Question about SanDisk Sansa e100 MP3 Player
I have a sansa E100 seriers MP3 player. I was using it fine yesterday , and it just stopped working in the middle of a song. Today I changed to a new battery and it will not turn on. If I plug into the computer does not recognize it. Any clue??
  • 2,574 Answers
Run the recovery tool from the SanDisk website .
Download Sansa Disk Recovery tool
How to use Sansa Recovery tool(instructions)
Download Adobe reader
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Posted on Mar 20, 2011
Using iTune cards for Sansa Clip MP3 Player
Sansa MP3 players will not play iTunes songs. Only iPods play iTune songs. Visit Limewire to download songs that you can play on your MP3 player.
Dec 07, 2008 | SanDisk Sansa Clip MP3 Player
Sansa 280
ok buddy...it might be problem with the storage.. try to format the player once.. now the player will be fresh... now download all the songs and try whether its working fine... if the problem continues try to contact the player manufacturer for replacement
Sep 17, 2008 | SanDisk Sansa e200 MP3 Player
Where's all my songs?! Or the folders, for that matter?
marth - in the menu, go to Settings --> USB Mode --> Autodetect; if it is already set to auto, then change to either MTP mode or MSC mode - one mode will show Audible/Recordings, and the other will show your Music
this player had a messed up file system, which is wqhy you're experiencing that problem
guest - your mp3 player is incompatible with protected Rhapsody WMA's - switch to Rhapsody's mp3-only subscription level, and reload the songs, and they will play fine (remember: with rhapsody, once your 30-day trial or subscription expires, any WMA files will become useless. Stick with their mp3 subscription, and you will be fine).
-Tha Mp3 Doctor
Sep 12, 2008 | SanDisk Sansa m250 MP3 Player
All songs vanished after plugging into Mac
WHo knows what the Mac may have done. Try changing the USB setting from Auto to MSC.
Jul 08, 2008 | SanDisk Sansa m230 MP3 Player
The screen is turning white when I change song
You could possibly try recovery mode?
or formatting it and starting over, see if that helps
easy way to format
1.Shutdown player
2.Hold Rec button
3.Turn player on
4.Plug your player into the PC
5.Go to My computer
6.Find a Icon named 16Mb Format
7.Open that and make a new text file
8.Name it sansa.fmt
9.unplug player and it will say Formatting.....
10.when its finished it will reset , or shut off, when its done turn it on and see if that helps
May 08, 2008 | SanDisk Sansa e260 MP3 Player
Won't play certain songs
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Oct 31, 2007 | SanDisk Sansa e260 MP3 Player
Music stopped playing "synchronize to continue..."
Your device has to be connected to Rhapsody every 15 to 30 days to verify your account.
If you are connected and signed in, and still receive this message, you should contact Rhapsody Technical Support as the error is on their end. (866-597-5507)
Best of Luck.
Oct 10, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
"BAD TRACK"
You have a corrupt file - bad file...
Corrupt files for sansa -
Plug your player in, in MSC mode.
Right-click on it.
Click "properties"
Click "tools"
Click "Error Checking"
Check both the boxes on the error checking window that pops up, and click start.
After it finishes, check your player to make sure your player is normal.
If that don't work then format = http://www.sandisk.com/Retail/Default.as...
Sep 26, 2007 | SanDisk Sansa e260 MP3 Player
How do i keep,my songs on my mp3 player,without overwriting them?????
in order to help you illl need more information, like what programs are you using to download and convert them into your mp3 player? i use rhapsody, because when i used to use windows media player it would give me the same problems you seem to be having. P.s. my e250 screen is broken v.t it was the only thing holding my entire colection of kick ass songs, most of which are irreplaceable due to undownloadableness. i could kill myself
Aug 04, 2007 | SanDisk Sansa e250 MP3 Player
No enough memory
It simply is saying you put to many songs on the mp3 player and you need to delete some by connecting it to the computer and delete them, one way to stop this it to upgrade and get a bigger memory stick.
Oct 24, 2006 | SanDisk Sansa e100 MP3 Player
SanDisk Sansa e100 MP3 Player Logo
290 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
