Question about GE Monogram Side by Side Refrigerator
I have Ge monogram refrigerator side by side door. The fridge came with the house we bought. The fridge shuts off (displays "off" on both freezer and refrigerator side) every few hours. When I touch the temperature increase or decrease control, the fridge switches on. It is not an electric problem. I have a Appliance warranty from American Home. Technician can not figure out the problem. Any help would be highly appreciate.
    New Friend:
I have the same problem with my same fridge. Has there been any resolution? Thanks in advance.
Posted on May 27, 2014
    Master:
  • 713 Answers
Your control went bad.
Posted on Mar 20, 2011
My ge monogram side by side built in 48 refrigerator door won't automatically swing shut
Lubrication on the hinges will help. There are adjustments to the leveling feet behind the toe kick panel at the bottom of the fridge. Adjusting them may solve the problem
Jul 28, 2017 | GE Refrigerators
My GE Monogram Frig door will not stay shut, it's lost its vacuum seal!
Check the fridge for out of level. Magnets on the weather-stripping hold the door closed. If there is something stuck on the seal, or too much weight in the door in an un-level fridge it will not make good contact. Try cleaning the rubber, and removing everything from the door after leveling. A good seal will stay closed even if the fridge is off.
Feb 23, 2015 | GE Monogram ZISS480DRSS Stainless Steel
The refrigerator water dispenser started running without pushing the device. It won't stop unless the freezer door is open. We were just sitting in the family room and all of a sudden the dispenser...
Pull the fridge out and look behind it. You're looking for the water line that could possibly have valve shutoff. If not, follow the line back to the source. Could be tapped under the sink, could go anywhere. You are attempting to shut off water to the fridge without shutting water off to entire home. Worst case scenario is if you can't locate the fridge shutoff and you can't get it fixed today and you don't want to leave the freezer door open, locate the main water shutoff for the house and shut it off over night. Hope this helps.
Jan 26, 2011 | GE Monogram Side by Side Refrigerator
GE Monogram refrigerator feeezing even when thermostat is set at 45
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jun 07, 2010 | GE Monogram Side by Side Refrigerator
I have a monogram ZIS420 the freezer works fine
Sep 24, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Does power need to be shut off?
Its needs to be defrosted until they repair the defrost system ,after that the fridge should defrost automaticaly.
Aug 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Red door spring GE monogram fridge side door
Spring closure part # WR2X8916 from Sears Parts.
Jun 29, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
GE Monogram will not accept freezer/fridge
Turns out the problem was because we didn't shut the freezer door tightly. The temperature re4set itself in about three hours. All OK and no expense :-)
Jun 05, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Need to find model # for ge monogram 42" side-by-side (1992?)
on the 42" Monograms the Model & serial nomenclature are usually located behind the top panel in the center section to the right of the compressor panel. Hope this helps....Bill
May 18, 2009 | GE Monogram Side by Side Refrigerator
How often are you supposed to change the filter? (GE Monogram)
GE recommends once a year for the water filter for light use and twice a year if used heavily.
Please take time to rate this fixya.
May 11, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
GE Monogram Side by Side Refrigerator Logo
255 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
