Question about Craftsman Nailer Kit, Palm Air Driver
Paslode im90i fires ok but nail dose not come out but firen pin does
  • Anonymous Mar 23, 2014
    Paslode is new just out of box but does not fire
My paslode im90i nail gun uses loads more gas than the calculated nails per gas and is costing me money
Posted on May 20, 2011
My paslode impulse 1m50f18 fires normally but no nail apears with paslode nails?
not sure what you mean" no nail appears with paslode nails" if it fires make sure the nails are correct for your gun
Sep 08, 2015 | Air Tools & Compressors
Hi, I have a paslode im90i nail gun. Problem is it occasionally fires five or six on the bounce then goes back to normal, which is now 90 percent misfires. It cycles, it does everything OK, it fires and it...
go on paslode site there is a video on cleaning also there is lots of talk about expired gas cartridges get new ones it seems once they reach exp date they just don't work worth a darn
Nov 22, 2014 | Air Tools & Compressors
Paslode 900600 Trim nailer not sinking nails
The firing pin can be completed or part of it crooked worn and can have a little burr on its way and stuck in the cylinder somewhere o-rings worn and hardened, have a tilting piston on the firing pin somewhere in the cilinder
Jul 27, 2017 | Air Tools & Compressors
My paslode im90i nail gun uses loads more gas than calculated nails per gas and is costing me money
are you useing it in the temp range on manual, that will make a diff.
May 20, 2011 | Garden
Paslode 2nd fix firing pin seems to ride over the top of nail hence not shooting it to right depth
Ok the only thing that keeps it from riding over the top of the nail is your quick release on the front of the tool. I bet when you go to latch the front that it is not very tight. you need to replace the whole door. This should take care of you problem. # 900759 front plate assemblyhttp://www.paslode.com/cleaning-procedures.html
Apr 21, 2011 | RTO Paslode 902000 IM250 Ii Cordless 16...
I have a paslode straight finish nailer, purchased in Australia around 2001. The problem is that the pin that drives the nail out of the gun does not retract back into the cylinder. I have it apart and the...
is the cylinder really dirty, if so it needs a thorough cleaning. your instruction mnual detailes how to do this. also look for a jammed nail in the nose area and possibly a bent driver.
Sep 15, 2010 | Omega Paslode 901000 Impulse Cordless...
Paslode framing nailer will onley fire one time and wont return to fireing pos. fires first nail great . started this problem after cleaning
Did you remember to lube the upper cylinder, lg 0-ring and silicone the striking pin----sticking may prevent returning to firing position
Mar 05, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode 350 wont fire
Probably needs cleaning. You`ll need two new o`rings.
Aug 19, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Firing pin not retracting far enough to allow nails forward
Yes,this is a common "mis fire" by Pasilode. I own the 16p Framer and the Angle nailer and I never get it from the Framer but I do get it seldom from Trim Gun,nothing you can do ,its just a misfire.
Please rate jj505
Mar 20, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode im350
Stuart - this sounds like an air problem - you should perform the following test. With the air nailer close to the compressor you must monitor the airpressure after the gun fires. it sounds like the air is not gettting through diapram fast enough or there is a blockage in line. Blockage in line is not suspected for the following reason . It sounds like the air hose is holding enough air to fire 2-4 nails and then you must wait for the line to fill up again and then it fires ok. The pressure regulator out to the line controls this and they do fail. try this test and report back to me - I know I can solve this for you as I have extensive background in compressor and the like.
Oct 22, 2008 | Itw Devilbiss Itw Paslode Cnp 65Y Coil...
Craftsman Nailer Kit, Palm Air Driver Logo
365 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
