -Plug TV back in and follow "initial setup instructions" (can be found on page 14 of manual).
    You will be given the choice of "home" or "store" settings. Change it from "store" to "home".
    -Done.
    Aug 20, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
    Connecting to Direct TV satellite box
    If the cable is connected to Antenna/cable port on your TV, then set the TV to antenna mode and search for programs after which you should have some stations showing.
    Jan 16, 2018 | Sanyo DS24425 24" TV
    Keeps going to refresh mode
    This is the Panasonic Customer Service Answer:
    you need to reset the unit to get it out of store mode sir
    make sure the unit is on and we are not in any menu screens
    press and hold the volume down button on the front panel
    and ok on the remote at the same time until the words self check appears on the front of the screen
    once self check is displayed unplug the unit from the wall for one minute
    after one minute plug the unit back in and it will go back through first time setup
    make sure you pick the home mode
    Apr 19, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
    Televison & Video Logo
    136 people viewed this question
    Top Sanyo Televison & Video Experts
     Grubhead
    Grubhead
    Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
