Question about Whirlpool Duet GHW9150P Front Load Washer
Door will not lock
I had to many towels in washer it was off balance so i cancelled the load. I think the door may have been forced open by the towels just before i got to the machine. Door says locked but it is not really locked will come open if I dont hold it closed.
  • Patch3 Aug 03, 2008
    How do I get to the door lock
    Scholar:
  • 97 Answers
Hiya
there is a good chance that the load has "bust" the door lock or maybe just snapped the door ******(part thats on the door itself)
if the ****** is ok, you will need to replace the door lock.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 03, 2008
  • kevin mcdowell
    kevin mcdowell Aug 03, 2008
    hiya
    you should be able to get one from any local repair center, or try using some of the google ads on this site.
    hope this helps
    kj
  • kevin mcdowell
    kevin mcdowell Aug 04, 2008
    hi
    sorry misread your question, you get to the doorlock by removing the retaining band around the front of the rubber door seal, then folding it back into the drum, loosen the two screws and disconnect the wiring block.
    refitting is the reverse.
    REMEMBER TO UNPLUG IT FROM THE MAINS FIRST.
    kj
I was using the spin cycle to spin water from a scarf. I decided to stop the stop so I hit cancel button. Now the washer door is locked and I can't open it.
• If the cycle is interrupted during spin, it will take approximately 2-3 minutes for the door lock to release. DO NOT force open the door. • To stop the washer, press Cancel.
Jan 05, 2011 | Frigidaire Affinity ATF7000E Front Load...
My GE Washer Door Won't Lock
Try this, press the pause/cancel button twice. Open the door, ensure there is nothing blocking the door and close the door fully. Open the detergent drawer fully and re-close the drawer. Select Quick wash and press start.
If this does not correct the problem, call for service under warranty.
clarkco
Feb 19, 2009 | GE WBVH6240F Front Load Washer
Washing machine previously off balance, I pressed cancel button
THERES A LOCK/UNLOCK TO THE FAR RIGHT OF THE PANEL..HOLD IT DOWN FOR 3 SECONDS - MY KIDS DID IT TOO
Feb 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Affinity LTF7000ES door not staying locked
unplug the washer and wait 5 minutes before plugging it in again!
this resets the system. If this does not work then you may have a faulty door lock, latch, or switch!
An need hands on service on location
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 31, 2008 | Frigidaire Affinity ATF7000E Front Load...
Top loading washer door locked
check the panel for triped breakers - check the plug for the washer - the door latch usually release itself after fewhe latch minutes- if nothing works try to force lid open with a thin screwdriver from the side were the door latch is
Sep 14, 2008 | Kenmore 24032\24036 Top Load Washer
Door buzzing/not locking
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Adding clothes after wash started
It is best to finalise what clothes you want to wash, regarding front loaders. Or if you stop the machine, you have to wait for a couple of minutes for the door mechanism to release the lock, before u try the door. At times the door won't open for there is water in there; & if you force the door you'll damage the door assembly. So a lot of caution here!
May 09, 2008 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
Stopped operating in the spin cycle
With a heavy blanket you probably have an out-of-balance condition which doesn't let the machine spin out and drain. This would keep the door lock from opening. Try hitting the Stop button twice. This should cancel the cycle and let the door lock open after a little while. Then either redistribute the load or add some items and run a Spin and Drain cycle.
Mar 05, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
63 people viewed this question
Dan Webster
Dan Webster
Sal De
