Question about Adaptec USB2connect 5100 6-port USB 2.0 Card - 2126500 Serial Adapter
When I plug in the cable for the e reader the...
    President:
  • 1,623 Answers
Explain in more detail
Posted on Mar 20, 2011
How do I connect a new dvd reader with a Panasonic SB-WA340 active subwoofer?
Of the Phillips is not a home theatre system them you can but you will have no volume co trol of the sub. If it is the alot of philips home theater in a box (htib) use special plugs...you would need to change the cable end of the sub to a compatible plug.
Aug 23, 2016 | Panasonic Audio Players & Recorders
E000732-0001 canon ir
Error Codes ecblank.gif ecblank.gif ecblank.gif Problem : ecblank.gif E000732 - 0001 Found cable from Machine to Reader becomes loose in reader housing due to Doc Feeder cable catching as the feeder is raised. ecblank.gif ecblank.gif ecblank.gif Sub-Assembly : ecblank.gif ecblank.gif ecblank.gif ecblank.gif Cause : ecblank.gif ecblank.gif ecblank.gif ecblank.gif Solution : ecblank.gif Replace cable (FH7 7167 000) dress Doc feeder cable away from plug by putting a twist in the doc cable before plugging into reader
May 13, 2014 | Xerox Office Equipment & Supplies
How do i download pictures from a verizon lg cellphone
There are a number of ways to do it. 1) you can use a cable that plugs into the camera and the other end of the cable plugs into the usb port of the computer. Most camera's come with this cable, if not it's a pretty common cable to purchase for less than $10.00. Once you plug it into both the camera and the computer, turn the camera on and the computer will recognize the usb camera device. You'll have to navigate to where your pictures are but that should be easy just open the folders until you find them. 2) you can buy a usb card reader than handles different types of cards. Remove the card from the camera and place it in the card reader device. Once again your computer will recognize the usb card reader and you can navigate thru the folders to find your pictures. 3) You can email them to yourself then go to the computer and open your emails and save the pictures.
Mar 19, 2012 | Dell Computers & Internet
I need to get an order form to order the part to help me download the pictures off of my camera. Evision 123 # 69A2S1CX0 05280
I could not determine what part it is that you are looking for, however I will still try to help you. It sounds like you are trying to transfer pictures from your camera's memory card to your computer. There are two ways that you can do this.
1. You can use the USB cable that came with the camera and connect the camera to the computer with the memory card inside the camera. Perhaps the part you are looking for is this USB cable to connect your camera to the computer and download the images.
2. If you do not have the USB cable that came with the camera, then you will need to take the memory card out of the camera and plug the memory card into a memory card reader. If your computer has a built in memory card reader then great, that's all you need; just plug the card into the reader and download the pictures from the card. If your computer does not have a built in memory card reader, you can buy one for cheap and plug it into a USB port. Here is a link to buy one from amazon.com which is a very reputable online store:
http://www.amazon.com/SanDisk-SDDR-88-A15-Hi-speed-Reader-Package/dp/B0000AKVHF
Plug this card reader into your USB port on your computer and plug your camera's memory card into this reader. Your computer will recognize the card and you can download the images to your computer! Good luck!
Jul 03, 2011 | eVision ClearView Digital Camera
Ir3170 error code e000732-0001
This error code is a communication error between the Reader Unit and the Copier (Printer Unit). Shut down and un-plug the Copier. Unplug and reset all the connectors on the rear and sides of the copier. One interface cable is responsible for communication between the reader unit and printer unit. This may solve the problem. Possible the cable is defective see if cable or cable socket is damaged.
This error also can be caused by a defective reader controller/DC Controller or Main Controller PCB.
If the simple cable check does not solve the problem a service call by a Canon dealer will required.
Mar 16, 2010 | Canon Office Equipment & Supplies
Can i download from my video camera to computer,what cable do i need to purchace.
Hi...
There are two ways to download your picture to the computer,
  1. If your camera have SD card you need to but a card reader then plug your SD card to the card reader and plug your card reader to your computer. direct to the motherboard. then start download your picture
  2. If you want to buy a cable make sure that the cable you buy is fix to the port size of your camera, i think the size of that bale is 2.5
Good luck !!!
Regards
PCmania
Jul 11, 2009 | JVC GR-D20EK Camcorder
Can't drive av/c;multimedia hardwares;tvcard
Sounds like the card reader cables, USB cables, and Firewire, (1394) cables have been disconnected from the motherboard. I'm guessing granted, but it could have been when the TV card was removed, or perhaps when you were installing upgrades.
You've had the computer open, judging from the statement that you've upgraded it.
1.Computer off, and unplugged from the surge protector. Open the computer case. TOUCH the metal frame of the computer case, to relieve your body of static electricity.
2.You may have to use a flashlight. Look for the cables coming from the card reader. From the Front Panel. You may have to remove the Front Panel a bit, to peer in, and see which cables go to the card reader.
Finding these cables, follow them back to the motherboard. See if they're plugged in, plugged in tight, and if they are the right way around.
Do the same for the firewire ports, and the USB ports. Follow their cables.
Apr 29, 2009 | E-Machines C6423 AMDAthlon 64 3400+ 2.2GHz...
Internal memory card reader plug on the MB?
The memory card reader that you have is most likely running on USB, therefore you will need to plug it in to one of the USB headers on your motherboard. They usually are made for 2 USB ports so the connector for USB is 2 rows, but yours is just flat so it will fit anyway.
The USB plug and cable on the motherboard kind of look like this:
http://www.windowsdevcenter.com/windows/2005/02/23/graphics/figure14.jpg
Dec 08, 2008 | EliteGroup 845GV-M3 Motherboard
Ricoh Caplio R5. Have used cable transfer of pictures to my PC twice , but now the plug will not enter the camera socket.
hi!!!
try to replaced your usb plug
or removed the memory card and plug in
memory card reader!!!
if you want to move the pic to the computer
Sep 23, 2008 | Cameras
Adaptec USB2connect 5100 6-port USB 2.0 Card - 2126500 Serial Adapter Logo
65 people viewed this question
Top Adaptec Computers & Internet Experts
Rommel Balcita
Martin Murray
Robert Graf
Are you an Adaptec Computer and Internet Expert? Answer questions, earn points and help others
