Question about Maytag Bravos MVWB700V Top Load Washer
Maytag Bravos Washer HE top loader mvwb300wq1 - 10 months old, loud noise sometimes near beginning of cycle, shows "Ul" on display. Then works OK next time!
  • 56 Answers
SOURCE: Any problems with Maytag Bravos mvwB750w?
you would be better off with a front load. they (bravos) dont sell all that well and probably wont be around too long
Posted on Feb 07, 2010
kdrake84
  • 262 Answers
SOURCE: how do I lift the
The link listed below will show you a diagram of your units Motor basket and lid parts.
Click on the link http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-MVWB300WQ1/3048/0153200/W1003175/00003?blt=06&prst=0&shdMod=MVWB300WQ1
As you can see (click on view full size) part number 6 (impellar or agitator) is held down by only a bolt,part number 2 and a washer part number 3.
Simply remove the bolt and remove the impellar (agitatior)
If you have any other questions or concerns please post.
If this information helped you please consider giving us a 4 thumbs up for our rating.
Thanks in advance and Thank You for using FixYa!
Keith
Posted on Feb 20, 2011
  • 6277 Answers
SOURCE: Can I pack insulation around
NO!
(If you haven't already, try my guidance notes on leveling, please!)
I mostly answer front load problems but ' out of balance' is a common problem with both!
So- I don't know your particular machine but the initial cure is the same.
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Mar 20, 2011
SOURCE: my maytag bravos quiet series 300 washing machine
i lost the manual , what does "5d" mean when it is
Posted on Jul 04, 2011
SOURCE: i have a maytag bravo.
Did you get a solution? Having the same problem.
Posted on Sep 09, 2011
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
Maytag Top Load Washer MVWB850YW making loud noise in spin cycle.
If it's a roaring noise, the tub bearing is probably wearing out. Spin the tub a little with your hand, if you hear a little of the roar, that's it.
Nov 26, 2013 | Maytag Bravos Series MVWB850YW 28"...
My 3 month old washer suddenly started leaking from underneath. There was a code displayed of a 5d, but the washer drains into a laundry sink, there are no kinks in the input line.
The washer is detecting too much soap. Make sure that you are using HE (high efficiency) soap Do a clean washer or hot cycle once a month with bleach or white vinegar with no clothes in it. Your washer only uses half the water that a regular machine does. The HE is specially designed for front loaders and these types of machines
Jul 11, 2011 | Maytag Bravos MTW6600T Top Load Washer
My Maytag Washer quiet seriouse keeps showing UL the last 11min of the spin cycle and I don't kno wats wrong
Hi
UL fault code indicates 'unbalanced load' which means the unbalance switch or control board may be faulty.
Sometimes it just means you have heavy items such as large towels or curtains in the wash but if it persists you will need to get it looked at.
Ash
Please rate this solution if you find it helpful
Dec 20, 2010 | Maytag Bravos MTW6600T Top Load Washer
My oasis he is not a see through top but i keep getting the ul message and when it goes through the spin cycle it sounds like ajet engine. iS THERE A SENSOR THAT NEEDS REPLACED.Sears wants 129.00 to just...
UL is unbalance load. uL is displayed when the machine/motor control detects an
off-balance load, and is steady on while the washer runs a
mini-cycle to rebalance the load.
Display clears if mini-cycle successfully rebalanced the
load.If the mini-cycle is unsuccessful, uL will flash until the door
lid is opened, allowing the customer to view and
redistribute the load. Page 57 shows the suspension
rod removal to get the tub out. These rods (4) hold the tub in place. Sorry I do not have an oasis manual but this Bravos manual will give you an Idea. One of those rods could be worn to the point it is throwing the the whole tub off. If a rod is broken then the tub could be pressing against the base and binding the motor, causing that noise. You gonna have to check and see.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 16, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Loud sounds coming from the washer on spin cycle
That is a characteristic of bearings gone bad. You should look into replacing the bearings.
Mar 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag Bravos MVWB700V Top Load Washer Logo
341 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
