Question about AMD Sempron 2800+, 1.6 GHz (G54222)
My computer can not read my usb devises plugged into usb ports rear or front
    Sergeant:
  • 170 Answers
Please check bios settings
Posted on Mar 20, 2011
How do I get my computer to recognize my simpletech hard drive?
For Windows XP and later, or Mac's OS9 and later, it should auto detect when it's plugged into a USB port. Large drives can sometimes take a little while to be detected, shouldn't take longer then 45-60 seconds, unless you're having other problems with the USB port. If it doesn't work in the first USB, try a different one, preferably on the back of the computer (some computers have front USB ports that aren't the same quality, power, and speed as the rear ports). If it doesn't work in a second port, try it on a different device that can read from the USB (another desktop or laptop, and some tablets and phones can do this).
Oct 10, 2014 | Simple Technology 5832713 1tb External...
HP Pavilion zv6000: USB ports are inop. USB port on rear of computer works fine. USB port on left/front will power my flash drive, but the light stays on constantly. The flash drive is does NOT show up in...
After reading the description, I think you need to try updating BIOS and latest device drivers for USB. Because USB are getting power on that means there would not be any fault to from the motherboard.
So please try updating latest BIOS for your notebook.
If you can provide me the product no for your notebook and the operating system which you are using currently then I can find the one for you.
Otherwise you can also do the same.
Type in the product no. on www.hp.com. Then go to software and driver download page, select the proper OS and search in BIOS ROM pack available for your notebook.
I hope this will help.
Jun 11, 2010 | HP Pavillion ZV6000 Notebook
My computer not reading device1430 magellan
assuming your using a windows xp or 2000 os, try another cable if you have one..turn the gps off, plug in the usb cord and restart the gps. if that fails, if the cable is connected to a port on the front of the computer,move the usb cable to a rear port on the computer and try the previous way i just explained.
if those fail, disconnect all usb devises connected to the pc and restart the computer and try again. (always use a rear port on the pc if you can)
Aug 09, 2009 | Magellan RoadMate 1430 GPS Receiver
Computer does not recognize it
good luck
Aug 03, 2009 | Magellan Maestro 4040 GPS Receiver
I'm trying to use the usb port to show pics from a digital camera. i don't have a manual
if you connect a camera on a usb your computer will show, a removable device in your computer. under E or F double click, and your computer will show all pictures in your camera
Apr 14, 2009 | Proscan PS36810 TV
Where would I look for the usb port
Most Compaqs (in general all brands) have USB ports on both the front and rear of the case. The rear connectors are found where all the other I/O connections are located. They are flat rectangular sockets. When you want to plug in a USB device, you can plug into any open USB port. The plug will also only fit one way, so if it will not go into the connector just flip it over.
Front panel USB connectors are often hidden behind a door. Look for a swing-open or slide-down panel. On some cases the connectors may be on the top or sides.
When connecting devices such as a printer or external hard drive, you should use the rear-panel USB ports. These go directly into the system board and have the best performance. Front-panel USB connectors plug into the main board with cables. For most devices (including your SanDisk) it doesn't matter which you use, but the rear-panel ones are best for high-speed devices or moving lots of data.
You can usually find the user's guide online at the computer manufacturer's website, and that will show you where all the connector are on your system.
If this solution has been what you need, please take a moment to rate it. Thanks for asking here!
Feb 21, 2009 | Compaq Computers & Internet
Charging camera
Are you using the front usb ports on your computer? My computer's front usb ports were not able to charge my camera, but the rear usb ports were able to (the charging light should stay on if it's charging correctly). I'm not an expert on this stuff, so maybe there's a power output difference between your frontal and rear usb ports.
Also, on the CD there was a camera connection driver. You might try installing that and see if that makes a difference?
Sep 28, 2008 | Kodak Easyshare M753 Digital Camera
Computer doesn't recognize usb device...
do not use Front usb connector. put your device in backside of CPU usb port. it wil work fine.
Mar 05, 2008 | Belkin BLKF5U201 USB Peripheral...
Power sugre with m240
Hi there. This message would indicate any one of the following: 1. You have a lot of USB devices plugged in to your computer, and the maximum power supply for the USB ports has been exceeded by plugging this player to your computer. It would be best if you unplugged 1 or 2 of the USB devices connected for the time being. 2. You are plugging the player on your front USB port, and may need to plug it in the rear USB port to acquire ample power supply (front USB ports do not get as much power as the rear USB port -- sad but true) 3. You are using a laptop and may need to try another USB port on that computer. Purchasing a self-powered USB hub would be ideal as it gets its power supply directly from the wall electrical socket.
May 11, 2007 | SanDisk Sansa m240 MP3 Player
AMD Sempron 2800+, 1.6 GHz (G54222) Logo
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
