Question about Kenmore 64802 Top Freezer Refrigerator
Hi, i have a kenmore 70194001 and i get water dripping into my ref. i defrost it and it is ok for awhile and it starts again. should i make the freezer warmer? thanks jay
SOURCE: Kenmore / GE side by side defrost drain keeps freezing up
Remove back of unit and check defrost heater has not become detached, otherwse the is only two possibilities, one a defrost fault and although you say the defrost tube is clear the only reason it does not flow is due to a restriction, what can happen is that the water backs up the drain pipe and then freezes before the water in the external tray can evaporate. Regards Advisor
Posted on Aug 24, 2007
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
woodchuck789
  • 4070 Answers
SOURCE: ice buildup in freezer drip pan and water overflow
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Sep 21, 2009
Sea Breeze
  • 4655 Answers
SOURCE: water drip at base of freezer door at bottom!
Have you had a chance to locate the location the water inside freezer? There are many reasons for this to happen I just can not say it would be a defrost condensate drain blockage. Most times it is. Every 8 to 10 hours your freezer defrost and the water is surposed to follow a pipe or drain through the refrigerator to a pan below refrigerator where the warm air from condenser evaporates the water back to the air inside your home. That drain line sometimes slowly becomes blocked and then the drain hole becomes clogged with ice. Once that happens the drain needs to be cleared. I will try to help you solve this so for now I need you to see if water looks as if it came from rear of freezer. Placing photos on Flickr would be great! So tell me where you see it and yes we may need to pull a few things out. This is nothing a few towels, hair dryer hot water and Clorox and a wet vacuum cannot handle. Sea Breeze
Posted on Mar 21, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Freezer door started dripping water when opened
Hi and welcome to FixYa. I am Kelly.
In the fresh food compartment center overhead within about 6 inches of the front of the unit there is a circular hole. Inside that hole you will see a dial with 2 tabs on it. Use your thumb or a squared off utensil and rotate the tabbed dial slowly until you hear an audible "CLICK" The refrigerator should stop running and the defrost cycle begins.
After 45 minutes (+ or - 10 mins) the compressor should start again. Once the compressor starts, check both the evaporator fan in the freezer compartment and the condenser fan in the bottom rear of the unit to make sure they are turning at full speed.
If the compressor does NOT after 90 minutes re-start, rotate the defrost timer tabs of the dial in the overhead of the fresh food compartment until you hear it start again. The fact that the compressor did not start in under 90 minutes indicates a defrost circuit problem.
A slow running evaporator fan or condenser fan will cause poor cooling. Also in the back of the unit, check the right side of the condenser coils for lint / hair build up. If it is blocked the front outside chassis of the freezer section will be very warm almost hot to the touch. Clean as needed with a vacuum if you do find any lint buildup.
Once more thing is to check the ice maker. Quickly touch the bottom of the ice maker. If it is VERY hot to the touch then there is a problem with the ice maker itself and the mold heater can cause your freezer to warm up and overall unit performance to degrade.
A complete checkout of the ice maker can be found here: http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
Your parts can be found here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48360
Scrolling the left side of the page will access all sections of the unit.
Thanks for using FixYa.
Kelly
It sounds as if you have an automatic defrost problem.
Posted on Jun 13, 2010
I have kenmore fridge model #106.64232402. on the bottom of the freezer is ice and water is dripping into the fridge. What i can do?
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 27, 2011 | Kenmore Top Freezer Refrigerator
Kenmore Refrigerator by Whirlpool, model 106, top freezer. Water drips into refrigerator from freezer. I have de-iced the coils in the freezer, under a flat panel. I made sure that water flowed from the...
Leo Ponder
imufo2
Sep 24, 2011 | Refrigerators
We have a Kenmore bottom-mount refrigerator - less than a year old. The drain on the freezer is clogging up with ice. We have defrosted it and cleared out the drain, but want to empty the drip pan. ...
Leo Ponder
imufo2
Sep 17, 2011 | Kenmore Refrigerators
Kenmore side by side ref model #58582891 water line leaking in bottom front of refrigerator, replaced the filter housing, stopped the leak that went into the drip pan. Water drips in front when push the...
Leo Ponder
imufo2
Aug 11, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
My kenmore refrigerator is glowing orange in the freezer.
That is completly normal, what your seeing is the glow of the defrost heater and its usually on for about 15- 20 minutes every 2-3 days,if you have your manual that came with the ref it will tell you that is't completly ok
Most people hear the term frost free but that is a misnomar and if a refrigerator isn't frosting it isn't working,their is manual defrost types that you need to defrost and automatic defrost types that a heater comes on and melts the frost after the ref. has for for appx 16 hours. Not 16 contunious hours but 16 hrs. of running (10 minutes on and 2 hours off takes awhile to accumalate 16 hours of run time)
Jul 26, 2011 | Kenmore Refrigerators
My kenmore refrigerator is leaking water from the freezer to the bottom part of the refrigerator what can be the problem It is only 5 years old
it is normal if your ref. was in defrosting time then after it is in good cooling your going to do is to clean the drain of your ref. to avoid dripping of water to flooring.
Mar 04, 2011 | Kenmore Refrigerators
Drain tube apparently doesn't allow condesate in ref to drain out
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jun 02, 2010 | Sub-Zero 650 / O Bottom Freezer...
Water is leaking into the refrigerator.
most likely the defrost drain in the freezer is frozen shut. take out the back wall of the freezer and check under the evaporator. if its a whirlpool built kenmore you may find a sheet of ice on the floor of the freezer under the plastic floor/tray. if this is the case, remove ice, thaw drain with a turkey baster and hot water. wrap a piece of thicker copper wire (pencil lead size approx), around the defrost heater and push into drain about 2-3 inches, making sure it doesn't touch the sides of the drain, this will keep the drain from freezing shut. if its a frigidaire built remove the control from the inside of the ref and silicone around the opening where the water drains from the freezer into the drain cup that is built into the back of the control panel. that will keep the water from running along the ceiling of the ref and dripping. hope this helps. if not put model number with problem.
Apr 19, 2009 | Kenmore Refrigerators
Kenmore Elite refrigerator problem
Sounds like a defrost problem or a plugged drain... to get it to work temporary defrost the freezer. Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks. To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain. The defrost systems is:
HEATER-DEFROST
THERMOSTAT-DEFROST
TIMER-DEFROST (or may have a ADC)
Start with the timer. (if it has a ADC it will not apply) It is just under the front kick plate. there is a knob you can turn it slowly.until it clicks off the compressor. then open the freezer and listen . You should hear the heater come on .. it will sizzle when it comes on ...
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
Aug 31, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Refrig with Filters water and ice dispenser- water is dripping when not in use, no flow when activated
valve needs to be replaced. it is located in the back, just follow the water line to it. to shut off water there is eaither a shutt off behind ref or in the basement. again try to fallow the water line
Oct 22, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 64802 Top Freezer Refrigerator Logo
56 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
